Jetson Orin Display Issue After Reboot
I am currently using the Jetson Orin with JetPack version 35.1.0. Prior to a recent reboot, I was able to use the system normally and could shut down or boot up without any issues. However, after the latest reboot, I only see the “boot options” screen, following which my display reports no video signal. Interestingly, the keyboard’s caps lock key seems to be responsive and I am able to SSH into Orin from another host machine.
[    30.296] (--) Log file renamed from "/var/log/Xorg.pid-2456.log" to "/var/log/Xorg.0.log"
[    30.297]
X.Org X Server 1.20.13
X Protocol Version 11, Revision 0
[    30.297] Build Operating System: linux Ubuntu
[    30.297] Current Operating System: Linux orin 5.10.104-tegra #35 SMP PREEMPT Tue Sep 20 16:13:56 CST 2022 aarch64
[    30.297] Kernel command line: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 console=ttyAMA0,115200 console=tty0 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0
[    30.297] Build Date: 29 March 2023  12:53:02PM
[    30.297] xorg-server 2:1.20.13-1ubuntu1~20.04.8 (For technical support please see http://www.ubuntu.com/support)
[    30.297] Current version of pixman: 0.38.4
[    30.297] 	Before reporting problems, check http://wiki.x.org
	to make sure that you have the latest version.
[    30.297] Markers: (--) probed, (**) from config file, (==) default setting,
	(++) from command line, (!!) notice, (II) informational,
	(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[    30.297] (==) Log file: "/var/log/Xorg.0.log", Time: Sat Oct 31 05:38:04 1970
[    30.298] (==) Using config file: "/etc/X11/xorg.conf"
[    30.298] (==) Using config directory: "/etc/X11/xorg.conf.d"
[    30.298] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    30.299] (==) No Layout section.  Using the first Screen section.
[    30.299] (==) No screen section available. Using defaults.
[    30.299] (**) |-->Screen "Default Screen Section" (0)
[    30.299] (**) |   |-->Monitor "<default monitor>"
[    30.300] (==) No device specified for screen "Default Screen Section".
	Using the first device section listed.
[    30.300] (**) |   |-->Device "Tegra0"
[    30.300] (==) No monitor specified for screen "Default Screen Section".
	Using a default monitor configuration.
[    30.300] (==) Automatically adding devices
[    30.300] (==) Automatically enabling devices
[    30.300] (==) Automatically adding GPU devices
[    30.300] (==) Automatically binding GPU devices
[    30.300] (==) Max clients allowed: 256, resource mask: 0x1fffff
[    30.300] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[    30.300] 	Entry deleted from font path.
[    30.300] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[    30.300] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[    30.300] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[    30.300] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[    30.300] (==) FontPath set to:
	/usr/share/fonts/X11/misc,
	/usr/share/fonts/X11/Type1,
	built-ins
[    30.300] (==) ModulePath set to "/usr/lib/xorg/modules"
[    30.300] (II) The server relies on udev to provide the list of input devices.
	If no devices become available, reconfigure udev or disable AutoAddDevices.
[    30.300] (II) Loader magic: 0xaaaae0e2a010
[    30.300] (II) Module ABI versions:
[    30.300] 	X.Org ANSI C Emulation: 0.4
[    30.300] 	X.Org Video Driver: 24.1
[    30.300] 	X.Org XInput driver : 24.1
[    30.300] 	X.Org Server Extension : 10.0
[    30.301] (++) using VT number 1
[    30.303] (II) systemd-logind: took control of session /org/freedesktop/login1/session/c1
[    30.304] (II) no primary bus or device found
[    30.304] (WW) "dri" will not be loaded unless you've specified it to be loaded elsewhere.
[    30.304] (II) "glx" will be loaded by default.
