Good day, I am encountering an issue with one of my two Jetson AGX Orin 64GB Developer Kit. It had been running fine displaying on the console over the DP (Display Port) connection, but recently it stopped displaying. I have tried connecting USB-C-to-HDMI and USB-C-to-DP and neither seem to work. When I look at: /var/log/Xorg.0.log I see:
[ 19.074] Kernel command line: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 console=ttyAMA0,115200 console=tty0 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0 nospectre_bhb nv-auto-config
[ 19.074] Build Date: 29 January 2024 12:44:21PM
[ 19.074] xorg-server 2:1.20.13-1ubuntu1~20.04.15 (For technical support please see http://www.ubuntu.com/support)
[ 19.074] Current version of pixman: 0.38.4
[ 19.074] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 19.074] Markers: (–) probed, () from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 19.074] (==) Log file: “/var/log/Xorg.0.log”, Time: Mon Apr 15 11:04:40 2024
[ 19.078] (==) Using config directory: “/etc/X11/xorg.conf.d”
[ 19.078] (==) Using system config directory “/usr/share/X11/xorg.conf.d”
[ 19.080] (==) No Layout section. Using the first Screen section.
[ 19.080] (==) No screen section available. Using defaults.
[ 19.080] () |–>Screen “Default Screen Section” (0)
[ 19.080] (**) | |–>Monitor “”
[ 19.081] (==) No monitor specified for screen “Default Screen Section”.
Using a default monitor configuration.
[ 19.081] (==) Automatically adding devices
[ 19.081] (==) Automatically enabling devices
[ 19.081] (==) Automatically adding GPU devices
[ 19.081] (==) Automatically binding GPU devices
[ 19.081] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 19.085] (WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
[ 19.085] Entry deleted from font path.
[ 19.085] (WW) The directory “/usr/share/fonts/X11/100dpi/” does not exist.
[ 19.085] (WW) The directory “/usr/share/fonts/X11/75dpi/” does not exist.
[ 19.086] (WW) The directory “/usr/share/fonts/X11/100dpi” does not exist.
[ 19.086] Entry deleted from font path.
[ 19.086] (WW) The directory “/usr/share/fonts/X11/75dpi” does not exist.
[ 19.086] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
[ 19.086] (==) ModulePath set to “/usr/lib/xorg/modules”
[ 19.086] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 19.086] (II) Loader magic: 0xaaaad36ca010
[ 19.086] (II) Module ABI versions:
[ 19.086] X.Org ANSI C Emulation: 0.4
[ 19.086] X.Org Video Driver: 24.1
[ 19.086] X.Org XInput driver : 24.1
[ 19.086] X.Org Server Extension : 10.0
[ 19.095] (++) using VT number 1
[ 19.100] (II) systemd-logind: took control of session /org/freedesktop/login1/session/c1
[ 19.101] (II) no primary bus or device found
[ 19.101] (II) LoadModule: “glx”
[ 19.102] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 19.113] (II) Module glx: vendor=“X.Org Foundation”
[ 19.113] compiled for 1.20.13, module version = 1.0.0
[ 19.113] ABI class: X.Org Server Extension, version 10.0
[ 19.113] (==) Matched modesetting as autoconfigured driver 0
[ 19.113] (==) Matched fbdev as autoconfigured driver 1
[ 19.113] (==) Assigned the driver to the xf86ConfigLayout
[ 19.113] (II) LoadModule: “modesetting”
[ 19.114] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 19.115] (II) Module modesetting: vendor=“X.Org Foundation”
[ 19.115] compiled for 1.20.13, module version = 1.20.13
[ 19.115] Module class: X.Org Video Driver
[ 19.115] ABI class: X.Org Video Driver, version 24.1
[ 19.115] (II) LoadModule: “fbdev”
[ 19.115] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 19.116] (II) Module fbdev: vendor=“X.Org Foundation”
[ 19.116] compiled for 1.20.1, module version = 0.5.0
[ 19.116] Module class: X.Org Video Driver
[ 19.116] ABI class: X.Org Video Driver, version 24.0
