Hi, I’m using a orin nx devkit board and want to change pinmux through dtsi files.
I followed
Go to Jetson Download Center | NVIDIA Developer. and down load the orin nx series pinmux file.
But there is only some xml file in it and no pinmux table while other board is just downloaded pinmux table.
Is there any wrong with your source?
Thanks for help!
Hi 854053437,
Please check if you could see pinmux spreadsheet for Orin NX/Nano in Jetson Download Center | NVIDIA Developer. Pinmux/Gpio dtsi are generated through .xlsm
file.
No, there is only Jetson_Orin_NX_and_Orin_Nano_series_Pinmux_Config_Template.zip
file and unzip it there is no .xlsm
file in it.
Hi, is there any file can I get cause I need to change the pinmux by reflash my board to test.
