AGX Orin devkit 5k / high-res monitor support
I’ve been trying to connect a couple of different high-resolution DisplayPort displays to the AGX Orin devkit, but it does not seem to support the highest resolution modes exposed by the displays. The module documentation states that the AGX Orin supports DisplayPort 1.4a, 4 lanes, and HBR3, which should be sufficient.
Is this a known limitation? If so, is this planned to be fixed in a future release?
Here’s the EDID of the 5k monitor that isn’t fully supported: the native mode is 5120x2880@60, DP 1.4 HBR3, no DSC. The Orin was only able to enumerate the lower-res modes (up to 3840x2160@60). This monitor works fine in the highest resolution 5120x2880@60 mode connected to the Quadro P2000 in my development host machine (Ubuntu 20.04.4, kernel 5.4.0, nvidia driver 510.73.05)
5K Monitor EDID (Decoded)
Block 0, Base EDID:
  EDID Structure Version & Revision: 1.4
  Vendor & Product Identification:
    Manufacturer: CHY
    Model: 12819
    Made in: week 15 of 2020
  Basic Display Parameters & Features:
    Digital display
    Bits per primary color channel: 10
    DisplayPort interface
    Maximum image size: 71 cm x 40 cm
    Gamma: 2.20
    DPMS levels: Off
    Supported color formats: RGB 4:4:4, YCrCb 4:4:4, YCrCb 4:2:2
    First detailed timing includes the native pixel format and preferred refresh rate
    Display is continuous frequency
  Color Characteristics:
    Red  : 0.6728, 0.3154
    Green: 0.1992, 0.7167
    Blue : 0.1484, 0.0449
    White: 0.3134, 0.3291
  Established Timings I & II:
    DMT 0x04:   640x480    59.940476 Hz   4:3     31.469 kHz     25.175000 MHz
    DMT 0x09:   800x600    60.316541 Hz   4:3     37.879 kHz     40.000000 MHz
    DMT 0x10:  1024x768    60.003840 Hz   4:3     48.363 kHz     65.000000 MHz
  Standard Timings:
    DMT 0x1c:  1280x800    59.810326 Hz  16:10    49.702 kHz     83.500000 MHz
    DMT 0x3a:  1680x1050   59.954250 Hz  16:10    65.290 kHz    146.250000 MHz
    DMT 0x45:  1920x1200   59.884600 Hz  16:10    74.556 kHz    193.250000 MHz
    DMT 0x33:  1600x1200   60.000000 Hz   4:3     75.000 kHz    162.000000 MHz
    DMT 0x23:  1280x1024   60.019740 Hz   5:4     63.981 kHz    108.000000 MHz
    DMT 0x52:  1920x1080   60.000000 Hz  16:9     67.500 kHz    148.500000 MHz
  Detailed Timing Descriptors:
    DTD 1:  3840x2160   60.001125 Hz  16:9    133.322 kHz    533.290000 MHz (595 mm x 335 mm)
                 Hfront   80 Hsync  32 Hback   48 Hpol P
                 Vfront   54 Vsync   5 Vback    3 Vpol N
    Display Product Serial Number: ''
    Display Product Name: 'DP 5K3K'
    Display Range Limits:
      Monitor ranges (Bare Limits): 48-60 Hz V, 31-180 kHz H, max dotclock 540 MHz
  Extension blocks: 2
Checksum: 0x60
Block 1, CTA-861 Extension Block:
  Revision: 3
  Underscans IT Video Formats by default
  Basic audio support
  Supports YCbCr 4:4:4
  Supports YCbCr 4:2:2
  Native detailed modes: 1
  Video Data Block:
    VIC   1:   640x480    59.940476 Hz   4:3     31.469 kHz     25.175000 MHz
    VIC   3:   720x480    59.940060 Hz  16:9     31.469 kHz     27.000000 MHz
    VIC   4:  1280x720    60.000000 Hz  16:9     45.000 kHz     74.250000 MHz
    VIC  18:   720x576    50.000000 Hz  16:9     31.250 kHz     27.000000 MHz
    VIC  19:  1280x720    50.000000 Hz  16:9     37.500 kHz     74.250000 MHz
    VIC   5:  1920x1080i  60.000000 Hz  16:9     33.750 kHz     74.250000 MHz
    VIC  20:  1920x1080i  50.000000 Hz  16:9     28.125 kHz     74.250000 MHz
    VIC  31:  1920x1080   50.000000 Hz  16:9     56.250 kHz    148.500000 MHz
    VIC  16:  1920x1080   60.000000 Hz  16:9     67.500 kHz    148.500000 MHz
    VIC   2:   720x480    59.940060 Hz   4:3     31.469 kHz     27.000000 MHz
    VIC  93:  3840x2160   24.000000 Hz  16:9     54.000 kHz    297.000000 MHz
