ORIN NX使用USB3.0只有USB2.0的速率
我们使用orin nx直出的以及通过upd720201扩展的usb3.0接入usb3.0设备速率只有usb2.0,通过查找论坛资料发现需要更改设备树,但是按照设备树更改后出现报错:
于是在原来的基础上更改了一下,但是重新烧录后还是一样的现象。
这是修改过的dtsi文件
tegra234-p3768-0000.dtsi.txt (4.8 KB)
You need to share the board design block diagram so that we can tell if the device tree is wrong.
We are not your colleague or hardware guy. We won’t know what is your true design looks like.
Also, we don’t check compilation error here. It is basic device tree syntax that you should figure out by yourself first.
usb1与usbss1对应;usb2与usbss2对应;以下是upd720201的原理图部分:
If usb2-1 and usb3-1 are together with usb host mode, then why do you have them in “usb@3550000”? That is device mode controller.
And usb3-0 is not in use, it should be disabled.
What is vdd_1v1_hub regulator? Are you sure it is really in use on your hub?
好的,那我应该把vdd_1v1_hub改成vdd_5v0_sys,然后禁用usb3-0;在usb@3550000中直接把phys、phy-names直接删除对吧
This depends on your hardware design. I won’t know.
You need to keep usb2-0 if you want usb2-0 to support device mode(otg).
好的,设备树中有没有哪里可以更改usb速率的;因为怀疑哪里把usb速率限制了,不止是orin直接出来的usb速率达不到3.0,通过pcie经过upd720201扩出来的4个usb3.0口也达不到3.0的速率
No, there is no such setting in the device tree.
USB hub on PCIe is also not controlled by our driver but the vendor driver. We only provided you the PCIe driver.
好的,谢谢
