HDMI is not working in 4K mode for Jetson Orin NX -- Continued
To the continuation of below topic
I will correct the dts file as per the discussion.
After dts file change do I need to make any changes in source for Jetson Orin NX or can I use as it is.
You also need to make sure the pinmux setting is correct. The hotplug detection pin needs to be GPIO.
And try to tell what is the exact problem you hit there. Previous topic already explained a quick way.
