Hello, I encountered a problem with my Jetson AGX Orin 64GB Developer Kit. The initial boot on eMMC, which was supposed to happen at the first startup, did not occur. I then proceeded to the recovery mode using the SDK Manager to flash JetPack 6.0 onto it. Now, I can connect via SSH to my Jetson, but I don’t have the ability to have a display output on a screen and use a mouse and keyboard for navigation. Therefore, I lack a graphical interface.
Can you help me ?
Dump the /var/log/Xorg.0.log from your ssh console first.
~$ cat /var/log/Xorg.0.log
[ 2876.632] (--) Log file renamed from "/var/log/Xorg.pid-2641.log" to "/var/log/Xorg.0.log"
[ 2876.633]
X.Org X Server 1.21.1.4
X Protocol Version 11, Revision 0
[ 2876.633] Current Operating System: Linux ubuntu 5.15.122-tegra #1 SMP PREEMPT Thu Nov 30 10:30:37 PST 2023 aarch64
[ 2876.633] Kernel command line: root=PARTUUID=2a7ca91a-29c1-4099-bf6e-cb3d3903408a rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 console=ttyAMA0,115200 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0 nospectre_bhb video=efifb:off console=tty0 nv-auto-config bl_prof_dataptr=2031616@0x102C610000 bl_prof_ro_ptr=65536@0x102C600000
[ 2876.633] xorg-server 2:21.1.4-2ubuntu1.7~22.04.2 (For technical support please see http://www.ubuntu.com/support)
[ 2876.633] Current version of pixman: 0.40.0
[ 2876.633] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 2876.633] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 2876.633] (==) Log file: "/var/log/Xorg.0.log", Time: Wed Feb 28 13:21:44 2024
[ 2876.633] (==) Using config file: "/etc/X11/xorg.conf"
[ 2876.633] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 2876.633] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 2876.633] (==) No Layout section. Using the first Screen section.
[ 2876.633] (==) No screen section available. Using defaults.
[ 2876.633] (**) |-->Screen "Default Screen Section" (0)
[ 2876.633] (**) | |-->Monitor "<default monitor>"
[ 2876.634] (==) No device specified for screen "Default Screen Section".
Using the first device section listed.
[ 2876.634] (**) | |-->Device "Tegra0"
[ 2876.634] (==) No monitor specified for screen "Default Screen Section".
Using a default monitor configuration.
[ 2876.634] (==) Automatically adding devices
[ 2876.634] (==) Automatically enabling devices
[ 2876.634] (==) Automatically adding GPU devices
[ 2876.634] (==) Automatically binding GPU devices
[ 2876.634] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 2876.634] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 2876.634] Entry deleted from font path.
[ 2876.634] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[ 2876.634] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[ 2876.634] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[ 2876.634] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[ 2876.634] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
[ 2876.634] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 2876.634] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 2876.634] (II) Loader magic: 0xaaaac9ea1010
[ 2876.634] (II) Module ABI versions:
[ 2876.634] X.Org ANSI C Emulation: 0.4
[ 2876.634] X.Org Video Driver: 25.2
[ 2876.634] X.Org XInput driver : 24.4
[ 2876.634] X.Org Server Extension : 10.0
[ 2876.635] (++) using VT number 1
[ 2876.637] (II) systemd-logind: took control of session /org/freedesktop/login1/session/c2
[ 2876.638] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 2876.638] (II) Platform probe for /sys/devices/platform/bus@0/13e00000.host1x/drm/drm/card0
[ 2876.639] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 12 paused 0
[ 2876.640] (II) no primary bus or device found
[ 2876.640] falling back to /sys/devices/platform/bus@0/13e00000.host1x/drm/drm/card0
[ 2876.640] (WW) "dri" will not be loaded unless you've specified it to be loaded elsewhere.
[ 2876.640] (II) "glx" will be loaded by default.
