Hello everybody.
From few weeks I am trying to overclock my Nvidia 3090 gpus. I was installed ubuntu, install drivers etc. Everything (mining) was work stable, but i have only 107Mh per gpus. I tried to make some overclocking but after few hours i was able to overclock only one card (main one).
My configuration:
- MB: Asrock H110 Pro BTC+
- GPUS: 5x RTX3090
- System: Ubuntu 20.04
- Nvidia Drivers: 470.63.01
One GPU is connected to PCI x16 - screen is connected to this GPU (only this GPU i could overclk), rest is connected to PCI x1. (I was also tryed to connect screen to integrated GPU or others, mining is working but ovclk also do not)
Here’s what i did:
- Set up coolbits to 26 (i wase used command: ‘nvidia-xconfig --cool-bits=28‘ and also change xorg.conf adding option coolbit to section ‘screen’ an ‘device’ )
- -Set nvidia-xconfig --enable-all-gpus
- -Set persistence mode (nvidia-smi -pm 1)
- -Set PowerMizer mode = 1 via nvidia-settings
- -Set the "GPUGraphicsClockOffset[3] and GPUMemoryTranserRateOffset[3] (but it was doesnt work – I had to use :
Everything is working only for GPU0, for other GPUS nothing happend.
I also run GUI i go to nvidia-x-settings to try change value on graphics mode. I can make it only for GPU0 – on other GPUs this performance level option is anavialable.
I tried to connect screen to other GPU – no changes
What is wrong? Why i cant overclock other GPUS connected to PCI x1?
My actual xorg.conf:
# nvidia-xconfig: X configuration file generated by nvidia-xconfig # nvidia-xconfig: version 470.63.01 Section "ServerLayout" Identifier "Layout0" Screen 0 "Screen0" 0 0 Screen 1 "Screen1" RightOf "Screen0" Screen 2 "Screen2" RightOf "Screen1" Screen 3 "Screen3" RightOf "Screen2" Screen 4 "Screen4" RightOf "Screen3" InputDevice "Keyboard0" "CoreKeyboard" InputDevice "Mouse0" "CorePointer" EndSection Section "Files" EndSection Section "InputDevice" # generated from default Identifier "Mouse0" Driver "mouse" Option "Protocol" "auto" Option "Device" "/dev/psaux" Option "Emulate3Buttons" "no" Option "ZAxisMapping" "4 5" EndSection Section "InputDevice" # generated from default Identifier "Keyboard0" Driver "kbd" EndSection Section "Monitor" Identifier "Monitor0" VendorName "Unknown" ModelName "Unknown" Option "DPMS" EndSection Section "Monitor" Identifier "Monitor1" VendorName "Unknown" ModelName "Unknown" Option "DPMS" EndSection Section "Monitor" Identifier "Monitor2" VendorName "Unknown" ModelName "Unknown" Option "DPMS" EndSection Section "Monitor" Identifier "Monitor3" VendorName "Unknown" ModelName "Unknown" Option "DPMS" EndSection Section "Monitor" Identifier "Monitor4" VendorName "Unknown" ModelName "Unknown" Option "DPMS" EndSection Section "Device" Identifier "Device0" Driver "nvidia" VendorName "NVIDIA Corporation" BoardName "NVIDIA GeForce RTX 3090" BusID "PCI:1:0:0" Option "Coolbits" "28" EndSection Section "Device" Identifier "Device1" Driver "nvidia" VendorName "NVIDIA Corporation" BoardName "NVIDIA GeForce RTX 3090" BusID "PCI:2:0:0" Option "Coolbits" "28" EndSection Section "Device" Identifier "Device2" Driver "nvidia" VendorName "NVIDIA Corporation" BoardName "NVIDIA GeForce RTX 3090" BusID "PCI:3:0:0" Option "Coolbits" "28" EndSection Section "Device" Identifier "Device3" Driver "nvidia" VendorName "NVIDIA Corporation" BoardName "NVIDIA GeForce RTX 3090" BusID "PCI:6:0:0" Option "Coolbits" "28" EndSection Section "Device" Identifier "Device4" Driver "nvidia" VendorName "NVIDIA Corporation" BoardName "NVIDIA GeForce RTX 3090" BusID "PCI:8:0:0" Option "Coolbits" "28" EndSection