The monitor have no display
When i use Jetson AGX Orin develop kit, the monitor was black after the logo screen. And then i used sdkmanage to flash the system to jepack 5.0.2,; use the cable (working well in another Orin); change the monitor(working well in another Orin); but those track are all not work. Finally, i use ttyACM0 to contact Orin to test weather the flashed system well ,result shows that the system is well ,i can logo in the system by it. and reboot it the logo message has no error, but the monitor has nothing to display.
so how works i can do to have a working monitor?
Jetpack5.0.2 is already old BSP. Please try to use jp5.1.1
Yes, i have try the jp5.1 and jp5.1.1 , they are all does not work.
What kind of monitor are you using?
Also, I notice some logs in your screenshot are abnormal. Are you sure this is devkit?
請注意一下devkit是指nv出的公板. 如果不是nv公板的話不能說是devkit…
The monitor i used is asus the model this VY279, i see the sdkmanager detect the device only have the one choinces that have 32G(…develop kit modul…), so i think it is devkit.
sdkm不會去偵測你的底板是什麼 只會去看module型號而已.
另外請問一下VY279是不是只有HDMI?
Also want to check, does VY279 only have HDMI?
Yes the VY279 only have HDMI, and i have try in another monitor PHILIPS model ID275B9N/93, it have DP port. But it also doesn’t work.
請問你的底板到底長怎麼樣子…他上面到底是HDMI port還是DP port…
Orin 上面只有DP,我用了两块屏幕,一块是只有HDMI,另一块上有DP,这两块屏幕都单独测试过都没有显示。
  1. 可以請你把你的dmesg完整的附上來嗎…
  2. 所以你的意思是你在測hdmi的時候有使用轉接頭嗎
這個forum可以用附件上傳… 麻煩有任何log都用附件不要直接複製貼上…
如果你再多貼上幾份log 我們這個post也沒辦法看了…
dmesg.txt (35.7 KB)
麻煩log從開始開機的時候抓…不是從kernel都已經開到了一半才抓…
dmesg.txt (76.9 KB)
抱歉花费d的时间有点点长
請問一下你有沒有完成第一次開機的帳號設定? 還是你不知道我在說什麼?
是在sdk上设置的账号和密码吗?这个是有完成的。
如果板子是在可以操作的狀況的話 麻煩分享一下
  1. lsmod command結果
  2. /var/log/Xorg.0.log
result_of_lsmod.txt (2.8 KB)
Xorg.txt (14.0 KB)