    VIC  94:  3840x2160   25.000000 Hz  16:9     56.250 kHz    297.000000 MHz
    VIC  95:  3840x2160   30.000000 Hz  16:9     67.500 kHz    297.000000 MHz
    VIC  96:  3840x2160   50.000000 Hz  16:9    112.500 kHz    594.000000 MHz
    VIC  97:  3840x2160   60.000000 Hz  16:9    135.000 kHz    594.000000 MHz
  Audio Data Block:
    Linear PCM:
      Max channels: 2
      Supported sample rates (kHz): 48 44.1 32
      Supported sample sizes (bits): 24 20 16
  Speaker Allocation Data Block:
    FL/FR - Front Left/Right
  Vendor-Specific Data Block (AMD), OUI 00-00-1A:
    Version: 1.1
    Minimum Refresh Rate: 48 Hz
    Maximum Refresh Rate: 60 Hz
    Flags 1.x: 0x00
  Colorimetry Data Block:
    xvYCC601
    xvYCC709
    BT2020YCC
    BT2020RGB
    Reserved MD0
  YCbCr 4:2:0 Capability Map Data Block:
  HDR Static Metadata Data Block:
    Electro optical transfer functions:
      Traditional gamma - SDR luminance range
      Traditional gamma - HDR luminance range
      SMPTE ST2084
    Supported static metadata descriptors:
      Static metadata type 1
    Desired content max luminance: 97 (408.759 cd/m^2)
    Desired content max frame-average luminance: 86 (322.098 cd/m^2)
    Desired content min luminance: 28 (0.049 cd/m^2)
    DTD 2:  3840x2160   59.996625 Hz  16:9    133.312 kHz    533.250000 MHz (597 mm x 336 mm)
                 Hfront   80 Hsync  32 Hback   48 Hpol N
    DTD 3:  2560x1440   59.950550 Hz  16:9     88.787 kHz    241.500000 MHz (597 mm x 336 mm)
                 Hfront   48 Hsync  32 Hback   80 Hpol P
                 Vfront    3 Vsync   5 Vback   33 Vpol N
Checksum: 0xd6  Unused space in Extension Block: 39 bytes
Block 2, DisplayID Extension Block:
  Version: 1.2
  Extension Count: 0
  Display Product Type: Extension Section
  Video Timing Modes Type 1 - Detailed Timings Data Block:
    DTD:  5120x2880   60.388716 Hz  16:9    177.664 kHz    966.490000 MHz (aspect 16:9, no 3D stereo, preferred)
               Hfront   96 Hsync  64 Hback  160 Hpol P
               Vfront    3 Vsync   5 Vback   54 Vpol N
    DTD:  2560x2880   29.986961 Hz  16:9     87.592 kHz    238.250000 MHz (aspect 16:9, no 3D stereo)
               Vfront    3 Vsync  10 Vback   28 Vpol N
    DTD:  2560x2880   59.981580 Hz  16:9    177.665 kHz    483.250000 MHz (aspect 16:9, no 3D stereo)
               Vfront    3 Vsync  10 Vback   69 Vpol N
  Supported Timing Modes Type 1 - VESA DMT Timings Data Block:
  Checksum: 0xf4
Checksum: 0x90
5K Monitor EDID (hexdump)
00 ff ff ff ff ff ff 00 0d 19 13 32 00 00 00 00
0f 1e 01 04 b5 47 28 78 3b 72 25 ac 50 33 b7 26
0b 50 54 21 08 00 81 00 b3 00 d1 00 a9 40 81 80
d1 c0 01 01 01 01 51 d0 00 a0 f0 70 3e 80 50 20
65 0c 53 4f 21 00 00 1a 00 00 00 ff 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 fc 00 44
50 20 35 4b 33 4b 0a 20 20 20 20 20 00 00 00 fd
00 30 3c 1f b4 36 01 0a 20 20 20 20 20 20 02 60
02 03 34 f1 4f 01 03 04 12 13 05 14 1f 10 02 5d
5e 5f 60 61 23 09 07 07 83 01 00 00 68 1a 00 00
01 01 30 3c 00 e3 05 c3 01 e3 0f 00 40 e6 06 07
01 61 56 1c 4d d0 00 a0 f0 70 3e 80 50 20 65 0c
55 50 21 00 00 18 56 5e 00 a0 a0 a0 29 50 30 20
35 00 55 50 21 00 00 1a 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 d6
70 12 79 00 00 03 01 3c 88 79 01 84 ff 13 3f 01
5f 80 3f 00 3f 0b 3d 00 02 00 04 00 10 5d 00 04
ff 09 9f 00 2f 80 1f 00 3f 0b 28 00 02 00 09 00
c4 bc 00 04 ff 09 9f 00 2f 80 1f 00 3f 0b 51 00
02 00 09 00 07 00 0a 08 81 00 08 04 00 04 02 10
00 00 00 00 00 00 00 00 00 00 00 00 00 00 f4 90
I also tried a VR HMD: an HP Reverb G1, native resolution 4320x2160@90. For this display, only the lower-res 2880x1440 modes are available. Again, this device works fine in the highest resolution 4320x2160@90 mode on the Quadro P2000 in my desktop.
