We are able to do a apt upgrade and the L4T and jetpack are upgraded to 32.4.4. and 4.4.1 respectively.
But while trying to use “apt dist-upgrade”, the L4T and jetpack version remain same.
Is there a way that I can do a “apt dist-upgrade” for custom board to latest version?
The L4T version is 32.4.2 and Jetpack version is 4.4 DP on our custom board
We have kept some L4T packages on hold : nvidia-l4t-bootloader, nvidia-l4t-kernel, nvidia-l4t-kernel-dtbs, nvidia-l4t-kernel-headers so that the custom boards kernel and dtb is not over written.
On using “apt upgrade” - the L4T version and jetpack version are upgraded to 32.4.4 and 4.4.1 respectively.
But on using “apt dist-upgrade”, the version of L4T and jetpack remains same and also hdmi issue is noted.
Thanks for your response @carolyuu ,
I want to upgrade from L4T 32.4.2 to latest L4T 32.5.
Followed the Jetson Linux Developer Guide to upgrade from 32.4.2 to 32.5 .
Run the below commands to hold the packages:
$ sudo apt-mark hold nvidia-l4t-bootloader nvidia-l4t-kernel nvidia-l4t-kernel-dtbs nvidia-l4t-kernel-headers
Maybe you can compare the log between dist-upgrade and upgrade.
I see following log from your dist-upgrade log.
the following packages have been kept back:
nvidia-l4t-apt-source nvidia-l4t-bootloader nvidia-l4t-configs nvidia-l4t-core nvidia-l4t-firmware nvidia-l4t-init nvidia-l4t-initrd nvidia-l4t-kernel nvidia-l4t-kernel-dtbs nvidia-l4t-kernel-headers
nvidia-l4t-multimedia-utils nvidia-l4t-oem-config nvidia-l4t-tools nvidia-l4t-wayland nvidia-l4t-weston nvidia-l4t-x11 nvidia-l4t-xusb-firmware
Since the difference between dist-upgrade and upgrade is dist-upgrade would handle the dependencies issue, once you hold some debian package, it may cause nvidia-l4t-core not upgrade either. And most of packages depend on l4t-core.
I tried to do a upgrade to 32.5 using “apt-get update and apt-get upgrade”. Still I face the same issue.
I checked the logs , the same packages are kept back.
Is there a way to hold the packages and upgrade L4T and jetpack ?
I mentioned that I am able to do a upgrade from 32.4.2 to 32.4.4 using" apt-get upgrade"
But I want to upgrade from 32.4.2 to 32.5. I followed the steps mentioned in Jetson Linux Developer Guide along with hold packages to upgrade from 32.4.2 to 32.5 - in this steps “apt dist-upgrade” is used. The L4T and jetpack version was not upgraded and HDMI issue was noticed.
As suggested in your previous reply , along with the steps to upgrade from 32.4.2 to 32.4.5, I used “apt-get update” instead of “apt dist-upgrade” and I reported that I face the same issue.
If even upgrade does not work, then the dependencies just not allow you to do that.
Let’s make it easy to understand. Our OTA method does not support any customized case.
For example, if you want to hold anything in old release, then that is one of customization so you may get what you want.
Thus, please do not hold any package. We also don’t guarantee rel-32.4.x kernel could work with other rel- 32.5 packages.
