hello nvidia: I am portting a new sensor to Orin NX, it can’t receive any validate data from the MIPI bus. The same DTS and driver is working well in jetson tx2 nx and jetson nano. There is some trace info below. I have no ideas to solve it, please help me.
root@nvidia-desktop:/home/nvidia# v4l2-ctl -d /dev/video0 --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
Type: Video Capture
[0]: 'UYVY' (UYVY 4:2:2)
Size: Discrete 1920x1080
Interval: Discrete 0.033s (30.000 fps)
[1]: 'NV16' (Y/CbCr 4:2:2)
[2]: 'UYVY' (UYVY 4:2:2)
root@nvidia-desktop:/home/nvidia# media-ctl -p -d /dev/media0
Media controller API version 5.10.120
Media device information
driver tegra-camrtc-ca
model NVIDIA Tegra Video Input Device
serial
bus info
hw revision 0x3
driver version 5.10.120
Device topology
- entity 1: 13e40000.host1x:nvcsi@15a00000- (2 pads, 2 links)
type V4L2 subdev subtype Unknown flags 0
device node name /dev/v4l-subdev0
pad0: Sink
<- "nvp6188 7-0030":0 [ENABLED]
pad1: Source
-> "vi-output, nvp6188 7-0030":0 [ENABLED]
- entity 4: nvp6188 7-0030 (1 pad, 1 link)
type V4L2 subdev subtype Sensor flags 0
device node name /dev/v4l-subdev1
pad0: Source
[fmt:UYVY8_1X16/1920x1080 field:none colorspace:srgb]
-> "13e40000.host1x:nvcsi@15a00000-":0 [ENABLED]
- entity 6: vi-output, nvp6188 7-0030 (1 pad, 1 link)
type Node subtype V4L flags 0
device node name /dev/video0
pad0: Sink
<- "13e40000.host1x:nvcsi@15a00000-":1 [ENABLED]
root@nvidia-desktop:/home/nvidia# cat /sys/kernel/debug/tracing/trace
# tracer: nop
# entries-in-buffer/entries-written: 31/31 #P:4
# _-----=> irqs-off
# / _----=> need-resched
# | / _---=> hardirq/softirq
# || / _--=> preempt-depth
# ||| / delay
# TASK-PID CPU# |||| TIMESTAMP FUNCTION
kworker/2:0-25 [002] .... 135.555946: rtcpu_string: tstamp:4891112159 id:0x04010000 str:"VM0 deactivating."
v4l2-ctl-2284 [000] .... 154.898668: tegra_channel_open: vi-output, nvp6188 7-0030
v4l2-ctl-2284 [000] .... 154.904509: tegra_channel_set_power: nvp6188 7-0030 : 0x1
v4l2-ctl-2284 [000] .... 154.904521: camera_common_s_power: status : 0x1
v4l2-ctl-2284 [000] .... 154.904545: tegra_channel_set_power: 13e40000.host1x:nvcsi@15a00000- : 0x1
v4l2-ctl-2284 [000] .... 154.904547: csi_s_power: enable : 0x1
v4l2-ctl-2284 [000] .... 154.905231: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt 13
v4l2-ctl-2284 [001] .... 154.911590: tegra_channel_set_stream: enable : 0x1
v4l2-ctl-2284 [001] .... 154.922626: tegra_channel_set_stream: 13e40000.host1x:nvcsi@15a00000- : 0x1
v4l2-ctl-2284 [001] .... 154.922629: csi_s_stream: enable : 0x1
v4l2-ctl-2284 [001] .... 154.923064: tegra_channel_set_stream: nvp6188 7-0030 : 0x1
kworker/2:0-25 [002] .... 154.934342: rtcpu_string: tstamp:5496348338 id:0x04010000 str:"VM0 activating."
kworker/2:0-25 [002] .... 154.934345: rtcpu_vinotify_event: tstamp:5496811973 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:175887248096 data:0x759d580010000000
kworker/2:0-25 [002] .... 154.934346: rtcpu_vinotify_event: tstamp:5496812129 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:175887254560 data:0x0000000031000001
kworker/2:0-25 [002] .... 154.934346: rtcpu_vinotify_event: tstamp:5496812285 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:175887305600 data:0x759d550010000000
kworker/2:0-25 [002] .... 154.934346: rtcpu_vinotify_event: tstamp:5496812417 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:175887312192 data:0x0000000031000002
vi-output, nvp6-2286 [003] .... 157.470592: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt 13
kworker/2:0-25 [002] .... 157.526110: rtcpu_vinotify_event: tstamp:5576681213 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:178446462496 data:0x759d580010000000
kworker/2:0-25 [002] .... 157.526112: rtcpu_vinotify_event: tstamp:5576681354 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:178446489920 data:0x0000000031000001
kworker/2:0-25 [002] .... 157.526113: rtcpu_vinotify_event: tstamp:5576681510 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:178446501248 data:0x759d550010000000
kworker/2:0-25 [002] .... 157.526113: rtcpu_vinotify_event: tstamp:5576681644 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:178446540064 data:0x0000000031000002
v4l2-ctl-2284 [002] .... 158.499007: tegra_channel_close: vi-output, nvp6188 7-0030
vi-output, nvp6-2286 [003] .... 160.061560: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt 13
v4l2-ctl-2284 [002] .... 160.071204: tegra_channel_set_stream: enable : 0x0
v4l2-ctl-2284 [002] .... 160.071205: tegra_channel_set_stream: nvp6188 7-0030 : 0x0
v4l2-ctl-2284 [002] .... 160.072225: tegra_channel_set_stream: 13e40000.host1x:nvcsi@15a00000- : 0x0
v4l2-ctl-2284 [002] .... 160.072227: csi_s_stream: enable : 0x0
v4l2-ctl-2284 [001] .... 160.084838: tegra_channel_set_power: nvp6188 7-0030 : 0x0
v4l2-ctl-2284 [001] .... 160.084847: camera_common_s_power: status : 0x0
v4l2-ctl-2284 [001] .... 160.088516: tegra_channel_set_power: 13e40000.host1x:nvcsi@15a00000- : 0x0
v4l2-ctl-2284 [001] .... 160.088519: csi_s_power: enable : 0x0
This is my DTS, “lane_polarity” I try to use 0 and 6 both not work.
