i am facing problem with getting display from the DP port though the AGX orin is perfectly working with SSH remote
but through the DP Port i’m getting only full black screen.
I’m sharing the dmesg output without connecting DP Port & with connecting DP Port below
dmesgResultwithoutDP.txt (74.8 KB)
dmesgResultwithDP.txt (75.0 KB)
xrander output is coming like this
in both DP Port connected or Disconnected Situation
For the information related to installed Jetpack version kindly look below screenshot
I have already reflashed the AGX Orin multiple times using SDKManager but facing same issue.
The DP cable i’m using is perfectly working.
Also earlier, we were able to get the display using the same equipment, but for some reason it got damaged.
Kindly guide me.
