Jetson AGX ORIN - Blank Display
I managed to successfully flash a Brand new AGX ORIN using SDK manager from a Host PC using Ubuntu 20.04 but was still getting a blank display on my HDMI screen. I have tried display port to HDMI active adapter but till no go.
I followed the steps on
I tried re-flashing but ORIN does not show up on the host computer. It says no hardware connected on the SDK manager.
I also tried dmesg | grep --color ‘tty’ but no serial devices showing up.
Please help, i am a newbie
Hi user100392,
You can refer to the following link for the instruction of installing Jetson with SDK Manager
Install Jetson Software with SDK Manager :: NVIDIA SDK Manager Documentation
Are you using the development kit or custom board?
In addition, UART console log could be captured by Micro-USB port.
Thanks, I am using the development kit.
You also could try to connect to another DP display.
(w/o adapter transfer from DP to HDMI)
Ok sure, will try and update. But why would the ORIN development kit not show up or get detected on the host computer.
If you are talking about type C cannot show you the Orin board, please refer to this post.
This solved the issue… Thanks
