The relevant log record is as follows. Here, Microstep MSI MP242 is the problematic monitor and AUS VG279QL1A is the working monitor.
[ 23.436] (–) Log file renamed from “/var/log/Xorg.pid-2013.log” to “/var/log/Xorg.0.log”
[ 23.437]
X.Org X Server 1.20.13
X Protocol Version 11, Revision 0
[ 23.437] Build Operating System: linux Ubuntu
[ 23.437] Current Operating System: Linux ubuntu 5.10.65-tegra #1 SMP PREEMPT Mon May 16 20:58:07 PDT 2022 aarch64
[ 23.437] Kernel command line: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 console=tty0 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0 nv-auto-config
[ 23.437] Build Date: 14 December 2021 02:14:13PM
[ 23.437] xorg-server 2:1.20.13-1ubuntu1~20.04.2 (For technical support please see Enterprise open source support | Ubuntu)
[ 23.437] Current version of pixman: 0.38.4
[ 23.437] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 23.437] Markers: (–) probed, () from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 23.437] (==) Log file: “/var/log/Xorg.0.log”, Time: Fri Jul 1 19:07:36 2022
[ 23.440] (==) Using config file: “/etc/X11/xorg.conf”
[ 23.440] (==) Using config directory: “/etc/X11/xorg.conf.d”
[ 23.440] (==) Using system config directory “/usr/share/X11/xorg.conf.d”
[ 23.443] (==) No Layout section. Using the first Screen section.
[ 23.443] (==) No screen section available. Using defaults.
[ 23.443] () |–>Screen “Default Screen Section” (0)
[ 23.443] () | |–>Monitor “”
[ 23.443] (==) No device specified for screen “Default Screen Section”.
Using the first device section listed.
[ 23.443] () | |–>Device “Tegra0”
[ 23.443] (==) No monitor specified for screen “Default Screen Section”.
Using a default monitor configuration.
[ 23.443] (==) Automatically adding devices
[ 23.443] (==) Automatically enabling devices
[ 23.443] (==) Automatically adding GPU devices
[ 23.443] (==) Automatically binding GPU devices
[ 23.443] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 23.446] (WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
[ 23.446] Entry deleted from font path.
[ 23.446] (WW) The directory “/usr/share/fonts/X11/100dpi/” does not exist.
[ 23.446] (WW) The directory “/usr/share/fonts/X11/75dpi/” does not exist.
[ 23.446] (WW) The directory “/usr/share/fonts/X11/100dpi” does not exist.
[ 23.446] (WW) The directory “/usr/share/fonts/X11/75dpi” does not exist.
[ 23.446] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
[ 23.446] (==) ModulePath set to “/usr/lib/xorg/modules”
[ 23.446] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 23.446] (II) Loader magic: 0xaaaaab70c010
[ 23.446] (II) Module ABI versions:
[ 23.446] X.Org ANSI C Emulation: 0.4
[ 23.446] X.Org Video Driver: 24.1
[ 23.446] X.Org XInput driver : 24.1
[ 23.446] X.Org Server Extension : 10.0
[ 23.447] (++) using VT number 2
[ 23.448] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_31
[ 23.449] (II) no primary bus or device found
[ 23.449] (WW) “dri” will not be loaded unless you’ve specified it to be loaded elsewhere.
[ 23.449] (II) “glx” will be loaded by default.
