/usr/lib/aarch64-linux-gnu/libprotobuf.a(extension_set.o): in function google::protobuf::internal::ExtensionSet::MutableString[abi:cxx11](int, unsigned char, google::protobuf::FieldDescriptor const*)': (.text+0xd40c): dangerous relocation: unsupported relocation /usr/bin/ld: /usr/lib/aarch64-linux-gnu/libprotobuf.a(extension_set.o): relocation R_AARCH64_ADR_PREL_PG_HI21 against symbol _ZTINSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEE’ which may bind externally can not be used when making a shared object; recompile with -fPIC
/usr/lib/aarch64-linux-gnu/libprotobuf.a(extension_set.o): in function google::protobuf::internal::ExtensionSet::AddString[abi:cxx11](int, unsigned char, google::protobuf::FieldDescriptor const*)': (.text+0xd7a0): dangerous relocation: unsupported relocation collect2: error: ld returned 1 exit status make[2]: *** [CMakeFiles/paddle2onnx.dir/build.make:1893: libpaddle2onnx.so.1.0.7] Error 1 make[1]: *** [CMakeFiles/Makefile2:178: CMakeFiles/paddle2onnx.dir/all] Error 2 make[1]: *** Waiting for unfinished jobs.... [ 88%] Building CXX object CMakeFiles/paddle2onnx_cpp2py_export.dir/paddle2onnx/mapper/tensor/one_hot_v2.cc.o [ 88%] Building CXX object CMakeFiles/paddle2onnx_cpp2py_export.dir/paddle2onnx/mapper/tensor/p_norm.cc.o [ 89%] Building CXX object CMakeFiles/paddle2onnx_cpp2py_export.dir/paddle2onnx/mapper/tensor/partial_ops.cc.o [ 89%] Building CXX object CMakeFiles/paddle2onnx_cpp2py_export.dir/paddle2onnx/mapper/tensor/pixel_shuffle.cc.o [ 89%] Building CXX object CMakeFiles/paddle2onnx_cpp2py_export.dir/paddle2onnx/mapper/tensor/pow.cc.o [ 90%] Building CXX object CMakeFiles/paddle2onnx_cpp2py_export.dir/paddle2onnx/mapper/tensor/range.cc.o [ 90%] Building CXX object CMakeFiles/paddle2onnx_cpp2py_export.dir/paddle2onnx/mapper/tensor/reduce.cc.o [ 90%] Building CXX object CMakeFiles/paddle2onnx_cpp2py_export.dir/paddle2onnx/mapper/tensor/reshape2.cc.o [ 91%] Building CXX object CMakeFiles/paddle2onnx_cpp2py_export.dir/paddle2onnx/mapper/tensor/scale.cc.o [ 91%] Building CXX object CMakeFiles/paddle2onnx_cpp2py_export.dir/paddle2onnx/mapper/tensor/scatter.cc.o [ 91%] Building CXX object CMakeFiles/paddle2onnx_cpp2py_export.dir/paddle2onnx/mapper/tensor/scatter_nd_add.cc.o [ 92%] Building CXX object CMakeFiles/paddle2onnx_cpp2py_export.dir/paddle2onnx/mapper/tensor/set_value.cc.o [ 92%] Building CXX object CMakeFiles/paddle2onnx_cpp2py_export.dir/paddle2onnx/mapper/tensor/slice.cc.o [ 92%] Building CXX object CMakeFiles/paddle2onnx_cpp2py_export.dir/paddle2onnx/mapper/tensor/split.cc.o [ 93%] Building CXX object CMakeFiles/paddle2onnx_cpp2py_export.dir/paddle2onnx/mapper/tensor/squeeze2.cc.o [ 93%] Building CXX object CMakeFiles/paddle2onnx_cpp2py_export.dir/paddle2onnx/mapper/tensor/stack.cc.o [ 93%] Building CXX object CMakeFiles/paddle2onnx_cpp2py_export.dir/paddle2onnx/mapper/tensor/take_along_axis.cc.o [ 94%] Building CXX object CMakeFiles/paddle2onnx_cpp2py_export.dir/paddle2onnx/mapper/tensor/temporal_shift.cc.o [ 94%] Building CXX object CMakeFiles/paddle2onnx_cpp2py_export.dir/paddle2onnx/mapper/tensor/tile.cc.o [ 94%] Building CXX object CMakeFiles/paddle2onnx_cpp2py_export.dir/paddle2onnx/mapper/tensor/top_k.cc.o [ 95%] Building CXX object