[    30.304] (II) LoadModule: "extmod"
[    30.304] (II) Module "extmod" already built-in
[    30.304] (II) LoadModule: "glx"
[    30.306] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[    30.310] (II) Module glx: vendor="X.Org Foundation"
[    30.311] 	compiled for 1.20.13, module version = 1.0.0
[    30.311] 	ABI class: X.Org Server Extension, version 10.0
[    30.311] (II) LoadModule: "nvidia"
[    30.311] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[    30.317] (II) Module nvidia: vendor="NVIDIA Corporation"
[    30.317] 	compiled for 1.6.99.901, module version = 1.0.0
[    30.318] 	Module class: X.Org Video Driver
[    30.318] (II) NVIDIA dlloader X Driver  35.1.0  Release Build  (bugfix_main)  (buildbrain@mobile-u64-5562-d3000)  Thu Aug 25 11:12:05 PDT 2022
[    30.318] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[    30.319] (WW) Falling back to old probe method for NVIDIA
[    30.319] (II) Loading sub module "fb"
[    30.319] (II) LoadModule: "fb"
[    30.319] (II) Loading /usr/lib/xorg/modules/libfb.so
[    30.320] (II) Module fb: vendor="X.Org Foundation"
[    30.320] 	compiled for 1.20.13, module version = 1.0.0
[    30.320] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    30.320] (II) Loading sub module "wfb"
[    30.320] (II) LoadModule: "wfb"
[    30.320] (II) Loading /usr/lib/xorg/modules/libwfb.so
[    30.321] (II) Module wfb: vendor="X.Org Foundation"
[    30.321] 	compiled for 1.20.13, module version = 1.0.0
[    30.321] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    30.321] (II) Loading sub module "ramdac"
[    30.321] (II) LoadModule: "ramdac"
[    30.321] (II) Module "ramdac" already built-in
[    30.413] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[    30.413] (II) NVIDIA(0): Creating default Display subsection in Screen section
	"Default Screen Section" for depth/fbbpp 24/32
[    30.413] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[    30.413] (==) NVIDIA(0): RGB weight 888
[    30.413] (==) NVIDIA(0): Default visual is TrueColor
[    30.413] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[    30.413] (DB) xf86MergeOutputClassOptions unsupported bus type 0
[    30.413] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration" "true"
[    30.413] (**) NVIDIA(0): Enabling 2D acceleration
[    30.413] (II) Loading sub module "glxserver_nvidia"
[    30.413] (II) LoadModule: "glxserver_nvidia"
[    30.413] (II) Loading /usr/lib/xorg/modules/extensions/libglxserver_nvidia.so
[    30.432] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[    30.432] 	compiled for 1.6.99.901, module version = 1.0.0
[    30.432] 	Module class: X.Org Server Extension
[    30.432] (II) NVIDIA GLX Module  35.1.0  Release Build  (bugfix_main)  (buildbrain@mobile-u64-5562-d3000)  Thu Aug 25 11:11:11 PDT 2022
[    30.433] (II) NVIDIA: The X server supports PRIME Render Offload.
[    30.634] (WW) NVIDIA: No DRM device: No direct render devices found.
[    30.636] (II) NVIDIA(0): NVIDIA GPU Orin (nvgpu) (GA10B) at SoC (GPU-0)
[    30.636] (--) NVIDIA(0): Memory: 31269600 kBytes
[    30.636] (--) NVIDIA(0): VideoBIOS:
[    30.636] (II) NVIDIA(0): Validated MetaModes:
[    30.636] (II) NVIDIA(0):     "NULL"
[    30.636] (II) NVIDIA(0): Virtual screen size determined to be 640 x 480
[    30.636] (WW) NVIDIA(0): Unable to get display device for DPI computation.
[    30.636] (==) NVIDIA(0): DPI set to (75, 75); computed from built-in default
[    30.636] (II) NVIDIA: Reserving 24576.00 MB of virtual memory for indirect memory
[    30.637] (II) NVIDIA:     access.
[    30.637] (WW) NVIDIA(GPU-0): Failed to enter interactive mode.
[    30.647] (EE) NVIDIA(0): Failed to allocate NVIDIA Error Handler
[    30.647] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[    30.647] (II) NVIDIA(0):     may not be running or the "AcpidSocketPath" X
[    30.647] (II) NVIDIA(0):     configuration option may not be set correctly.  When the
[    30.647] (II) NVIDIA(0):     ACPI event daemon is available, the NVIDIA X driver will
[    30.647] (II) NVIDIA(0):     try to use it to receive ACPI event notifications.  For
[    30.647] (II) NVIDIA(0):     details, please see the "ConnectToAcpid" and
[    30.647] (II) NVIDIA(0):     "AcpidSocketPath" X configuration options in Appendix B: X
[    30.647] (II) NVIDIA(0):     Config Options in the README.