tegra-capture-vi {
num-channels = <1>;
ports {
#address-cells = <1>;
#size-cells = <0>;
port@0 {
reg = <0>;
nvp6188_vi_in0: endpoint {
port-index = <0>;
bus-width = <2>;
remote-endpoint = <&nvp6188_csi_out0>;
host1x@13e00000 {
nvcsi@15a00000 {
num-channels = <1>;
#size-cells = <0>;
channel@0 {
reg = <0>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
nvp6188_csi_in0: endpoint@0 {
port-index = <0>;
bus-width = <2>;
remote-endpoint = <&nvp6188_nvp6188_out0>;
port@1 {
reg = <1>;
nvp6188_csi_out0: endpoint@1 {
remote-endpoint = <&nvp6188_vi_in0>;
i2c@c250000 {
nvp6188_a@30 {
compatible = "nvidia,nvp6188";
reg = <0x30>;
devnode = "video0";
physical_w = "15.0";
physical_h = "12.5";
sensor_model ="nvp6188";
post_crop_frame_drop = "3";
use_decibel_gain = "true";
delayed_gain = "true";
use_sensor_mode_id = "true";
mode0 {/*mode NVP6188_MODE_1920X1080_CROP_30FPS*/
mclk_khz = "27000";
num_lanes = "2";
phy_mode = "DPHY";
discontinuous_clk = "yes";
dpcm_enable = "false";
cil_settletime = "0";
lane_polarity = "0";
active_w = "1920";
active_h = "1080";
mode_type = "yuv";
pixel_phase = "uyvy";
dynamic_pixel_bit_depth = "16";
csi_pixel_bit_depth = "16";
readout_orientation = "0";
line_length = "2200";
inherent_gain = "1";
mclk_multiplier = "18";
pix_clk_hz = "1188000000";
gain_factor = "16";
framerate_factor = "1000000";
exposure_factor = "1000000";
min_gain_val = "16";
max_gain_val = "356";
step_gain_val = "1";
default_gain = "16";
min_hdr_ratio = "1";
max_hdr_ratio = "1";
min_framerate = "1500000"; /* 1.5 */
max_framerate = "30000000"; /* 30 */
step_framerate = "1";
default_framerate = "30000000";
min_exp_time = "25"; /* us */
max_exp_time = "660000"; /* us */
step_exp_time = "1";
default_exp_time = "33334";/* us */
embedded_metadata_height = "0";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
nvp6188_nvp6188_out0: endpoint {
port-index = <0>;
bus-width = <2>;
remote-endpoint = <&nvp6188_csi_in0>;
tegra-camera-platform {
compatible = "nvidia, tegra-camera-platform";
* Physical settings to calculate max ISO BW
* num_csi_lanes = <>;
* Total number of CSI lanes when all cameras are active
* max_lane_speed = <>;
* Max lane speed in Kbit/s
* min_bits_per_pixel = <>;
* Min bits per pixel
* vi_peak_byte_per_pixel = <>;
* Max byte per pixel for the VI ISO case
* vi_bw_margin_pct = <>;
* Vi bandwidth margin in percentage
* max_pixel_rate = <>;
* Max pixel rate in Kpixel/s for the ISP ISO case
* isp_peak_byte_per_pixel = <>;
* Max byte per pixel for the ISP ISO case
* isp_bw_margin_pct = <>;
* Isp bandwidth margin in percentage
num_csi_lanes = <2>;
max_lane_speed = <1500000>;
min_bits_per_pixel = <8>;
vi_peak_byte_per_pixel = <2>;
vi_bw_margin_pct = <25>;
//max_pixel_rate = <750000>;
isp_peak_byte_per_pixel = <5>;
isp_bw_margin_pct = <25>;
* The general guideline for naming badge_info contains 3 parts, and is as follows,
* The first part is the camera_board_id for the module; if the module is in a FFD
* platform, then use the platform name for this part.
* The second part contains the position of the module, ex. "rear" or "front".
* The third part contains the last 6 characters of a part number which is found
* in the module's specsheet from the vender.
modules {
module0 {
//badge = "nvp6188_front_linv6188";
position = "bottom";
orientation = "0";
drivernode0 {
/* Declare PCL support driver (classically known as guid) */
pcl_id = "v4l2_sensor";
/* Driver v4l2 device name */
devname = "nvp6188 30-001a";
/* Declare the device-tree hierarchy to driver instance */
proc-device-tree = "/proc/device-tree/i2c@c250000/nvp6188_a@30";
