I am facing display issues with my Jetson Orin 64GB dev kit. There is currently a black screen after the Orin boots up. I am sure the Orin has booted up since I can ssh into the machine and login to Ubuntu. I am also sure its not a display/cable issue as I can use the same cable and monitor setup on other Orins and it works perfectly. This is the second Orin I am facing this exact issue with. I know re-flashing the device resolves the issue, but this is not a permanent solution.
On running the cat /etc/nv_tegra_release command on the Orin I get the following:
R35 (release), REVISION: 1.0, GCID: 31346300, BOARD: t186ref, EABI: aarch64, DATE: Thu Aug 25 18:41:45 UTC 2022
Looking for a permanent and quick resolution to this issue.
