Hello Nvidia Team,
We are using Orin NX (16 GB) module + avermedia d131 kit with ov5640 camera sensor.
& facing difficulty while bringing it up.
Driver used : /drivers/media/i2c/ov5640.c (in kernel-source.)
Device Tree :
include “avt-p3767-0000-p1310-0000-d131ox.dtsi”
capture_vi_base: tegra-capture-vi {
num-channels = <1>;
ports {
#address-cells = <1>;
#size-cells = <0>;
status = “okay”;
ov5640_vi_port0: port@0 {
reg = <0>;
status = "okay";
ov5640_vi_in0: endpoint {
status = "okay";
port-index = <0>;
bus-width = <2>;
remote-endpoint = <&ov5640_csi_out0>;
host1x@13e00000 {
csi_base: nvcsi@15a00000 {
num-channels = <1>;
#size-cells = <0>;
status = "okay";
csi_chan0: channel@0 {
reg = <0>;
status = "okay";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
status = "okay";
ov5640_csi_in0: endpoint@0 {
status = "okay";
port-index = <0>;
bus-width = <2>;
remote-endpoint = <&ov5640_out0>;
port@1 {
reg = <1>;
status = "okay";
ov5640_csi_out0: endpoint@1 {
status = "okay";
remote-endpoint = <&ov5640_vi_in0>;
i2c@c240000 {
status = "okay";
#size-cells = <0>;
ov5640_mipi: ov5640_mipi@3c {
compatible = "ovti,ov5640";
reg = <0x3c>;
devnode = "video0";
physical_w = "3.680";
physical_h = "2.760";
sensor_model = "ov5640";
use_sensor_mode_id = "false";
clocks = <&bpmp_clks TEGRA234_CLK_EXTPERIPH4>, <&bpmp_clks TEGRA234_CLK_PLLP_OUT0>;
clock-names = "xclk", "pllp_grtba";
powerdown-gpios = <&tegra_main_gpio TEGRA234_MAIN_GPIO(Q, 5) GPIO_ACTIVE_HIGH>;
reset-gpios = <&tegra_main_gpio TEGRA234_MAIN_GPIO(AC, 6) GPIO_ACTIVE_HIGH>;
status = "okay";
mode0 { /* OV5640_MODE_1920x1080_30FPS */
mclk_khz = "27000";
num_lanes = "2";
lane_polarity = "6";
phy_mode = "DPHY";
discontinuous_clk = "yes";
dpcm_enable = "false";
cil_settletime = "0";
active_w = "1920";
active_h = "1080";
pixel_phase = "uyvy";
mode_type = "yuv";
csi_pixel_bit_depth = "16";
readout_orientation = "0";
line_length = "2200";
inherent_gain = "1";
mclk_multiplier = "9.33";
pix_clk_hz = "207000000";
gain_factor = "100";
framerate_factor = "1000000";
exposure_factor = "1000000";
min_gain_val = "0"; /* 1.00x */
max_gain_val = "540"; /* 10.66x */
step_gain_val = "6";
default_gain = "0"; /* 1.00x */
min_hdr_ratio = "1";
max_hdr_ratio = "1";
min_framerate = "15000000"; /* 2.0 fps */
max_framerate = "30000000"; /* 30.0 fps */
step_framerate = "1";
default_framerate = "30000000"; /* 30.0 fps */
min_exp_time = "1070"; /* us */
max_exp_time = "33245"; /* us */
step_exp_time = "55";
default_exp_time = "2495"; /* us */
embedded_metadata_height = "0";
mode1 { /* OV5640_MODE_1920x1080_30FPS */
mclk_khz = "27000";
num_lanes = "2";
phy_mode = "DPHY";
active_w = "1920";
active_h = "1080";
//pixel_t = "uyvy";
mode_type = "yuv";
max_framerate = "15000000"; /* 30.0 fps */
mode2 { /* OV5640_MODE_720P_1280x720 */
mclk_khz = "27000";
num_lanes = "2";
phy_mode = "DPHY";
active_w = "1280";
active_h = "720";
//pixel_t = "uyvy";
mode_type = "yuv";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
ov5640_out0: endpoint {
status = "okay";
port-index = <0>;
bus-width = <2>;
remote-endpoint = <&ov5640_csi_in0>;
When loading module for ov5640 , we are getting kernel trace as below.
tegra_channel_s_ctrl+0x1c4/0x21c
__v4l2_ctrl_handler_setup+0x10c/0x134
v4l2_ctrl_handler_setup+0x30/0x6c
tegra_channel_init_subdevices+0x2a4/0x7ac
tegra_vi_graph_notify_complete+0x2f4/0x690
v4l2_async_notifier_try_complete+0x78/0x84
v4l2_async_register_subdev+0x168/0x1b0
v4l2_async_register_subdev_sensor_common+0x78/0xf0
ov5640_probe+0x68c/0x78c [ov5640]
i2c_device_probe+0x120/0x300
really_probe+0xf8/0x4b0
driver_probe_device+0x60/0xbc
device_driver_attach+0xc0/0xcc
__driver_attach+0x94/0x120
bus_for_each_dev+0x84/0xe0
driver_attach+0x34/0x40
bus_add_driver+0x10c/0x1ec
driver_register+0x7c/0x124
i2c_register_driver+0x54/0xd0
ov5640_i2c_driver_init+0x28/0x1000 [ov5640]
do_one_initcall+0x54/0x2e0
do_init_module+0x50/0x240
Kernel panic seems to be occurend by kernel-source/nvidia/drivers/media/platform/tegra/camera/vi/channel.c [ line :1335].
case TEGRA_CAMERA_CID_VI_PREFERRED_STRIDE:
chan->preferred_stride = ctrl->val;
tegra_channel_update_format(chan, chan->format.width,
chan->format.height,
chan->format.pixelformat,
&chan->fmtinfo->bpp,
chan->preferred_stride);
Could anyone please let us know the reason behind kernel panic when inserting ov5640.ko driver.
Thanks & Regards,
Kaushal Dekivadia