[    30.672] (II) NVIDIA(0): Setting mode "NULL"
[    30.677] (==) NVIDIA(0): Disabling shared memory pixmaps
[    30.677] (==) NVIDIA(0): Backing store enabled
[    30.677] (==) NVIDIA(0): Silken mouse enabled
[    30.678] (==) NVIDIA(0): DPMS enabled
[    30.678] (II) Loading sub module "dri2"
[    30.678] (II) LoadModule: "dri2"
[    30.678] (II) Module "dri2" already built-in
[    30.678] (II) NVIDIA(0): [DRI2] Setup complete
[    30.678] (II) NVIDIA(0): [DRI2]   VDPAU driver: nvidia
[    30.678] (II) Initializing extension Generic Event Extension
[    30.679] (II) Initializing extension SHAPE
[    30.679] (II) Initializing extension MIT-SHM
[    30.679] (II) Initializing extension XInputExtension
[    30.679] (II) Initializing extension XTEST
[    30.679] (II) Initializing extension BIG-REQUESTS
[    30.679] (II) Initializing extension SYNC
[    30.680] (II) Initializing extension XKEYBOARD
[    30.680] (II) Initializing extension XC-MISC
[    30.680] (II) Initializing extension SECURITY
[    30.680] (II) Initializing extension XFIXES
[    30.680] (II) Initializing extension RENDER
[    30.680] (II) Initializing extension RANDR
[    30.680] (II) Initializing extension COMPOSITE
[    30.680] (II) Initializing extension DAMAGE
[    30.681] (II) Initializing extension MIT-SCREEN-SAVER
[    30.681] (II) Initializing extension DOUBLE-BUFFER
[    30.681] (II) Initializing extension RECORD
[    30.681] (II) Initializing extension DPMS
[    30.681] (II) Initializing extension Present
[    30.681] (II) Initializing extension DRI3
[    30.681] (II) Initializing extension X-Resource
[    30.681] (II) Initializing extension XVideo
[    30.681] (II) Initializing extension XVideo-MotionCompensation
[    30.681] (II) Initializing extension SELinux
[    30.681] (II) SELinux: Disabled on system
[    30.681] (II) Initializing extension GLX
[    30.682] (II) Indirect GLX disabled.
[    30.682] (II) GLX: Another vendor is already registered for screen 0
[    30.682] (II) Initializing extension XFree86-VidModeExtension
[    30.682] (II) Initializing extension XFree86-DGA
[    30.682] (II) Initializing extension XFree86-DRI
[    30.682] (II) Initializing extension DRI2
[    30.682] (II) Initializing extension NV-GLX
[    30.682] (II) Initializing extension NV-CONTROL
[    30.832] (II) config/udev: Adding input device NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=3 (/dev/input/event5)
[    30.832] (II) No input driver specified, ignoring this device.
[    30.832] (II) This device may have been added with another device file.
[    30.833] (II) config/udev: Adding input device NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=7 (/dev/input/event6)
[    30.833] (II) No input driver specified, ignoring this device.
[    30.833] (II) This device may have been added with another device file.
[    30.833] (II) config/udev: Adding input device NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=8 (/dev/input/event7)
[    30.834] (II) config/udev: Adding input device NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=9 (/dev/input/event8)
[    30.834] (II) No input driver specified, ignoring this device.
[    30.834] (II) This device may have been added with another device file.