[ 2876.640] (II) LoadModule: "extmod"
[ 2876.640] (II) Module "extmod" already built-in
[ 2876.640] (II) LoadModule: "glx"
[ 2876.640] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 2876.642] (II) Module glx: vendor="X.Org Foundation"
[ 2876.642] compiled for 1.21.1.4, module version = 1.0.0
[ 2876.642] ABI class: X.Org Server Extension, version 10.0
[ 2876.642] (II) LoadModule: "nvidia"
[ 2876.642] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 2876.643] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 2876.643] compiled for 1.6.99.901, module version = 1.0.0
[ 2876.643] Module class: X.Org Video Driver
[ 2876.643] (II) NVIDIA dlloader X Driver 540.2.0 Release Build (bugfix_main) (buildbrain@mobile-u64-6517-d7000) Thu Nov 30 10:43:30 PST 2023
[ 2876.643] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 2876.643] (II) systemd-logind: releasing fd for 226:0
[ 2876.644] (II) Loading sub module "fb"
[ 2876.644] (II) LoadModule: "fb"
[ 2876.644] (II) Module "fb" already built-in
[ 2876.644] (II) Loading sub module "wfb"
[ 2876.644] (II) LoadModule: "wfb"
[ 2876.644] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 2876.645] (II) Module wfb: vendor="X.Org Foundation"
[ 2876.645] compiled for 1.21.1.4, module version = 1.0.0
[ 2876.645] ABI class: X.Org ANSI C Emulation, version 0.4
[ 2876.764] (II) NVIDIA(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 2876.764] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[ 2876.765] (==) NVIDIA(0): RGB weight 888
[ 2876.765] (==) NVIDIA(0): Default visual is TrueColor
[ 2876.765] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 2876.765] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration" "true"
[ 2876.765] (**) NVIDIA(0): Enabling 2D acceleration
[ 2876.765] (II) Loading sub module "glxserver_nvidia"
[ 2876.765] (II) LoadModule: "glxserver_nvidia"
[ 2876.765] (II) Loading /usr/lib/xorg/modules/extensions/libglxserver_nvidia.so
[ 2876.770] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[ 2876.770] compiled for 1.6.99.901, module version = 1.0.0
[ 2876.770] Module class: X.Org Server Extension
[ 2876.771] (II) NVIDIA GLX Module 540.2.0 Release Build (bugfix_main) (buildbrain@mobile-u64-6517-d7000) Thu Nov 30 10:42:33 PST 2023
[ 2876.771] (II) NVIDIA: The X server supports PRIME Render Offload.
[ 2877.092] (--) NVIDIA(0): Valid display device(s) on GPU-0 at SoC
[ 2877.092] (--) NVIDIA(0): DFP-0
[ 2877.092] (--) NVIDIA(0): DFP-1
[ 2877.095] (II) NVIDIA(0): NVIDIA GPU Orin (nvgpu) (GA10B) at SoC (GPU-0)
[ 2877.095] (--) NVIDIA(0): Memory: 64349648 kBytes
[ 2877.095] (--) NVIDIA(0): VideoBIOS:
[ 2877.095] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 2877.095] (--) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[ 2877.095] (--) NVIDIA(GPU-0): DFP-0: 2380.0 MHz maximum pixel clock
[ 2877.110] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 2877.110] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 2877.110] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 2877.110] (==) NVIDIA(0):
[ 2877.111] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[ 2877.111] (==) NVIDIA(0): will be used as the requested mode.
[ 2877.111] (--) NVIDIA(0): No enabled display devices found; starting anyway because
[ 2877.111] (--) NVIDIA(0): AllowEmptyInitialConfiguration is enabled
[ 2877.115] (II) NVIDIA(0): Validated MetaModes:
[ 2877.115] (II) NVIDIA(0): "NULL"
[ 2877.115] (II) NVIDIA(0): Virtual screen size determined to be 640 x 480
[ 2877.115] (WW) NVIDIA(0): Unable to get display device for DPI computation.
[ 2877.115] (==) NVIDIA(0): DPI set to (75, 75); computed from built-in default
[ 2877.115] (II) NVIDIA: Reserving 24576.00 MB of virtual memory for indirect memory
[ 2877.115] (II) NVIDIA: access.
[ 2877.115] (WW) NVIDIA(GPU-0): Failed to enter interactive mode.
