The operating system cannot show on the screen but can access system through Micro-USB
when i switch on the device, the screen show black with the information:
The current input timing is not supported by the monitor display.Please change your input timing to 1920x1080, 60Hz or any other monitor listed timing as per the monitor specifications.
Are you using NV devkit as carrier board or you are using a custom board?
Or you are not sure what does this question mean?
I think it is a NVIDIA AGX Orin 64, rather that NVIDIA AGX Orin 64 developer kit. Because I used the sdkmanager, I selected AGX Orin 64 it went well. But error occurred when I selected developer kit.
But I saw it written JETSON AGX ORIN DEVELOPER KIT on the package box
I don’t actually understand what does that mean Orin AGX 64 instead of Orin AGX 64 developer kit…
Developer kit is the base board. The 64 or 32 in the name indicating the DRAM size on the module.
Orin AGX 64GB will have 64GB DRAM.
Orin AGX devkit will have 32GB DRAM
Both of the module can mounted on the devloper kit board.
Make sure what is the product you are using first,
Also, is the monitor in use a pure DP monitor or you are using some kind of adapters there?
Then I am using AGX ORIN 64 GB.
And I use DP monitor. Adaptor is not used.
please use the serial console and share out the /var/log/Xorg.0.log and dmesg.
You can use etherent to send out the file. We don’t want to see you posting a screenshot.
Ok I’ LL try. Thanks.
