Hi all,
I’m trying to create a mirror in OVS 3.1.0057. I have a bridge br-inside with two DPDK ports (p1 and pf1hpf) and I want to mirror the traffic to a normal port en3f0pf0sf0 on another bridge br-mirrorI.
I created the mirror like this:
ovs-vsctl -- --id=@p1 get port p1 -- --id=@p2 get port pf1hpf -- --id=@m create mirror name=m1 select_dst_port=@p1 select_src_port=@p1,@p2 output-port=@p2 -- set bridge br-mirrorI mirrors=@m
The mirror was created successfully:
_uuid : fd21f823-9d68-44ed-a5d1-821ddd7115ee
external_ids : {}
output_port : 03ba8c56-5d8d-49b6-8cb6-1279270a8112
output_vlan : []
select_all : false
select_dst_port : [4072c5a7-22d1-40db-94fe-b0d2d613730f]
select_src_port : [03ba8c56-5d8d-49b6-8cb6-1279270a8112, 4072c5a7-22d1-40db-94fe-b0d2d613730f]
select_vlan : []
snaplen : []
statistics : {}
The problem is that the mirror shows no statistics and doesn’t seem to capture any traffic.
Here’s the current bridge setup:
ce8fd330-19c2-48f1-a70d-b16c7fcb1851
Bridge br-mirrorI
datapath_type: netdev
Port en3f0pf0sf0
Interface en3f0pf0sf0
type: dpdk
Port br-mirrorI
Interface br-mirrorI
type: internal
Port enp3s0f0s0
Interface enp3s0f0s0
Bridge br-inside
Port pf1hpf
Interface pf1hpf
type: dpdk
Port p1
Interface p1
type: dpdk
Port br-inside
Interface br-inside
type: internal
Bridge br-outside
Port br-outside
Interface br-outside
type: internal
ovs_version: "3.1.0057"
cookie=0x0, duration=647.280s, table=0, n_packets=0, n_bytes=0, priority=0 actions=NORMAL
doca@ovs-doca: hit:21177 missed:4801
br-inside:
br-inside 65534/1: (tap)
p1 1/2: (doca: dpdk-devargs=0000:03:00.1,dv_xmeta_en=4,dv_flow_en=2,reuse_tag=1,fdb_def_rule_en=0,repr_matching_en=0,vport_match=1, dpdk-lsc-interrupt=false, n_rxq=1, n_rxq_desc=2048, n_txq_desc=2048)
pf1hpf 2/3: (doca: dpdk-devargs=0000:03:00.1,dv_xmeta_en=4,dv_flow_en=2,reuse_tag=1,fdb_def_rule_en=0,repr_matching_en=0,vport_match=1,representor=pf1vf65535, dpdk-lsc-interrupt=false, dpdk-vf-mac=fe:09:5c:bd:47:63, n_rxq=1, n_rxq_desc=2048, n_txq_desc=2048)
offloaded flows: 19
offloaded packets: 98.42% (735745/747543)
offloaded bytes: 99.74% (664308386/666011783)
br-mirrorI:
br-mirrorI 65534/5: (tap)
en3f0pf0sf0 1/6: (doca: dpdk-devargs=0000:03:00.0,dv_xmeta_en=4,dv_flow_en=2,reuse_tag=1,fdb_def_rule_en=0,repr_matching_en=0,vport_match=1,representor=pf0sf0, dpdk-lsc-interrupt=false, dpdk-vf-mac=00:00:00:00:00:00, n_rxq=1, n_rxq_desc=0, n_txq_desc=0)
enp3s0f0s0 2/7: (system)
offloaded flows: 19
offloaded packets: 0.00% (0/0)
offloaded bytes: 0.00% (0/0)
br-outside:
br-outside 65534/4: (tap)
offloaded flows: 19
root@localhost:/home/ubuntu#
It looks like the mirror is created, but nothing is being mirrored. Any ideas on what might be wrong or how to get it working?