[ 2877.119] (EE) NVIDIA(0): Failed to allocate NVIDIA Error Handler
[ 2877.119] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 2877.119] (II) NVIDIA(0): may not be running or the "AcpidSocketPath" X
[ 2877.119] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 2877.119] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 2877.119] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 2877.119] (II) NVIDIA(0): details, please see the "ConnectToAcpid" and
[ 2877.119] (II) NVIDIA(0): "AcpidSocketPath" X configuration options in Appendix B: X
[ 2877.119] (II) NVIDIA(0): Config Options in the README.
[ 2877.148] (II) NVIDIA(0): Setting mode "NULL"
[ 2877.163] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 2877.163] (==) NVIDIA(0): Backing store enabled
[ 2877.163] (==) NVIDIA(0): Silken mouse enabled
[ 2877.164] (==) NVIDIA(0): DPMS enabled
[ 2877.164] (II) Loading sub module "dri2"
[ 2877.164] (II) LoadModule: "dri2"
[ 2877.164] (II) Module "dri2" already built-in
[ 2877.164] (II) NVIDIA(0): [DRI2] Setup complete
[ 2877.164] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 2877.164] (II) Initializing extension Generic Event Extension
[ 2877.164] (II) Initializing extension SHAPE
[ 2877.164] (II) Initializing extension MIT-SHM
[ 2877.165] (II) Initializing extension XInputExtension
[ 2877.165] (II) Initializing extension XTEST
[ 2877.165] (II) Initializing extension BIG-REQUESTS
[ 2877.165] (II) Initializing extension SYNC
[ 2877.165] (II) Initializing extension XKEYBOARD
[ 2877.165] (II) Initializing extension XC-MISC
[ 2877.166] (II) Initializing extension SECURITY
[ 2877.166] (II) Initializing extension XFIXES
[ 2877.166] (II) Initializing extension RENDER
[ 2877.166] (II) Initializing extension RANDR
[ 2877.166] (II) Initializing extension COMPOSITE
[ 2877.166] (II) Initializing extension DAMAGE
[ 2877.167] (II) Initializing extension MIT-SCREEN-SAVER
[ 2877.167] (II) Initializing extension DOUBLE-BUFFER
[ 2877.167] (II) Initializing extension RECORD
[ 2877.167] (II) Initializing extension DPMS
[ 2877.167] (II) Initializing extension Present
[ 2877.167] (II) Initializing extension DRI3
[ 2877.167] (II) Initializing extension X-Resource
[ 2877.168] (II) Initializing extension XVideo
[ 2877.168] (II) Initializing extension XVideo-MotionCompensation
[ 2877.168] (II) Initializing extension SELinux
[ 2877.168] (II) SELinux: Disabled on system
[ 2877.168] (II) Initializing extension GLX
[ 2877.168] (II) Indirect GLX disabled.
[ 2877.168] (II) GLX: Another vendor is already registered for screen 0
[ 2877.168] (II) Initializing extension XFree86-VidModeExtension
[ 2877.168] (II) Initializing extension XFree86-DGA
[ 2877.168] (II) Initializing extension XFree86-DRI
[ 2877.169] (II) Initializing extension DRI2
[ 2877.169] (II) Initializing extension NV-GLX
[ 2877.169] (II) Initializing extension NV-CONTROL
[ 2877.215] (II) config/udev: Adding input device NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=3 (/dev/input/event1)
[ 2877.215] (II) No input driver specified, ignoring this device.
[ 2877.215] (II) This device may have been added with another device file.
[ 2877.215] (II) config/udev: Adding input device NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=7 (/dev/input/event2)
[ 2877.216] (II) No input driver specified, ignoring this device.
[ 2877.216] (II) This device may have been added with another device file.
[ 2877.216] (II) config/udev: Adding input device NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=8 (/dev/input/event3)
[ 2877.217] (II) config/udev: Adding input device NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=9 (/dev/input/event4)
[ 2877.217] (II) No input driver specified, ignoring this device.
[ 2877.217] (II) This device may have been added with another device file.
