Is the Agx-Orin supporting hdmi 4k resolution?
The xrandr show the system only support full hd resolution
ubuntu@linux:~$ xrandr
Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 32767 x 32767
DP-0 disconnected (normal left inverted right x axis y axis)
DP-1 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 597mm x 336mm
1920x1080 60.00*+ 59.94 50.00
1680x1050 59.95
1600x900 60.00
1440x900 59.89
1280x1024 75.02 60.02
1280x800 59.81
1280x720 60.00 59.94 50.00
1152x864 75.00
1024x768 75.03 70.07 60.00
800x600 75.00 72.19 60.32 56.25
720x576 50.00
720x480 59.94
640x480 75.00 72.81 59.94
ubuntu@linux:~$
BSP : R35.1.0
Yes it supports 4k.
Please also try other monitors too.
BTW, why are you still using DP and you ask me about HDMI?
We tried two of different brand HDMI monitors, both provided the same information. I’m wondering also is it a bug for that DP-1 named?
Is this your custom carrier board? If so, how did you bring up your HDMI interface?
Yes, it is our custom board, we do not changed any thing about display. We flashed this image to boot up system on Dev-Kit with a DP display prior and flashing this image to our custom carrier board with HDMI output without modified any display configuration.
Then it is wrong… it is not a HDMI interface… it is still DP…
Is the file “tegra234-dcb-p3701-0000-a02-p3737-0000-a01.dtsi” for DP output?
You need to generate new dcb file for HDMI. The default on in source code is for DP only.
https://docs.nvidia.com/jetson/archives/r35.1/DeveloperGuide/text/SD/Kernel/DisplayConfigurationAndBringUp/OrinDisplayconfig.html?highlight=dcb
Also… suggest you to file ticket for this issue. I am not sure why you are asking this on forum.
Also, we think this will need our hardware engineer to review your schematics.