[ 23.449] (II) LoadModule: “extmod”
[ 23.449] (II) Module “extmod” already built-in
[ 23.449] (II) LoadModule: “glx”
[ 23.450] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 23.460] (II) Module glx: vendor=“X.Org Foundation”
[ 23.460] compiled for 1.20.13, module version = 1.0.0
[ 23.460] ABI class: X.Org Server Extension, version 10.0
[ 23.460] (II) LoadModule: “nvidia”
[ 23.461] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 23.479] (II) Module nvidia: vendor=“NVIDIA Corporation”
[ 23.479] compiled for 1.6.99.901, module version = 1.0.0
[ 23.480] Module class: X.Org Video Driver
[ 23.480] (II) NVIDIA dlloader X Driver 34.1.1 Release Build (bugfix_main) (buildbrain@mobile-u64-5414-d7000) Mon May 16 21:05:42 PDT 2022
[ 23.481] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 23.481] (WW) Falling back to old probe method for NVIDIA
[ 23.481] (II) Loading sub module “fb”
[ 23.481] (II) LoadModule: “fb”
[ 23.481] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 23.482] (II) Module fb: vendor=“X.Org Foundation”
[ 23.482] compiled for 1.20.13, module version = 1.0.0
[ 23.482] ABI class: X.Org ANSI C Emulation, version 0.4
[ 23.482] (II) Loading sub module “wfb”
[ 23.482] (II) LoadModule: “wfb”
[ 23.482] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 23.484] (II) Module wfb: vendor=“X.Org Foundation”
[ 23.484] compiled for 1.20.13, module version = 1.0.0
[ 23.484] ABI class: X.Org ANSI C Emulation, version 0.4
[ 23.484] (II) Loading sub module “ramdac”
[ 23.484] (II) LoadModule: “ramdac”
[ 23.484] (II) Module “ramdac” already built-in
[ 23.487] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[ 23.487] (II) NVIDIA(0): Creating default Display subsection in Screen section
“Default Screen Section” for depth/fbbpp 24/32
[ 23.488] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[ 23.488] (==) NVIDIA(0): RGB weight 888
[ 23.488] (==) NVIDIA(0): Default visual is TrueColor
[ 23.488] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 23.488] (DB) xf86MergeOutputClassOptions unsupported bus type 0
[ 23.488] () NVIDIA(0): Option “AllowEmptyInitialConfiguration” “true”
[ 23.488] () NVIDIA(0): Enabling 2D acceleration
[ 23.488] (II) Loading sub module “glxserver_nvidia”
[ 23.488] (II) LoadModule: “glxserver_nvidia”
[ 23.488] (II) Loading /usr/lib/xorg/modules/extensions/libglxserver_nvidia.so
[ 23.627] (II) Module glxserver_nvidia: vendor=“NVIDIA Corporation”
[ 23.627] compiled for 1.6.99.901, module version = 1.0.0
[ 23.627] Module class: X.Org Server Extension
[ 23.627] (II) NVIDIA GLX Module 34.1.1 Release Build (bugfix_main) (buildbrain@mobile-u64-5414-d7000) Mon May 16 21:02:35 PDT 2022
[ 23.628] (II) NVIDIA: The X server supports PRIME Render Offload.
[ 24.481] (–) NVIDIA(0): Valid display device(s) on GPU-0 at SoC
[ 24.482] (–) NVIDIA(0): DFP-0
[ 24.482] (–) NVIDIA(0): DFP-1
[ 24.482] (WW) NVIDIA: No DRM device: No direct render devices found.
[ 24.482] (II) NVIDIA(0): NVIDIA GPU Orin (nvgpu) (GA10B) at SoC (GPU-0)
[ 24.483] (–) NVIDIA(0): Memory: 31357604 kBytes
[ 24.483] (–) NVIDIA(0): VideoBIOS:
[ 24.483] (–) NVIDIA(GPU-0): DFP-0: disconnected
[ 24.483] (–) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[ 24.483] (–) NVIDIA(GPU-0): DFP-0: 2380.0 MHz maximum pixel clock
[ 24.578] (–) NVIDIA(GPU-0): Microstep MSI MP242 (DFP-1): connected
[ 24.578] (–) NVIDIA(GPU-0): Microstep MSI MP242 (DFP-1): Internal TMDS
[ 24.578] (–) NVIDIA(GPU-0): Microstep MSI MP242 (DFP-1): 165.0 MHz maximum pixel clock
[ 24.622] (==) NVIDIA(0):
[ 24.622] (==) NVIDIA(0): No modes were requested; the default mode “nvidia-auto-select”
[ 24.622] (==) NVIDIA(0): will be used as the requested mode.
