Setting applications clocks is not supported
Hi everybody,
I just got 2 EVGA GTX 1070 FTW cards. Everything works fine except that I am not able to overclock the cards. When I try to use the ‘‘nvidia-smi ac’’ I get the following message:
‘Setting applications clocks is not supported for GPU 0000:01:00.0.’
I have driver version 375.66 installed as well as CUDA 8.0. I have Ubuntu 16.04.
Anyone has any ideas? I have searched for many days to find a solution but coudn’t find something that works for me.
Thanks a lot in advance.
Are u using ssh or direct access? (must use 2nd)
You can not overclock without powermizer in xorg. You need to use coolbits.
nvidia-smi
was ment to use lower clocks that stock but you can query for supported clocks:
nvidia-smi -q
if u want to overclock you need to use presistent mode (demon) coolbits and nvidia-xconfig
nvidia-persistenced --persistence-mode  #first run deamon
nvidia-smi -pm ENABLED  #2nd enable persistenced mode
nvidia-smi -pl 130  #limit TDP if u want
to run coolbits all GPU must be seen in nvidia-setting by xorg, if not :
nvidia-xconfig -a, --enable-all-gpus  #this add every screen for every gpu to xconfig.conf
now we can run collbits
nvidia-xconfig -cool-bits=28 #now u can control core & mem clocks and termal setting in xorg.
use this from console or make script if u want to auto overclock (can use crontab):
nvidia-settings -a "GPUMemoryTransferRateOffset[3]=value"
nvidia-settings -a "GPUGraphicsClockOffset[3]=value"
