Orin nx 8G development board, uses HDMI output, links to 4K displays, only supports 1920* 1080@60 I used a special device and changed it to 3840 * 1080, which can only output 30Hz; If configured at 60Hz, it cannot be displayed; That is to say, my HDMI can only output a bandwidth of less than 165M. May I ask why?
Related topics
| Only 1080p resolution of customized Orin nx carrier board | 3 | 817 | June 5, 2023 | |
| Orin NX 4k HDMI output on custom carrier board | 1 | 164 | June 3, 2025 | |
| AGX ORIN 32GB carrier HDMI has been forced to 1080p@60hz, can not adapt to 4K@60hz | 11 | 990 | July 26, 2023 | |
| Some 4K display did not work via the HDMI in AGX Orin platform with jetpack5.0.2 and jetpack5.1.1 | 9 | 1263 | June 12, 2023 | |
| How to change Display Function from dp to hdmi on the Orin nano Developer Kit ? | 15 | 326 | September 30, 2025 | |
| AGX Orin Display issue with 4K HDMI | 4 | 968 | October 14, 2023 | |
| Hdmi just support 1080p display screen,jetson orin nx 8g | 11 | 1330 | June 15, 2023 | |
| Orin max supported display resolutions - 8K? | 1 | 620 | April 25, 2024 | |
| Is the Agx-Orin supporting hdmi 4k resolution? | 9 | 2147 | November 1, 2022 | |
| Orin Nano, custom board has no HDMI 4K image | 6 | 900 | December 8, 2023 |