[ 24.626] (II) NVIDIA(0): Validated MetaModes:
[ 24.626] (II) NVIDIA(0): “DFP-1:nvidia-auto-select”
[ 24.626] (II) NVIDIA(0): Virtual screen size determined to be 1920 x 1080
[ 24.730] (–) NVIDIA(0): DPI set to (92, 91); computed from “UseEdidDpi” X config
[ 24.730] (–) NVIDIA(0): option
[ 24.730] (II) NVIDIA: Reserving 24576.00 MB of virtual memory for indirect memory
[ 24.730] (II) NVIDIA: access.
[ 24.730] (WW) NVIDIA(GPU-0): Failed to enter interactive mode.
[ 24.741] (EE) NVIDIA(0): Failed to allocate NVIDIA Error Handler
[ 24.741] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 24.741] (II) NVIDIA(0): may not be running or the “AcpidSocketPath” X
[ 24.741] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 24.741] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 24.741] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 24.741] (II) NVIDIA(0): details, please see the “ConnectToAcpid” and
[ 24.741] (II) NVIDIA(0): “AcpidSocketPath” X configuration options in Appendix B: X
[ 24.741] (II) NVIDIA(0): Config Options in the README.
[ 24.770] (II) NVIDIA(0): Setting mode “DFP-1:nvidia-auto-select”
[ 24.916] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 24.916] (==) NVIDIA(0): Backing store enabled
[ 24.916] (==) NVIDIA(0): Silken mouse enabled
[ 24.916] (==) NVIDIA(0): DPMS enabled
[ 24.916] (II) Loading sub module “dri2”
[ 24.916] (II) LoadModule: “dri2”
[ 24.916] (II) Module “dri2” already built-in
[ 24.916] (II) NVIDIA(0): [DRI2] Setup complete
[ 24.916] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 24.917] (II) Initializing extension Generic Event Extension
[ 24.917] (II) Initializing extension SHAPE
[ 24.917] (II) Initializing extension MIT-SHM
[ 24.917] (II) Initializing extension XInputExtension
[ 24.918] (II) Initializing extension XTEST
[ 24.918] (II) Initializing extension BIG-REQUESTS
[ 24.918] (II) Initializing extension SYNC
[ 24.918] (II) Initializing extension XKEYBOARD
[ 24.919] (II) Initializing extension XC-MISC
[ 24.919] (II) Initializing extension SECURITY
[ 24.919] (II) Initializing extension XFIXES
[ 24.919] (II) Initializing extension RENDER
[ 24.920] (II) Initializing extension RANDR
[ 24.920] (II) Initializing extension COMPOSITE
[ 24.920] (II) Initializing extension DAMAGE
[ 24.920] (II) Initializing extension MIT-SCREEN-SAVER
[ 24.920] (II) Initializing extension DOUBLE-BUFFER
[ 24.920] (II) Initializing extension RECORD
[ 24.920] (II) Initializing extension DPMS
[ 24.921] (II) Initializing extension Present
[ 24.921] (II) Initializing extension DRI3
[ 24.921] (II) Initializing extension X-Resource
[ 24.921] (II) Initializing extension XVideo
[ 24.921] (II) Initializing extension XVideo-MotionCompensation
[ 24.921] (II) Initializing extension SELinux
[ 24.921] (II) SELinux: Disabled on system
[ 24.921] (II) Initializing extension GLX
[ 24.921] (II) Indirect GLX disabled.
[ 24.921] (II) GLX: Another vendor is already registered for screen 0
[ 24.921] (II) Initializing extension XFree86-VidModeExtension
[ 24.921] (II) Initializing extension XFree86-DGA
[ 24.922] (II) Initializing extension XFree86-DRI
[ 24.922] (II) Initializing extension DRI2
[ 24.922] (II) Initializing extension NV-GLX
[ 24.922] (II) Initializing extension NV-CONTROL
[ 24.922] (II) Initializing extension XINERAMA
[ 25.013] (II) config/udev: Adding input device NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=3 (/dev/input/event5)
[ 25.013] (II) No input driver specified, ignoring this device.