[ 2877.218] (II) config/udev: Adding input device Dell KB216 Wired Keyboard (/dev/input/event6)
[ 2877.218] (**) Dell KB216 Wired Keyboard: Applying InputClass "libinput keyboard catchall"
[ 2877.218] (II) LoadModule: "libinput"
[ 2877.218] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 2877.220] (II) Module libinput: vendor="X.Org Foundation"
[ 2877.220] compiled for 1.20.14, module version = 1.2.1
[ 2877.220] Module class: X.Org XInput Driver
[ 2877.220] ABI class: X.Org XInput driver, version 24.1
[ 2877.220] (II) Using input driver 'libinput' for 'Dell KB216 Wired Keyboard'
[ 2877.222] (II) systemd-logind: got fd for /dev/input/event6 13:70 fd 39 paused 0
[ 2877.222] (**) Dell KB216 Wired Keyboard: always reports core events
[ 2877.222] (**) Option "Device" "/dev/input/event6"
[ 2877.225] (II) event6 - Dell KB216 Wired Keyboard: is tagged by udev as: Keyboard
[ 2877.225] (II) event6 - Dell KB216 Wired Keyboard: device is a keyboard
[ 2877.226] (II) event6 - Dell KB216 Wired Keyboard: device removed
[ 2877.226] (**) Option "config_info" "udev:/sys/devices/platform/bus@0/3610000.usb/usb1/1-4/1-4.1/1-4.1:1.0/0003:413C:2113.0001/input/input6/event6"
[ 2877.226] (II) XINPUT: Adding extended input device "Dell KB216 Wired Keyboard" (type: KEYBOARD, id 6)
[ 2877.226] (**) Option "xkb_model" "pc105"
[ 2877.226] (**) Option "xkb_layout" "fr"
[ 2877.226] (**) Option "xkb_variant" "latin9"
[ 2877.247] (II) event6 - Dell KB216 Wired Keyboard: is tagged by udev as: Keyboard
[ 2877.247] (II) event6 - Dell KB216 Wired Keyboard: device is a keyboard
[ 2877.249] (II) config/udev: Adding input device Dell KB216 Wired Keyboard Consumer Control (/dev/input/event7)
[ 2877.249] (**) Dell KB216 Wired Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 2877.249] (II) Using input driver 'libinput' for 'Dell KB216 Wired Keyboard Consumer Control'
[ 2877.250] (II) systemd-logind: got fd for /dev/input/event7 13:71 fd 42 paused 0
[ 2877.250] (**) Dell KB216 Wired Keyboard Consumer Control: always reports core events
[ 2877.250] (**) Option "Device" "/dev/input/event7"
[ 2877.252] (II) event7 - Dell KB216 Wired Keyboard Consumer Control: is tagged by udev as: Keyboard
[ 2877.252] (II) event7 - Dell KB216 Wired Keyboard Consumer Control: device is a keyboard
[ 2877.253] (II) event7 - Dell KB216 Wired Keyboard Consumer Control: device removed
[ 2877.253] (II) libinput: Dell KB216 Wired Keyboard Consumer Control: needs a virtual subdevice
[ 2877.253] (**) Option "config_info" "udev:/sys/devices/platform/bus@0/3610000.usb/usb1/1-4/1-4.1/1-4.1:1.1/0003:413C:2113.0002/input/input7/event7"
[ 2877.253] (II) XINPUT: Adding extended input device "Dell KB216 Wired Keyboard Consumer Control" (type: MOUSE, id 7)
[ 2877.253] (**) Option "AccelerationScheme" "none"
[ 2877.253] (**) Dell KB216 Wired Keyboard Consumer Control: (accel) selected scheme none/0
[ 2877.253] (**) Dell KB216 Wired Keyboard Consumer Control: (accel) acceleration factor: 2.000
[ 2877.253] (**) Dell KB216 Wired Keyboard Consumer Control: (accel) acceleration threshold: 4
[ 2877.255] (II) event7 - Dell KB216 Wired Keyboard Consumer Control: is tagged by udev as: Keyboard
[ 2877.255] (II) event7 - Dell KB216 Wired Keyboard Consumer Control: device is a keyboard
[ 2877.256] (II) config/udev: Adding input device Dell KB216 Wired Keyboard System Control (/dev/input/event8)
[ 2877.256] (**) Dell KB216 Wired Keyboard System Control: Applying InputClass "libinput keyboard catchall"