[    30.834] (II) config/udev: Adding input device  USB OPTICAL MOUSE (/dev/input/event0)
[    30.834] (**)  USB OPTICAL MOUSE: Applying InputClass "libinput pointer catchall"
[    30.834] (II) LoadModule: "libinput"
[    30.835] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[    30.839] (II) Module libinput: vendor="X.Org Foundation"
[    30.839] 	compiled for 1.20.4, module version = 0.29.0
[    30.839] 	Module class: X.Org XInput Driver
[    30.839] 	ABI class: X.Org XInput driver, version 24.1
[    30.839] (II) Using input driver 'libinput' for ' USB OPTICAL MOUSE'
[    30.896] (II) systemd-logind: got fd for /dev/input/event0 13:64 fd 31 paused 0
[    30.896] (**)  USB OPTICAL MOUSE: always reports core events
[    30.896] (**) Option "Device" "/dev/input/event0"
[    30.896] (**) Option "_source" "server/udev"
[    30.902] (II) event0  -  USB OPTICAL MOUSE: is tagged by udev as: Mouse
[    30.902] (II) event0  -  USB OPTICAL MOUSE: device is a pointer
[    30.902] (II) event0  -  USB OPTICAL MOUSE: device removed
[    30.903] (**) Option "config_info" "udev:/sys/devices/platform/3610000.xhci/usb1/1-2/1-2.3/1-2.3:1.0/0003:0000:3825.0001/input/input0/event0"
[    30.903] (II) XINPUT: Adding extended input device " USB OPTICAL MOUSE" (type: MOUSE, id 6)
[    30.903] (**) Option "AccelerationScheme" "none"
[    30.903] (**)  USB OPTICAL MOUSE: (accel) selected scheme none/0
[    30.903] (**)  USB OPTICAL MOUSE: (accel) acceleration factor: 2.000
[    30.903] (**)  USB OPTICAL MOUSE: (accel) acceleration threshold: 4
[    30.904] (II) event0  -  USB OPTICAL MOUSE: is tagged by udev as: Mouse
[    30.904] (II) event0  -  USB OPTICAL MOUSE: device is a pointer
[    30.905] (II) config/udev: Adding input device  USB OPTICAL MOUSE (/dev/input/mouse0)
[    30.905] (II) No input driver specified, ignoring this device.
[    30.905] (II) This device may have been added with another device file.
[    30.906] (II) config/udev: Adding input device Usb KeyBoard Usb KeyBoard (/dev/input/event1)
[    30.906] (**) Usb KeyBoard Usb KeyBoard: Applying InputClass "libinput keyboard catchall"
[    30.906] (II) Using input driver 'libinput' for 'Usb KeyBoard Usb KeyBoard'
[    30.907] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 34 paused 0
[    30.907] (**) Usb KeyBoard Usb KeyBoard: always reports core events
[    30.907] (**) Option "Device" "/dev/input/event1"
[    30.907] (**) Option "_source" "server/udev"
[    30.908] (II) event1  - Usb KeyBoard Usb KeyBoard: is tagged by udev as: Keyboard
[    30.908] (II) event1  - Usb KeyBoard Usb KeyBoard: device is a keyboard
[    30.908] (II) event1  - Usb KeyBoard Usb KeyBoard: device removed
[    30.908] (**) Option "config_info" "udev:/sys/devices/platform/3610000.xhci/usb1/1-2/1-2.4/1-2.4:1.0/0003:C0F4:01F5.0004/input/input9/event1"
[    30.908] (II) XINPUT: Adding extended input device "Usb KeyBoard Usb KeyBoard" (type: KEYBOARD, id 7)
[    30.908] (**) Option "xkb_model" "pc105"
[    30.908] (**) Option "xkb_layout" "us"
[    30.910] (II) event1  - Usb KeyBoard Usb KeyBoard: is tagged by udev as: Keyboard
[    30.910] (II) event1  - Usb KeyBoard Usb KeyBoard: device is a keyboard
[    30.911] (II) config/udev: Adding input device Usb KeyBoard Usb KeyBoard Consumer Control (/dev/input/event2)
[    30.911] (**) Usb KeyBoard Usb KeyBoard Consumer Control: Applying InputClass "libinput keyboard catchall"
[    30.911] (II) Using input driver 'libinput' for 'Usb KeyBoard Usb KeyBoard Consumer Control'
[    30.912] (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 35 paused 0
[    30.912] (**) Usb KeyBoard Usb KeyBoard Consumer Control: always reports core events
[    30.912] (**) Option "Device" "/dev/input/event2"
[    30.912] (**) Option "_source" "server/udev"
[    30.913] (II) event2  - Usb KeyBoard Usb KeyBoard Consumer Control: is tagged by udev as: Keyboard
[    30.913] (II) event2  - Usb KeyBoard Usb KeyBoard Consumer Control: device is a keyboard
[    30.913] (II) event2  - Usb KeyBoard Usb KeyBoard Consumer Control: device removed
[    30.913] (II) libinput: Usb KeyBoard Usb KeyBoard Consumer Control: needs a virtual subdevice
[    30.913] (**) Option "config_info" "udev:/sys/devices/platform/3610000.xhci/usb1/1-2/1-2.4/1-2.4:1.1/0003:C0F4:01F5.0005/input/input10/event2"
