Hi I when i restarted my system i got the following error and the screen gets stuck at this position only:
The current input timing is not supported by the monitor display.Please change your input timing to 1920x1200@60Hz or any other monitor listed timing as per monitor specification.
Normally i do get this but within secs it boots to the login page but this time it is stuck completely.
Thank you
Which jetapck release is in use?
Is this NV devkit or custom board?
Jetpack 5.1.2
AGX Orin 64GB devkit
What kind of monitor is in use ?
… No I mean whether it is HDMI or DP and what brand name and model ID is that monitor…
Could you use serial console to access your board and attach the /var/log/Xorg.0.log as file?
link:
It looks like you install something that breaks the xorg setting so that it tries to use non-nvidia related driver.
It could be hard to find out where goes wrong. Maybe try to reflash the board.
we tried to install nvidia-smi instead of Jetson-stats .
Is there any way that we could bring it back instead of complete reflash as it has lot of data in it?