[ 2877.256] (II) Using input driver 'libinput' for 'Dell KB216 Wired Keyboard System Control'
[ 2877.257] (II) systemd-logind: got fd for /dev/input/event8 13:72 fd 43 paused 0
[ 2877.257] (**) Dell KB216 Wired Keyboard System Control: always reports core events
[ 2877.257] (**) Option "Device" "/dev/input/event8"
[ 2877.259] (II) event8 - Dell KB216 Wired Keyboard System Control: is tagged by udev as: Keyboard
[ 2877.259] (II) event8 - Dell KB216 Wired Keyboard System Control: device is a keyboard
[ 2877.259] (II) event8 - Dell KB216 Wired Keyboard System Control: device removed
[ 2877.259] (**) Option "config_info" "udev:/sys/devices/platform/bus@0/3610000.usb/usb1/1-4/1-4.1/1-4.1:1.1/0003:413C:2113.0002/input/input8/event8"
[ 2877.259] (II) XINPUT: Adding extended input device "Dell KB216 Wired Keyboard System Control" (type: KEYBOARD, id 8)
[ 2877.260] (**) Option "xkb_model" "pc105"
[ 2877.260] (**) Option "xkb_layout" "fr"
[ 2877.260] (**) Option "xkb_variant" "latin9"
[ 2877.261] (II) event8 - Dell KB216 Wired Keyboard System Control: is tagged by udev as: Keyboard
[ 2877.262] (II) event8 - Dell KB216 Wired Keyboard System Control: device is a keyboard
[ 2877.263] (II) config/udev: Adding input device Logitech USB Optical Mouse (/dev/input/event9)
[ 2877.263] (**) Logitech USB Optical Mouse: Applying InputClass "libinput pointer catchall"
[ 2877.263] (II) Using input driver 'libinput' for 'Logitech USB Optical Mouse'
[ 2877.264] (II) systemd-logind: got fd for /dev/input/event9 13:73 fd 44 paused 0
[ 2877.264] (**) Logitech USB Optical Mouse: always reports core events
[ 2877.264] (**) Option "Device" "/dev/input/event9"
[ 2877.266] (II) event9 - Logitech USB Optical Mouse: is tagged by udev as: Mouse
[ 2877.266] (II) event9 - Logitech USB Optical Mouse: device is a pointer
[ 2877.266] (II) event9 - Logitech USB Optical Mouse: device removed
[ 2877.267] (**) Option "config_info" "udev:/sys/devices/platform/bus@0/3610000.usb/usb1/1-4/1-4.2/1-4.2:1.0/0003:046D:C077.0003/input/input9/event9"
[ 2877.267] (II) XINPUT: Adding extended input device "Logitech USB Optical Mouse" (type: MOUSE, id 9)
[ 2877.267] (**) Option "AccelerationScheme" "none"
[ 2877.267] (**) Logitech USB Optical Mouse: (accel) selected scheme none/0
[ 2877.267] (**) Logitech USB Optical Mouse: (accel) acceleration factor: 2.000
[ 2877.267] (**) Logitech USB Optical Mouse: (accel) acceleration threshold: 4
[ 2877.269] (II) event9 - Logitech USB Optical Mouse: is tagged by udev as: Mouse
[ 2877.269] (II) event9 - Logitech USB Optical Mouse: device is a pointer
[ 2877.270] (II) config/udev: Adding input device gpio-keys (/dev/input/event0)
[ 2877.270] (**) gpio-keys: Applying InputClass "libinput keyboard catchall"
[ 2877.270] (II) Using input driver 'libinput' for 'gpio-keys'
[ 2877.270] (II) systemd-logind: got fd for /dev/input/event0 13:64 fd 45 paused 0
[ 2877.270] (**) gpio-keys: always reports core events
[ 2877.270] (**) Option "Device" "/dev/input/event0"
[ 2877.271] (II) event0 - gpio-keys: is tagged by udev as: Keyboard
[ 2877.271] (II) event0 - gpio-keys: device is a keyboard
[ 2877.272] (II) event0 - gpio-keys: device removed
[ 2877.272] (**) Option "config_info" "udev:/sys/devices/platform/gpio-keys/input/input0/event0"
[ 2877.272] (II) XINPUT: Adding extended input device "gpio-keys" (type: KEYBOARD, id 10)
[ 2877.272] (**) Option "xkb_model" "pc105"