[ 25.013] (II) This device may have been added with another device file.
[ 25.014] (II) config/udev: Adding input device NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=7 (/dev/input/event6)
[ 25.014] (II) No input driver specified, ignoring this device.
[ 25.014] (II) This device may have been added with another device file.
[ 25.014] (II) config/udev: Adding input device NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=8 (/dev/input/event7)
[ 25.015] (II) No input driver specified, ignoring this device.
[ 25.015] (II) This device may have been added with another device file.
[ 25.015] (II) config/udev: Adding input device NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=9 (/dev/input/event8)
[ 25.016] (II) config/udev: Adding input device Logitech Wireless Mouse (/dev/input/event0)
[ 25.017] () Logitech Wireless Mouse: Applying InputClass “libinput pointer catchall”
[ 25.017] (II) LoadModule: “libinput”
[ 25.055] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 25.063] (II) Module libinput: vendor=“X.Org Foundation”
[ 25.063] compiled for 1.20.4, module version = 0.29.0
[ 25.063] Module class: X.Org XInput Driver
[ 25.063] ABI class: X.Org XInput driver, version 24.1
[ 25.063] (II) Using input driver ‘libinput’ for ‘Logitech Wireless Mouse’
[ 25.064] (II) systemd-logind: got fd for /dev/input/event0 13:64 fd 31 paused 0
[ 25.064] () Logitech Wireless Mouse: always reports core events
[ 25.064] () Option “Device” “/dev/input/event0”
[ 25.065] () Option “_source” “server/udev”
[ 25.081] (II) event0 - Logitech Wireless Mouse: is tagged by udev as: Mouse
[ 25.081] (II) event0 - Logitech Wireless Mouse: device is a pointer
[ 25.081] (II) event0 - Logitech Wireless Mouse: device removed
[ 25.081] () Option “config_info” “udev:/sys/devices/platform/3610000.xhci/usb1/1-4/1-4.2/1-4.2:1.2/0003:046D:C52B.0003/0003:046D:4055.0004/input/input20/event0”
[ 25.081] (II) XINPUT: Adding extended input device “Logitech Wireless Mouse” (type: MOUSE, id 6)
[ 25.082] () Option “AccelerationScheme” “none”
[ 25.082] () Logitech Wireless Mouse: (accel) selected scheme none/0
[ 25.082] () Logitech Wireless Mouse: (accel) acceleration factor: 2.000
[ 25.082] () Logitech Wireless Mouse: (accel) acceleration threshold: 4
[ 25.083] (II) event0 - Logitech Wireless Mouse: is tagged by udev as: Mouse
[ 25.083] (II) event0 - Logitech Wireless Mouse: device is a pointer
[ 25.084] (II) config/udev: Adding input device Logitech Wireless Mouse (/dev/input/mouse0)
[ 25.084] (II) No input driver specified, ignoring this device.
[ 25.084] (II) This device may have been added with another device file.
