Driver 520, Ubuntu 20.04 / 5.15.0-52
System with Intel GPU where monitor connected and 3 NVIDIA cards.
I’m trying to enable overclocking (mem freq & cpu greq ) for my NVIDIA cards on the desktop system. I’m trying to apply "Option “Coolbits” “28” " to nvidia cards different ways:
user@pcc:/usr/share/X11/xorg.conf.d$ ls
10-amdgpu.conf 10-nvidia.conf 10-quirks.conf 10-radeon.conf 11-nvidia-offload.conf 40-libinput.conf 51-synaptics-quirks.conf 70-synaptics.conf 70-wacom.conf nvidia-options.conf
user@pc:/usr/share/X11/xorg.conf.d$ cat nvidia-options.conf
Section "OutputClass"
Identifier "nvidia-options"
MatchDriver "nvidia-drm"
Driver "nvidia"
Option "Coolbits" "28"
EndSectionuser@pc:/usr/share/X11/xorg.conf.d$ cat 10-nvidia.conf
Identifier "nvidia"
Driver "nvidia"
Option "AllowEmptyInitialConfiguration"
ModulePath "/usr/lib/x86_64-linux-gnu/nvidia/xorg"
EndSection
user@pc:/usr/share/X11/xorg.conf.d$ sudo cat 11-nvidia-offload.conf
# DO NOT EDIT. AUTOMATICALLY GENERATED BY gpu-manager
#Section "ServerLayout"
# Identifier "layout"
# Option "AllowNVIDIAGPUScreens"
#EndSection
As you an see, I comment out Option “AllowNVIDIAGPUScreens” and everything else from 11-nvidia-offload.conf AND removed nvidia-prime ( apt-get remove nvidia-prime ) from the system to not rewrite this 11-nvidia-offload file. Also I read that with NVIDIA PRIME coolbits can not work. But still no success!
Xorg.log
The problem is "(WW) NVIDIA(G2): Option “Coolbits” is not used "
p.s. I also tried to create my own /etc/X11/xorg.conf by " nvidia-xconfig -a --cool-bits=28 ", but the system can not boot with this xorg.conf as nvidia-config does not add “intel” card to it. If I did it myself by adding monitor, screen and device with “intel” drive, after restart graphics I see blank screen…
Please, help… Is there any way to enable overclocking and have intel card enabled with connected monitor.
p.p.s. BTW, I tried to connect monitor to NVIDIA card, but can not boot at all, because monitor switched off (not possible to the BIOS screen)…