[ 2877.272] (**) Option "xkb_layout" "fr"
[ 2877.272] (**) Option "xkb_variant" "latin9"
[ 2877.273] (II) event0 - gpio-keys: is tagged by udev as: Keyboard
[ 2877.273] (II) event0 - gpio-keys: device is a keyboard
[ 2877.274] (II) config/udev: Adding input device NVIDIA Jetson AGX Orin APE Headset Jack (/dev/input/event5)
[ 2877.274] (**) NVIDIA Jetson AGX Orin APE Headset Jack: Applying InputClass "libinput keyboard catchall"
[ 2877.274] (II) Using input driver 'libinput' for 'NVIDIA Jetson AGX Orin APE Headset Jack'
[ 2877.275] (II) systemd-logind: got fd for /dev/input/event5 13:69 fd 46 paused 0
[ 2877.275] (**) NVIDIA Jetson AGX Orin APE Headset Jack: always reports core events
[ 2877.275] (**) Option "Device" "/dev/input/event5"
[ 2877.277] (II) event5 - NVIDIA Jetson AGX Orin APE Headset Jack: is tagged by udev as: Keyboard Switch
[ 2877.277] (II) event5 - NVIDIA Jetson AGX Orin APE Headset Jack: device is a keyboard
[ 2877.277] (II) event5 - NVIDIA Jetson AGX Orin APE Headset Jack: device removed
[ 2877.277] (**) Option "config_info" "udev:/sys/devices/platform/sound/sound/card1/input5/event5"
[ 2877.277] (II) XINPUT: Adding extended input device "NVIDIA Jetson AGX Orin APE Headset Jack" (type: KEYBOARD, id 11)
[ 2877.277] (**) Option "xkb_model" "pc105"
[ 2877.277] (**) Option "xkb_layout" "fr"
[ 2877.277] (**) Option "xkb_variant" "latin9"
[ 2877.278] (II) event5 - NVIDIA Jetson AGX Orin APE Headset Jack: is tagged by udev as: Keyboard Switch
[ 2877.278] (II) event5 - NVIDIA Jetson AGX Orin APE Headset Jack: device is a keyboard
[ 2877.287] (**) Dell KB216 Wired Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 2877.287] (II) Using input driver 'libinput' for 'Dell KB216 Wired Keyboard Consumer Control'
[ 2877.287] (II) systemd-logind: returning pre-existing fd for /dev/input/event7 13:71
[ 2877.287] (**) Dell KB216 Wired Keyboard Consumer Control: always reports core events
[ 2877.287] (**) Option "Device" "/dev/input/event7"
[ 2877.287] (II) libinput: Dell KB216 Wired Keyboard Consumer Control: is a virtual subdevice
[ 2877.287] (**) Option "config_info" "udev:/sys/devices/platform/bus@0/3610000.usb/usb1/1-4/1-4.1/1-4.1:1.1/0003:413C:2113.0002/input/input7/event7"
[ 2877.288] (II) XINPUT: Adding extended input device "Dell KB216 Wired Keyboard Consumer Control" (type: KEYBOARD, id 12)
[ 2877.288] (**) Option "xkb_model" "pc105"
[ 2877.288] (**) Option "xkb_layout" "fr"
[ 2877.288] (**) Option "xkb_variant" "latin9"
[ 2877.544] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 2877.544] (--) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[ 2877.544] (--) NVIDIA(GPU-0): DFP-0: 2380.0 MHz maximum pixel clock
[ 2877.555] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 2877.555] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 2877.555] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
And i use a display to vdi adapter for the monitor
[ 2877.544] (–) NVIDIA(GPU-0): DFP-0: disconnected
[ 2877.544] (–) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[ 2877.544] (–) NVIDIA(GPU-0): DFP-0: 2380.0 MHz maximum pixel clock
[ 2877.555] (–) NVIDIA(GPU-0): DFP-1: disconnected
[ 2877.555] (–) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 2877.555] (–) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
The log said it does not detect your cable connection at all. Do you have native DP monitor to use?
no maybe hdmi but no DP