[ 25.085] (II) config/udev: Adding input device Logitech K540/K545 (/dev/input/event1)
[ 25.085] () Logitech K540/K545: Applying InputClass “libinput keyboard catchall”
[ 25.085] (II) Using input driver ‘libinput’ for ‘Logitech K540/K545’
[ 25.086] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 34 paused 0
[ 25.086] () Logitech K540/K545: always reports core events
[ 25.086] () Option “Device” “/dev/input/event1”
[ 25.086] () Option “_source” “server/udev”
[ 25.090] (II) event1 - Logitech K540/K545: is tagged by udev as: Keyboard
[ 25.090] (II) event1 - Logitech K540/K545: device is a keyboard
[ 25.090] (II) event1 - Logitech K540/K545: device removed
[ 25.090] (II) libinput: Logitech K540/K545: needs a virtual subdevice
[ 25.090] () Option “config_info” “udev:/sys/devices/platform/3610000.xhci/usb1/1-4/1-4.2/1-4.2:1.2/0003:046D:C52B.0003/0003:046D:4076.0005/input/input21/event1”
[ 25.091] (II) XINPUT: Adding extended input device “Logitech K540/K545” (type: MOUSE, id 7)
[ 25.091] () Option “AccelerationScheme” “none”
[ 25.091] () Logitech K540/K545: (accel) selected scheme none/0
[ 25.091] () Logitech K540/K545: (accel) acceleration factor: 2.000
[ 25.091] () Logitech K540/K545: (accel) acceleration threshold: 4
[ 25.094] (II) event1 - Logitech K540/K545: is tagged by udev as: Keyboard
[ 25.094] (II) event1 - Logitech K540/K545: device is a keyboard
[ 25.095] (II) config/udev: Adding input device gpio-keys (/dev/input/event4)
[ 25.095] () gpio-keys: Applying InputClass “libinput keyboard catchall”
[ 25.095] (II) Using input driver ‘libinput’ for ‘gpio-keys’
[ 25.096] (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 35 paused 0
[ 25.096] () gpio-keys: always reports core events
[ 25.096] () Option “Device” “/dev/input/event4”
[ 25.096] () Option “_source” “server/udev”
[ 25.097] (II) event4 - gpio-keys: is tagged by udev as: Keyboard
[ 25.097] (II) event4 - gpio-keys: device is a keyboard
[ 25.098] (II) event4 - gpio-keys: device removed
[ 25.098] () Option “config_info” “udev:/sys/devices/platform/gpio-keys/input/input5/event4”
[ 25.098] (II) XINPUT: Adding extended input device “gpio-keys” (type: KEYBOARD, id 8)
[ 25.098] () Option “xkb_model” “pc105”
[ 25.098] () Option “xkb_layout” “tr,us”
[ 25.098] () Option “xkb_options” “grp_led:scroll”
[ 25.130] (II) event4 - gpio-keys: is tagged by udev as: Keyboard
[ 25.130] (II) event4 - gpio-keys: device is a keyboard
[ 25.140] () Logitech K540/K545: Applying InputClass “libinput keyboard catchall”
[ 25.140] (II) Using input driver ‘libinput’ for ‘Logitech K540/K545’
[ 25.140] (II) systemd-logind: returning pre-existing fd for /dev/input/event1 13:65
[ 25.141] () Logitech K540/K545: always reports core events
[ 25.141] () Option “Device” “/dev/input/event1”
[ 25.141] () Option “_source” “_driver/libinput”
[ 25.141] (II) libinput: Logitech K540/K545: is a virtual subdevice
[ 25.141] () Option “config_info” “udev:/sys/devices/platform/3610000.xhci/usb1/1-4/1-4.2/1-4.2:1.2/0003:046D:C52B.0003/0003:046D:4076.0005/input/input21/event1”
[ 25.141] (II) XINPUT: Adding extended input device “Logitech K540/K545” (type: KEYBOARD, id 9)
[ 25.141] () Option “xkb_model” “pc105”
[ 25.141] () Option “xkb_layout” “tr,us”
[ 25.141] () Option “xkb_options” “grp_led:scroll”
[ 26.060] (–) NVIDIA(GPU-0): DFP-0: disconnected