[ 19.116] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 19.116] (II) FBDEV: driver for framebuffer: fbdev
[ 19.116] (WW) Falling back to old probe method for modesetting
[ 19.116] (EE) open /dev/dri/card0: No such file or directory
[ 19.116] (WW) Falling back to old probe method for fbdev
[ 19.116] (II) Loading sub module “fbdevhw”
[ 19.116] (II) LoadModule: “fbdevhw”
[ 19.116] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 19.117] (II) Module fbdevhw: vendor=“X.Org Foundation”
[ 19.117] compiled for 1.20.13, module version = 0.0.2
[ 19.117] ABI class: X.Org Video Driver, version 24.1
[ 19.117] (EE) open /dev/fb0: No such file or directory
[ 19.117] (WW) Falling back to old probe method for modesetting
[ 19.117] (EE) open /dev/dri/card0: No such file or directory
[ 19.117] (WW) Falling back to old probe method for fbdev
[ 19.117] (II) Loading sub module “fbdevhw”
[ 19.117] (II) LoadModule: “fbdevhw”
[ 19.117] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 19.118] (II) Module fbdevhw: vendor=“X.Org Foundation”
[ 19.118] compiled for 1.20.13, module version = 0.0.2
[ 19.118] ABI class: X.Org Video Driver, version 24.1
[ 19.118] (EE) open /dev/fb0: No such file or directory
[ 19.118] (EE) No devices detected.
[ 19.118] (==) Matched modesetting as autoconfigured driver 0
[ 19.118] (==) Matched fbdev as autoconfigured driver 1
[ 19.118] (==) Assigned the driver to the xf86ConfigLayout
[ 19.118] (II) LoadModule: “modesetting”
[ 19.118] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 19.118] (II) Module modesetting: vendor=“X.Org Foundation”
[ 19.118] compiled for 1.20.13, module version = 1.20.13
[ 19.118] Module class: X.Org Video Driver
[ 19.118] (II) UnloadModule: “modesetting”
[ 19.118] (II) Unloading modesetting
[ 19.118] (II) Failed to load module “modesetting” (already loaded, 0)
[ 19.118] (II) LoadModule: “fbdev”
[ 19.118] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 19.118] (II) Module fbdev: vendor=“X.Org Foundation”
[ 19.118] compiled for 1.20.1, module version = 0.5.0
[ 19.118] ABI class: X.Org Video Driver, version 24.0
[ 19.118] (II) UnloadModule: “fbdev”
[ 19.118] (II) Unloading fbdev
[ 19.118] (II) Failed to load module “fbdev” (already loaded, 0)
[ 19.118] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 19.118] (II) FBDEV: driver for framebuffer: fbdev
[ 19.118] (WW) Falling back to old probe method for modesetting
[ 19.118] (EE) open /dev/dri/card0: No such file or directory
[ 19.118] (WW) Falling back to old probe method for fbdev
[ 19.118] (II) Loading sub module “fbdevhw”
[ 19.118] (II) LoadModule: “fbdevhw”
[ 19.119] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 19.119] (II) Module fbdevhw: vendor=“X.Org Foundation”
[ 19.119] compiled for 1.20.13, module version = 0.0.2
[ 19.119] ABI class: X.Org Video Driver, version 24.1
[ 19.119] (EE) open /dev/fb0: No such file or directory
[ 19.119] (WW) Falling back to old probe method for modesetting
[ 19.119] (EE) open /dev/dri/card0: No such file or directory
[ 19.119] (WW) Falling back to old probe method for fbdev
[ 19.119] (II) Loading sub module “fbdevhw”
[ 19.119] (II) LoadModule: “fbdevhw”
[ 19.119] (EE) No devices detected.
[ 19.119] (EE)
Fatal server error:
[ 19.119] (EE) no screens found(EE)
[ 19.119] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 19.119] (EE) Please also check the log file at “/var/log/Xorg.0.log” for additional information.
[ 19.119] (EE)
[ 19.120] (EE) Server terminated with error (1). Closing log file.
So it looks like it is not detecting the DP connection, but I am not sure why or how to re-enable it. Flashing the device is not really an option as we are in mid-development of a solution we are working on. I can SSH and xRDP to the machine without any issue.
Any suggestions would be appreciated.
Thanks,
Greg