CMakeFiles/paddle2onnx_cpp2py_export.dir/paddle2onnx/mapper/tensor/top_k_v2.cc.o [ 95%] Building CXX object CMakeFiles/paddle2onnx_cpp2py_export.dir/paddle2onnx/mapper/tensor/transpose2.cc.o [ 95%] Building CXX object CMakeFiles/paddle2onnx_cpp2py_export.dir/paddle2onnx/mapper/tensor/unique.cc.o [ 96%] Building CXX object CMakeFiles/paddle2onnx_cpp2py_export.dir/paddle2onnx/mapper/tensor/unsqueeze2.cc.o [ 96%] Building CXX object CMakeFiles/paddle2onnx_cpp2py_export.dir/paddle2onnx/mapper/tensor/unstack.cc.o [ 96%] Building CXX object CMakeFiles/paddle2onnx_cpp2py_export.dir/paddle2onnx/mapper/tensor/where.cc.o [ 97%] Building CXX object CMakeFiles/paddle2onnx_cpp2py_export.dir/paddle2onnx/onnx_reader.cc.o [ 97%] Building CXX object CMakeFiles/paddle2onnx_cpp2py_export.dir/paddle2onnx/optimizer/convert_fp32_to_fp16.cc.o [ 97%] Building CXX object CMakeFiles/paddle2onnx_cpp2py_export.dir/paddle2onnx/optimizer/paddle2onnx_optimizer.cc.o [ 98%] Building CXX object CMakeFiles/paddle2onnx_cpp2py_export.dir/paddle2onnx/paddle_reader.cc.o [ 98%] Building CXX object CMakeFiles/paddle2onnx_cpp2py_export.dir/paddle2onnx/parser/parser.cc.o [ 98%] Building CXX object CMakeFiles/paddle2onnx_cpp2py_export.dir/third/optimizer/onnxoptimizer/optimize.cc.o [ 99%] Building CXX object CMakeFiles/paddle2onnx_cpp2py_export.dir/third/optimizer/onnxoptimizer/pass.cc.o [ 99%] Building CXX object CMakeFiles/paddle2onnx_cpp2py_export.dir/third/optimizer/onnxoptimizer/pass_manager.cc.o [ 99%] Building CXX object CMakeFiles/paddle2onnx_cpp2py_export.dir/third/optimizer/onnxoptimizer/pass_registry.cc.o [100%] Linking CXX shared module paddle2onnx_cpp2py_export.cpython-38-aarch64-linux-gnu.so /usr/bin/ld: /usr/lib/aarch64-linux-gnu/libprotobuf.a(descriptor.o): relocation R_AARCH64_ADR_PREL_PG_HI21 against symbol _ZTINSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEE’ which may bind externally can not be used when making a shared object; recompile with -fPIC
/usr/lib/aarch64-linux-gnu/libprotobuf.a(descriptor.o): in function google::protobuf::EnumDescriptor::CopyTo(google::protobuf::EnumDescriptorProto*) const': (.text+0x390c): dangerous relocation: unsupported relocation /usr/bin/ld: /usr/lib/aarch64-linux-gnu/libprotobuf.a(descriptor.o): relocation R_AARCH64_ADR_PREL_PG_HI21 against symbol _ZTINSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEE’ which may bind externally can not be used when making a shared object; recompile with -fPIC
/usr/lib/aarch64-linux-gnu/libprotobuf.a(descriptor.o): in function google::protobuf::Descriptor::CopyTo(google::protobuf::DescriptorProto*) const': (.text+0xdf9c): dangerous relocation: unsupported relocation /usr/bin/ld: /usr/lib/aarch64-linux-gnu/libprotobuf.a(descriptor.o): relocation R_AARCH64_ADR_PREL_PG_HI21 against symbol _ZTINSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEE’ which may bind externally can not be used when making a shared object; recompile with -fPIC
/usr/lib/aarch64-linux-gnu/libprotobuf.a(descriptor.o): in function google::protobuf::FileDescriptor::CopyTo(google::protobuf::FileDescriptorProto*) const': (.text+0xe1fc): dangerous relocation: unsupported relocation /usr/bin/ld: /usr/lib/aarch64-linux-gnu/libprotobuf.a(descriptor.o): relocation R_AARCH64_ADR_PREL_PG_HI21 against symbol _ZTINSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEE’ which may bind externally can not be used when making a shared object; recompile with -fPIC