Section "Screen" Identifier "Screen0" Device "Device0" Monitor "Monitor0" DefaultDepth 24 Option "AllowEmptyInitialConfiguration" "True" Option "ConnectedMonitor" "DFP-0" Option "Interactive" "False" Option "Coolbits" "28" SubSection "Display" Depth 24 EndSubSection EndSection Section "Screen" Identifier "Screen1" Device "Device1" Monitor "Monitor1" DefaultDepth 24 Option "AllowEmptyInitialConfiguration" "True" Option "ConnectedMonitor" "DFP-0" Option "Interactive" "False" Option "Coolbits" "28" SubSection "Display" Depth 24 EndSubSection EndSection Section "Screen" Identifier "Screen2" Device "Device2" Monitor "Monitor2" DefaultDepth 24 Option "AllowEmptyInitialConfiguration" "True" Option "ConnectedMonitor" "DFP-0" Option "Interactive" "False" Option "Coolbits" "28" SubSection "Display" Depth 24 EndSubSection EndSection Section "Screen" Identifier "Screen3" Device "Device3" Monitor "Monitor3" DefaultDepth 24 Option "AllowEmptyInitialConfiguration" "True" Option "ConnectedMonitor" "DFP-0" Option "Interactive" "False" Option "Coolbits" "28" SubSection "Display" Depth 24 EndSubSection EndSection Section "Screen" Identifier "Screen4" Device "Device4" Monitor "Monitor4" DefaultDepth 24 Option "AllowEmptyInitialConfiguration" "True" Option "ConnectedMonitor" "DFP-0" Option "Interactive" "False" Option "Coolbits" "28" SubSection "Display" Depth 24 EndSubSection EndSection
nvidia-smi:
+-----------------------------------------------------------------------------+ | NVIDIA-SMI 470.63.01 Driver Version: 470.63.01 CUDA Version: 11.4 | |-------------------------------+----------------------+----------------------+ | GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC | | Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. | | | | MIG M. | |===============================+======================+======================| | 0 NVIDIA GeForce ... Off | 00000000:01:00.0 On | N/A | | 30% 29C P8 23W / 350W | 168MiB / 24267MiB | 0% Default | | | | N/A | +-------------------------------+----------------------+----------------------+ | 1 NVIDIA GeForce ... Off | 00000000:02:00.0 Off | N/A | | 30% 27C P8 12W / 350W | 5MiB / 24268MiB | 0% Default | | | | N/A | +-------------------------------+----------------------+----------------------+ | 2 NVIDIA GeForce ... Off | 00000000:03:00.0 Off | N/A | | 0% 26C P8 15W / 350W | 5MiB / 24268MiB | 0% Default | | | | N/A | +-------------------------------+----------------------+----------------------+ | 3 NVIDIA GeForce ... Off | 00000000:06:00.0 Off | N/A | | 30% 26C P8 14W / 350W | 5MiB / 24268MiB | 0% Default | | | | N/A | +-------------------------------+----------------------+----------------------+ | 4 NVIDIA GeForce ... Off | 00000000:08:00.0 Off | N/A | | 0% 24C P8 30W / 390W | 5MiB / 24268MiB | 0% Default | | | | N/A | +-------------------------------+----------------------+----------------------+ +-----------------------------------------------------------------------------+ | Processes: | | GPU GI CI PID Type Process name GPU Memory | | ID ID Usage | |=============================================================================| | 0 N/A N/A 1335 G /usr/lib/xorg/Xorg 79MiB | | 0 N/A N/A 1555 G /usr/bin/gnome-shell 86MiB | | 0 N/A N/A 1864 G /usr/bin/nvidia-settings 0MiB | | 1 N/A N/A 1335 G /usr/lib/xorg/Xorg 4MiB | | 2 N/A N/A 1335 G /usr/lib/xorg/Xorg 4MiB | | 3 N/A N/A 1335 G /usr/lib/xorg/Xorg 4MiB | | 4 N/A N/A 1335 G /usr/lib/xorg/Xorg 4MiB | +-----------------------------------------------------------------------------+
Blockquote
Thanks in advance for help.