[    30.913] (II) XINPUT: Adding extended input device "Usb KeyBoard Usb KeyBoard Consumer Control" (type: MOUSE, id 8)
[    30.913] (**) Option "AccelerationScheme" "none"
[    30.914] (**) Usb KeyBoard Usb KeyBoard Consumer Control: (accel) selected scheme none/0
[    30.914] (**) Usb KeyBoard Usb KeyBoard Consumer Control: (accel) acceleration factor: 2.000
[    30.914] (**) Usb KeyBoard Usb KeyBoard Consumer Control: (accel) acceleration threshold: 4
[    30.915] (II) event2  - Usb KeyBoard Usb KeyBoard Consumer Control: is tagged by udev as: Keyboard
[    30.915] (II) event2  - Usb KeyBoard Usb KeyBoard Consumer Control: device is a keyboard
[    30.916] (II) config/udev: Adding input device Usb KeyBoard Usb KeyBoard System Control (/dev/input/event3)
[    30.916] (**) Usb KeyBoard Usb KeyBoard System Control: Applying InputClass "libinput keyboard catchall"
[    30.916] (II) Using input driver 'libinput' for 'Usb KeyBoard Usb KeyBoard System Control'
[    30.916] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 36 paused 0
[    30.916] (**) Usb KeyBoard Usb KeyBoard System Control: always reports core events
[    30.917] (**) Option "Device" "/dev/input/event3"
[    30.917] (**) Option "_source" "server/udev"
[    30.918] (II) event3  - Usb KeyBoard Usb KeyBoard System Control: is tagged by udev as: Keyboard
[    30.918] (II) event3  - Usb KeyBoard Usb KeyBoard System Control: device is a keyboard
[    30.918] (II) event3  - Usb KeyBoard Usb KeyBoard System Control: device removed
[    30.918] (**) Option "config_info" "udev:/sys/devices/platform/3610000.xhci/usb1/1-2/1-2.4/1-2.4:1.1/0003:C0F4:01F5.0005/input/input11/event3"
[    30.918] (II) XINPUT: Adding extended input device "Usb KeyBoard Usb KeyBoard System Control" (type: KEYBOARD, id 9)
[    30.918] (**) Option "xkb_model" "pc105"
[    30.918] (**) Option "xkb_layout" "us"
[    30.920] (II) event3  - Usb KeyBoard Usb KeyBoard System Control: is tagged by udev as: Keyboard
[    30.920] (II) event3  - Usb KeyBoard Usb KeyBoard System Control: device is a keyboard
[    30.921] (II) config/udev: Adding input device gpio-keys (/dev/input/event4)
[    30.921] (**) gpio-keys: Applying InputClass "libinput keyboard catchall"
[    30.921] (II) Using input driver 'libinput' for 'gpio-keys'
[    30.922] (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 37 paused 0
[    30.922] (**) gpio-keys: always reports core events
[    30.922] (**) Option "Device" "/dev/input/event4"
[    30.922] (**) Option "_source" "server/udev"
[    30.922] (II) event4  - gpio-keys: is tagged by udev as: Keyboard
[    30.922] (II) event4  - gpio-keys: device is a keyboard
[    30.922] (II) event4  - gpio-keys: device removed
[    30.922] (**) Option "config_info" "udev:/sys/devices/platform/gpio-keys/input/input4/event4"
[    30.922] (II) XINPUT: Adding extended input device "gpio-keys" (type: KEYBOARD, id 10)
[    30.922] (**) Option "xkb_model" "pc105"
[    30.923] (**) Option "xkb_layout" "us"
[    30.923] (II) event4  - gpio-keys: is tagged by udev as: Keyboard
[    30.923] (II) event4  - gpio-keys: device is a keyboard
[    30.930] (**) Usb KeyBoard Usb KeyBoard Consumer Control: Applying InputClass "libinput keyboard catchall"
[    30.930] (II) Using input driver 'libinput' for 'Usb KeyBoard Usb KeyBoard Consumer Control'
[    30.930] (II) systemd-logind: returning pre-existing fd for /dev/input/event2 13:66
[    30.930] (**) Usb KeyBoard Usb KeyBoard Consumer Control: always reports core events
[    30.930] (**) Option "Device" "/dev/input/event2"
[    30.930] (**) Option "_source" "_driver/libinput"
[    30.930] (II) libinput: Usb KeyBoard Usb KeyBoard Consumer Control: is a virtual subdevice
[    30.930] (**) Option "config_info" "udev:/sys/devices/platform/3610000.xhci/usb1/1-2/1-2.4/1-2.4:1.1/0003:C0F4:01F5.0005/input/input10/event2"
[    30.930] (II) XINPUT: Adding extended input device "Usb KeyBoard Usb KeyBoard Consumer Control" (type: KEYBOARD, id 11)
[    30.930] (**) Option "xkb_model" "pc105"
[    30.930] (**) Option "xkb_layout" "us"
If there are other logs or additional information that would be helpful in diagnosing this issue, please let me know and I will provide them as soon as possible.
