Orin NX use 2 Cameras (both x4 ) issue
We have a carrier board with 2 cameras(both x4). Currently, I am facing an issue with using camera0.
My camera0 consists of CSI0_D0 + CSI0_D1 + CSI1_D0 + CSI1_D1 and clock use CSI0_CLK (supported for x4 configuration) , differences from devkit (P3768-A04 Orin Carry Board) CSI1_D0 + CSI1_D1 + CSI0_D0 + CSI0_D1
In design guide Chapter 10 :MIPI CSI VIDEO INPUT, it is said “CSI_0_D1 and CSI_1_D0 have P/N swapped on the module”
my question is how can i config “lane_polarity” is 0 or 6 ?
Suppose the lane_polarity is 6 for the Orin NX.
Yes, I know lane_polarity is 6 for the Orin NX, but my carrier board for MIPI camera 0 is different ‘P3768-A04 Orin Carry Board’. So, is lane_polarity also 6?
" * lane_polarity must be 0x6 for sensors attached to CSI0/1 port, since CSI0 D1 and CSI1 D0 has P/N swizzled, in Orin NX 16GB, Orin NX 8GB, Orin Nano 8GB and Orin Nano 4GB modules. Set it by 0x0 for other cases."
thank you!
Suppose the pin is swap in the Orin NX module it should need set to 6.
in the camera0 (CSI0 + CSI1, 4lanes)
i set lane_polarity = “6” and the /dev/video0 can show up , but can’t display image stream normally .
use command is :
“gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! ‘video/x-raw(memory:NVMM),width=(int)1280,height=(int)720,format=(string)NV12,framerate=(fraction)30/1’ ! nvvidconv ! queue ! xvimagesink”
Eventually, an error occurs (pls see attachments).
cam1_gst-launch-1.0.txt (2.1 KB)
cam1_v4l2-ctl.txt (7.8 KB)
my questions are …
  1. I want to set the camera0 (CSI0+CSI1) to 4lanes. In addition to using CSI0_CLK (supported for x4 configuration) for the clock and lane_polarity = “6”, which part do I need to modify?
  2. What is the definition of serial_a serial_b serial_c serial_d for tegra_sinterface
I would suggest bring the camera in CSI2+3 4 lanes without lane polarity to make sure the sensor driver then come back to CSI0+1.
Below is the tegra_sinterface map.
CSI0 ↔ serial_a
CSI1 ↔ serial_b
CSI2 ↔ serial_c
CSI3 ↔ serial_d