[ 26.061] (–) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[ 26.061] (–) NVIDIA(GPU-0): DFP-0: 2380.0 MHz maximum pixel clock
[ 26.074] (–) NVIDIA(GPU-0): DFP-1: disconnected
[ 26.074] (–) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 26.074] (–) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 28.029] (–) NVIDIA(GPU-0): DFP-0: disconnected
[ 28.029] (–) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[ 28.029] (–) NVIDIA(GPU-0): DFP-0: 2380.0 MHz maximum pixel clock
[ 28.044] (–) NVIDIA(GPU-0): DFP-1: disconnected
[ 28.044] (–) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 28.044] (–) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 28.047] (II) NVIDIA(0): Setting mode “NULL”
[ 28.136] (–) NVIDIA(GPU-0): DFP-0: disconnected
[ 28.136] (–) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[ 28.136] (–) NVIDIA(GPU-0): DFP-0: 2380.0 MHz maximum pixel clock
[ 28.152] (–) NVIDIA(GPU-0): DFP-1: disconnected
[ 28.152] (–) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 28.152] (–) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 55.965] (–) NVIDIA(GPU-0): AUS VG279QL1A (DFP-1): connected
[ 55.966] (–) NVIDIA(GPU-0): AUS VG279QL1A (DFP-1): Internal TMDS
[ 55.966] (–) NVIDIA(GPU-0): AUS VG279QL1A (DFP-1): 165.0 MHz maximum pixel clock
[ 55.970] (–) NVIDIA(GPU-0): DFP-0: disconnected
[ 55.971] (–) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[ 55.971] (–) NVIDIA(GPU-0): DFP-0: 2380.0 MHz maximum pixel clock
[ 56.062] (–) NVIDIA(GPU-0): AUS VG279QL1A (DFP-1): connected
[ 56.062] (–) NVIDIA(GPU-0): AUS VG279QL1A (DFP-1): Internal TMDS
[ 56.062] (–) NVIDIA(GPU-0): AUS VG279QL1A (DFP-1): 165.0 MHz maximum pixel clock
[ 56.095] (II) NVIDIA(0): Setting mode “DP-1: nvidia-auto-select @1920x1080 +0+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}”
[ 56.409] (–) NVIDIA(GPU-0): AUS VG279QL1A (DFP-1): connected
[ 56.409] (–) NVIDIA(GPU-0): AUS VG279QL1A (DFP-1): Internal TMDS
[ 56.409] (–) NVIDIA(GPU-0): AUS VG279QL1A (DFP-1): 165.0 MHz maximum pixel clock
[ 56.503] (–) NVIDIA(GPU-0): AUS VG279QL1A (DFP-1): connected
[ 56.503] (–) NVIDIA(GPU-0): AUS VG279QL1A (DFP-1): Internal TMDS
[ 56.503] (–) NVIDIA(GPU-0): AUS VG279QL1A (DFP-1): 165.0 MHz maximum pixel clock
[ 56.522] (–) NVIDIA(GPU-0): DFP-0: disconnected
[ 56.522] (–) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[ 56.522] (–) NVIDIA(GPU-0): DFP-0: 2380.0 MHz maximum pixel clock
[ 56.613] (–) NVIDIA(GPU-0): AUS VG279QL1A (DFP-1): connected
[ 56.613] (–) NVIDIA(GPU-0): AUS VG279QL1A (DFP-1): Internal TMDS
[ 56.613] (–) NVIDIA(GPU-0): AUS VG279QL1A (DFP-1): 165.0 MHz maximum pixel clock
[ 58.043] (–) NVIDIA(GPU-0): DFP-1: connected
[ 58.044] (–) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 58.044] (–) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 58.190] (–) NVIDIA(GPU-0): AUS VG279QL1A (DFP-1): connected
[ 58.190] (–) NVIDIA(GPU-0): AUS VG279QL1A (DFP-1): Internal TMDS
[ 58.190] (–) NVIDIA(GPU-0): AUS VG279QL1A (DFP-1): 165.0 MHz maximum pixel clock
[ 64.256] (–) NVIDIA(GPU-0): DFP-0: disconnected
[ 64.256] (–) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[ 64.257] (–) NVIDIA(GPU-0): DFP-0: 2380.0 MHz maximum pixel clock
[ 64.347] (–) NVIDIA(GPU-0): AUS VG279QL1A (DFP-1): connected
[ 64.347] (–) NVIDIA(GPU-0): AUS VG279QL1A (DFP-1): Internal TMDS
[ 64.347] (–) NVIDIA(GPU-0): AUS VG279QL1A (DFP-1): 165.0 MHz maximum pixel clock
