Hello there,
We are trying to bring up our custom board with AGX Orin 32GB and JetPack 5.0.2.
The following is our current configuration:
- We are using DisplayPort
- We have no EEPROM on the custom board, so we have made the following modification
- We are using RGMII ( MGBE not implemented)
- We haven’t finished our device tree, so we are using the AGX Orin device tree.
- Current debug UART is as follows
LOGS_NVIDIA_ORIN.txt (87.8 KB)
The power on sequence is executed correctly and we consume around 30W on the 12V input of the carrier board, after a few minutes consumption falls to around 1.5W.
But nothing appears on the display port screen.
Could you give us your critical opinion on the logs below?
We would be grateful if you would like to share your experience with making the DisplayPort work.
Thank you