Thank you in advance for your help!
is the display driver loaded correctly?
Check lsmod | grep nvidia.
Also enable the verbose Xorg log as shown here:
Now, I can access the display normally. However, the directory /home/nvidia appears to be completely new and does not contain any of the files I had previously saved. In my attempt to restore access to the interface, I’ve taken the following steps, denoted as :
sudo mount /dev/mmcblkop1 /mnt
cd /mnt/etc
sudo rm setssdroot
This issue may have arisen from my previous attempts at creating multiple users on Orin. The command I used to do so was :
sudo adduser test
sudo usermod -aG sudo test
su test
Jetson orin suddenly gets stuck after " su test " enter
Sounds like you boot into the eMMC instead of the NVMe drive originally used.
if you want the system to boot from NVMe drives, we do officially support flashing directly into them.
Please check Workflow 3 in Linux_for_Tegra/tools/kernel_flash/README_initrd_flash.txt.
To add a bit more information, when I SSH back into Orin, I used the command sudo deluser test to remove the user I had previously created. After I was able to restore the interface and log back in, I noticed two directories under /dev/nvme0n1p1/home , namely nvidia and test .
It’s expected as deleting a user account does not also delete the home folder.
It seems there might be some misunderstanding. I want to clarify that I have been using the NVMe drive for booting up consistently in the past. The reason I resorted to booting from eMMC now is that I could not access the desktop interface normally via NVMe.
so maybe I delete the test floder?
I’m if you boot into the eMMC, then it’s totally expected that the contents of the home folder in the eMMC differ from the one in the NVMe drive. Or you did not mean that?
Just to make sure, is it still an issue to support?
Why can’t you if you don’t need it anymore?
I deleted the test user’s home directory, then tried to reboot using NVMe. Unfortunately, I still cannot access the desktop interface normally. Any further assistance would be greatly appreciated.
Then can you just re-flash the NVMe drive?
I also don’t see the response here.
While I appreciate your suggestion to reflash the system, I currently have many development tasks running on Orin. Therefore, I would prefer to try and return to the state of normal use before considering a system reflash.
When I run the command lsmod | grep nvidia, there is no output.
So apparently the display driver is gone.
Are you using the default BSP, or you made some customization to the kernel?
Are nvidia.ko, nvidia-drm.ko, nvidia-modeset.ko present under /usr/lib/modules/$(uname -r)/extra/opensrc-disp/? What if you manually modprobe them?
cd /usr/lib/modules/5.10.104-tegra/extra/opensrc-disp/
nvidia@orin:/usr/lib/modules/5.10.104-tegra/extra/opensrc-disp$ ls
nvidia-drm.ko  nvidia.ko  nvidia-modeset.ko
sudo modprobe nvidia
modprobe: ERROR: could not insert 'nvidia': No such device
sudo modprobe nvidia.ko
modprobe: FATAL: Module nvidia.ko not found in directory /lib/modules/5.10.104-tegra
sudo modprobe nvidia-drm
modprobe: ERROR: could not insert 'nvidia_drm': No such device
sudo modprobe nvidia-modeset
modprobe: ERROR: could not insert 'nvidia_modeset': No such device
How about this?
Can you also try running sudo depmod -a and loading the modules again?
If that still does not work, then the only thing I can suggest is really a re-flash.
╥_╥
Alright, I’ve decided to reflash the system. Thank you for the suggestion.