HP Reverb G1 EDID (Decoded)
Block 0, Base EDID:
    Manufacturer: HPN
    Model: 13870
    Serial Number: 3903855746
    Made in: week 38 of 2020
    Digital display
    Bits per primary color channel: 8
    Maximum image size: 11 cm x 5 cm
    Gamma: 2.20
    Default (sRGB) color space is primary color space
    First detailed timing does not include the native pixel format and preferred refresh rate
    Red  : 0.6396, 0.3300
    Green: 0.2998, 0.5996
    Blue : 0.1484, 0.0595
  Established Timings I & II: none
  Standard Timings:
    DTD 1:  2880x1440   89.997862 Hz   2:1    137.517 kHz    410.900000 MHz (110 mm x 50 mm)
                 Hfront   54 Hsync   2 Hback   52 Hpol P
                 Vfront   63 Vsync   2 Vback   23 Vpol P
    DTD 2:  2880x1440   59.997845 Hz   2:1     91.677 kHz    273.930000 MHz (110 mm x 50 mm)
    Unknown Display Descriptor (0x11): 00 11 00 00 00 00 00 00 00 00 00 00 00 00 00 00 '................'
  Extension blocks: 2
Checksum: 0x20
  Revision: 3
  Native detailed modes: 0
  Vendor-Specific Data Block (Microsoft), OUI CA-12-5C:
    Version: 1
    Display Product Primary Use Case: 7 (Virtual reality headset)
    Container ID: 52e7dcda-6f9a-59af-93dd-2ca74a67c3ca
Checksum: 0xab  Unused space in Extension Block: 101 bytes
  Version: 1.2
  Extension Count: 0
    DTD:  4320x2160   90.020369 Hz   1:1    209.477 kHz    949.980000 MHz (aspect 1:1, no 3D stereo, preferred)
               Hfront  109 Hsync   3 Hback  103 Hpol P
               Vfront    9 Vsync   3 Vback  155 Vpol P
    DTD:  4320x2160   60.013734 Hz   1:1    132.390 kHz    600.390000 MHz (aspect 1:1, no 3D stereo)
               Vfront   39 Vsync   3 Vback    4 Vpol P
  Checksum: 0x78
Checksum: 0x90
HP Reverb G1 EDID (hexdump)
00 ff ff ff ff ff ff 00 22 0e 2e 36 82 1c b0 e8
26 1e 01 04 a5 0b 05 78 0c ee 15 a3 54 4c 99 26
0f 50 54 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 82 a0 40 6c b0 a0 58 50 36 02
f2 0c 6e 32 00 00 00 1e 01 6b 40 6c b0 a0 58 50
36 02 f2 0c 6e 32 00 00 00 1e 00 00 00 11 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 11
00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 20
02 03 1a 00 75 5c 12 ca 01 07 52 e7 dc da 6f 9a
59 af 93 dd 2c a7 4a 67 c3 ca 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ab
70 12 79 00 00 03 00 28 15 73 01 80 df 10 d6 00
6c 80 02 00 6f 08 a6 00 08 80 02 00 86 ea 00 00
df 10 d6 00 6c 80 02 00 6f 08 2d 00 26 80 02 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 78 90
(EDID decoding was done with edid-decode.git - edid-decode main repository, built at revision cc1aeb00)
The enumerated modes are the same everywhere I’ve checked – Xorg, Wayland, a Vulkan client using VK_KHR_display for modesetting (without a windowing system), installing drm-tests and running modeprint nvidia-drm, and finally booting with the argument drm.debug=255 and watching dmesg.
