Sorry if this questions sound a little dumb, but has anyone faced this issues?
I am using:
- Ubuntu 16.04
- 2 GPUs RTX 3080 (EVGA RTX 3080 XC3 Ultra, MSI RTX 3080 Ventus 3X)
- Asus B250 Mining Expert
- Nvidia Driver 455.23.05, CUDA 11.1
What I am trying to achieve:
- I wanted to set the application, memory clock, and fan speed
What I have been doing so far that is successful:
- I have been able to trigger
persistence modeinnvidia-smi - Set the power limit with
nvidia-smi
What I have been doing that failed:
- I am not able to trigger coolbits via CLI or even edit it onto the
xorg.conf. (I have addedOption "Coolbits" "28"inside thexorg.conf) - I created a new folder in
/etc/X11/xorg.conf.dand make a filenvidia.confwith the property like such
#StartLine
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BoardName "Geforce RTX 3080"
BusID "PCI:11:0:0"
EndSection
Section "Device"
Identifier "Device1"
Driver "nvidia"
BusID "PCI:13:0:0"
EndSection
#EndLine
- Everytime I reboot the system, all the config does not persist and has been overriden, gist.github.com
- I tried to trigger the
nvidia-smi -q -d SUPPORTED_CLOCKS, i have enabled-pm 1on both GPU, but the result showing N/A, microway.com
==============NVSMI LOG==============
Timestamp : Sat Jan 9 16:29:36 2021
Driver Version : 455.23.05
CUDA Version : 11.1
Attached GPUs : 2
GPU 00000000:0B:00.0
Supported Clocks : N/A
GPU 00000000:0D:00.0
- I also tried using the ppa repository, but the outcome is mismatch version, the one from NVIDIA Cuda 11.1 is the working installation for me
ps: sorry i need to remove the link, new user cannot add more than 3 linkshttps://askubuntu.com/questions/4983/what-are-ppas-and-how-do-i-use-them
All the helps is much appreciated.
Thank you in advanced!
nvidia-bug-report.log.gz (1.4 MB)
