Hello everyone,
Following an apt upgrade on Jetson Orin (today), the screen is permanently black after booting .
The board is still accessible via ssh .
The solutions found in the forum did not work:
Our specs :
Thank you in advance.
Hello @DaveYYY ,
We use a Jetson AGX Orin 64GB Developer Kit .
Please first try re-flashing the device.
We are currently starting the re-flash process in one of our boards.
However, our goal is to prevent doing this on all devices.
Do you have another suggestion to try in parallel?
I cannot tell since I don’t even know what packages you updated.
Please refer to the print screen shared in the first message.
Give text log, bro. Screenshots are not preferred.
I don’t think you can recover from this.
Maybe check the status of display drivers sudo lsmod | grep nvidia, and also Xorg log.
Are you able to do sudo modprobe nvidia?
Apparently all of your display drivers are gone.
Hello @DaveYYY ,
sudo modprobe nvidia returns “modprobe : ERROR could not insert ‘nvidia’: Invalid argument”
Then please re-flash your device.
I don’t think you can recover from it when even the driver is broken.
system
Closed
June 19, 2024, 3:19am
15