dmesg output from hot plugging 5K display with drm.debug=255
[   55.117403] [drm:drm_sysfs_hotplug_event] generating hotplug event
[   55.117450] [drm:drm_helper_probe_single_connector_modes] [CONNECTOR:61:DP-1]
[   55.126472] [drm:drm_helper_probe_single_connector_modes] [CONNECTOR:61:DP-1] status updated from disconnected to connected
[   55.126542] [drm:drm_sysfs_hotplug_event] generating hotplug event
[   55.126625] [drm:drm_add_display_info] Supported Monitor Refresh rate range is 48 Hz - 60 Hz
[   55.126634] [drm:drm_add_display_info] non_desktop set to 0
[   55.126650] [drm:drm_add_display_info] DP-1: Assigning EDID-1.4 digital sink color depth as 10 bpc.
[   55.126666] [drm:drm_find_displayid_extension] base revision 0x12, length 121, 0 0
[   55.126678] [drm:drm_update_tile_info] block id 0x3, rev 1, len 60
[   55.126688] [drm:drm_update_tile_info] found DisplayID tag 0x3, unhandled
[   55.126698] [drm:drm_update_tile_info] block id 0x7, rev 0, len 10
[   55.126707] [drm:drm_update_tile_info] found DisplayID tag 0x7, unhandled
[   55.188477] [drm:drm_helper_probe_single_connector_modes] [CONNECTOR:61:DP-1] probed modes :
[   55.188484] [drm:drm_mode_debug_printmodeline] Modeline "3840x2160": 60 533290 3840 3920 3952 4000 2160 2214 2219 2222 0x8 0x9
[   55.188486] [drm:drm_mode_debug_printmodeline] Modeline "3840x2160": 60 593410 3840 4016 4104 4400 2160 2168 2178 2250 0x0 0x5
[   55.188488] [drm:drm_mode_debug_printmodeline] Modeline "3840x2160": 60 533250 3840 3920 3952 4000 2160 2214 2219 2222 0x0 0xa
[   55.188489] [drm:drm_mode_debug_printmodeline] Modeline "3840x2160": 50 594000 3840 4896 4984 5280 2160 2168 2178 2250 0x0 0x5
[   55.188491] [drm:drm_mode_debug_printmodeline] Modeline "3840x2160": 30 296700 3840 4016 4104 4400 2160 2168 2178 2250 0x0 0x5
[   55.188493] [drm:drm_mode_debug_printmodeline] Modeline "3840x2160": 25 297000 3840 4896 4984 5280 2160 2168 2178 2250 0x0 0x5
[   55.188494] [drm:drm_mode_debug_printmodeline] Modeline "3840x2160": 24 296700 3840 5116 5204 5500 2160 2168 2178 2250 0x0 0x5
[   55.188496] [drm:drm_mode_debug_printmodeline] Modeline "2560x2880": 60 483250 2560 2608 2640 2720 2880 2883 2893 2962 0x0 0x9
[   55.188498] [drm:drm_mode_debug_printmodeline] Modeline "2560x2880": 30 238250 2560 2608 2640 2720 2880 2883 2893 2921 0x0 0x9
[   55.188501] [drm:drm_mode_debug_printmodeline] Modeline "2560x1440": 60 241500 2560 2608 2640 2720 1440 1443 1448 1481 0x0 0x9
[   55.188502] [drm:drm_mode_debug_printmodeline] Modeline "1920x1200": 60 193250 1920 2056 2256 2592 1200 1203 1209 1245 0x0 0x6
[   55.188504] [drm:drm_mode_debug_printmodeline] Modeline "1920x1080": 60 148500 1920 2008 2052 2200 1080 1084 1089 1125 0x0 0x5
[   55.188505] [drm:drm_mode_debug_printmodeline] Modeline "1920x1080": 60 148350 1920 2008 2052 2200 1080 1084 1089 1125 0x0 0x5
[   55.188508] [drm:drm_mode_debug_printmodeline] Modeline "1920x1080": 50 148500 1920 2448 2492 2640 1080 1084 1089 1125 0x0 0x5
[   55.188509] [drm:drm_mode_debug_printmodeline] Modeline "1600x1200": 60 162000 1600 1664 1856 2160 1200 1201 1204 1250 0x0 0x5
[   55.188511] [drm:drm_mode_debug_printmodeline] Modeline "1680x1050": 60 146250 1680 1784 1960 2240 1050 1053 1059 1089 0x0 0x6
[   55.188512] [drm:drm_mode_debug_printmodeline] Modeline "1280x1024": 60 108000 1280 1328 1440 1688 1024 1025 1028 1066 0x0 0x5
[   55.188514] [drm:drm_mode_debug_printmodeline] Modeline "1280x800": 60 83500 1280 1352 1480 1680 800 803 809 831 0x0 0x6
[   55.188516] [drm:drm_mode_debug_printmodeline] Modeline "1280x720": 60 74180 1280 1390 1430 1650 720 725 730 750 0x0 0x5
[   55.188517] [drm:drm_mode_debug_printmodeline] Modeline "1280x720": 50 74250 1280 1720 1760 1980 720 725 730 750 0x0 0x5
[   55.188519] [drm:drm_mode_debug_printmodeline] Modeline "1024x768": 60 65000 1024 1048 1184 1344 768 771 777 806 0x0 0xa
[   55.188520] [drm:drm_mode_debug_printmodeline] Modeline "800x600": 60 40000 800 840 968 1056 600 601 605 628 0x0 0x5
[   55.188522] [drm:drm_mode_debug_printmodeline] Modeline "720x576": 50 27000 720 732 796 864 576 581 586 625 0x0 0xa
[   55.188524] [drm:drm_mode_debug_printmodeline] Modeline "720x480": 60 27000 720 736 798 858 480 489 495 525 0x0 0xa
[   55.188525] [drm:drm_mode_debug_printmodeline] Modeline "640x480": 60 25180 640 648 744 800 480 482 484 525 0x0 0xa
[   55.188527] [drm:drm_mode_debug_printmodeline] Modeline "640x480": 60 25175 640 656 752 800 480 490 492 525 0x0 0xa
[   55.188528] [drm:drm_mode_debug_printmodeline] Modeline "640x480": 60 25170 640 656 752 800 480 490 492 525 0x0 0xa
modeprint output from 5K display
$ modeprint nvidia-drm
Starting test
Resources
count_connectors : 1
count_encoders   : 2
count_crtcs      : 2
count_fbs        : 0
Connector: DP-1
	encoder id     : 0
	conn           : connected
	count_modes    : 27
	count_props    : 5
	props          : 1 2 5 6 4
	count_encoders : 2
	encoders       : 60 62
Mode: "3840x2160" 3840x2160 60
Mode: "3840x2160" 3840x2160 50
Mode: "3840x2160" 3840x2160 30
Mode: "3840x2160" 3840x2160 25
Mode: "3840x2160" 3840x2160 24
Mode: "2560x2880" 2560x2880 60
Mode: "2560x2880" 2560x2880 30
Mode: "2560x1440" 2560x1440 60
Mode: "1920x1200" 1920x1200 60
Mode: "1920x1080" 1920x1080 60
Mode: "1920x1080" 1920x1080 50
Mode: "1600x1200" 1600x1200 60
Mode: "1680x1050" 1680x1050 60
Mode: "1280x1024" 1280x1024 60
Mode: "1280x800" 1280x800 60
Mode: "1280x720" 1280x720 60
Mode: "1280x720" 1280x720 50
Mode: "1024x768" 1024x768 60
Mode: "800x600" 800x600 60
Mode: "720x576" 720x576 50
Mode: "720x480" 720x480 60
Mode: "640x480" 640x480 60
Encoder: TMDS
	crtc_id   :0
	type   :2
	possible_crtcs  :0x3
	possible_clones :0x0
Encoder: TMDS
	crtc_id   :0
	type   :2
	possible_crtcs  :0x3
Crtc
	x              : 0
	y              : 0
	width          : 0
	height         : 0
	mode           : 0xaaaac7b8615c
	gamma size     : 0
Crtc
	x              : 0
	y              : 0
	width          : 0
	height         : 0
	mode           : 0xaaaac7b861cc
	gamma size     : 0
Ok
please refer to the sw feature over here.
https://docs.nvidia.com/jetson/archives/r34.1/DeveloperGuide/text/SO/JetsonAgxOrin.html