/usr/lib/aarch64-linux-gnu/libprotobuf.a(descriptor.o): in function google::protobuf::internal::ArenaStringPtr::CreateInstance(google::protobuf::Arena*, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const*)': (.text._ZN6google8protobuf8internal14ArenaStringPtr14CreateInstanceEPNS0_5ArenaEPKNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEE[_ZN6google8protobuf8internal14ArenaStringPtr14CreateInstanceEPNS0_5ArenaEPKNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEE]+0x110): dangerous relocation: unsupported relocation /usr/bin/ld: /usr/lib/aarch64-linux-gnu/libprotobuf.a(int128.o): relocation R_AARCH64_ADR_PREL_PG_HI21 against symbol _ZNKSt5ctypeIcE8do_widenEc’ which may bind externally can not be used when making a shared object; recompile with -fPIC
/usr/lib/aarch64-linux-gnu/libprotobuf.a(int128.o): in function google::protobuf::operator<<(std::ostream&, google::protobuf::uint128 const&)': (.text+0xadc): dangerous relocation: unsupported relocation /usr/bin/ld: /usr/lib/aarch64-linux-gnu/libprotobuf.a(int128.o): relocation R_AARCH64_ADR_PREL_PG_HI21 against symbol _ZNKSt5ctypeIcE8do_widenEc’ which may bind externally can not be used when making a shared object; recompile with -fPIC
(.text+0xb14): dangerous relocation: unsupported relocation
/usr/bin/ld: /usr/lib/aarch64-linux-gnu/libprotobuf.a(int128.o): relocation R_AARCH64_ADR_PREL_PG_HI21 against symbol _ZNKSt5ctypeIcE8do_widenEc' which may bind externally can not be used when making a shared object; recompile with -fPIC (.text+0xb4c): dangerous relocation: unsupported relocation /usr/bin/ld: /usr/lib/aarch64-linux-gnu/libprotobuf.a(int128.o): relocation R_AARCH64_ADR_PREL_PG_HI21 against symbol _ZNKSt5ctypeIcE8do_widenEc’ which may bind externally can not be used when making a shared object; recompile with -fPIC
(.text+0xb78): dangerous relocation: unsupported relocation
/usr/bin/ld: /usr/lib/aarch64-linux-gnu/libprotobuf.a(descriptor.pb.o): relocation R_AARCH64_ADR_PREL_PG_HI21 against symbol _ZTINSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEE' which may bind externally can not be used when making a shared object; recompile with -fPIC /usr/lib/aarch64-linux-gnu/libprotobuf.a(descriptor.pb.o): in function google::protobuf::EnumDescriptorProto::MergePartialFromCodedStream(google::protobuf::io::CodedInputStream*)‘:
(.text+0x1d934): dangerous relocation: unsupported relocation
/usr/bin/ld: /usr/lib/aarch64-linux-gnu/libprotobuf.a(descriptor.pb.o): relocation R_AARCH64_ADR_PREL_PG_HI21 against symbol _ZTINSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEE' which may bind externally can not be used when making a shared object; recompile with -fPIC /usr/lib/aarch64-linux-gnu/libprotobuf.a(descriptor.pb.o): in function google::protobuf::DescriptorProto::MergePartialFromCodedStream(google::protobuf::io::CodedInputStream*)’:
(.text+0x1ff5c): dangerous relocation: unsupported relocation
/usr/bin/ld: /usr/lib/aarch64-linux-gnu/libprotobuf.a(descriptor.pb.o): relocation R_AARCH64_ADR_PREL_PG_HI21 against symbol _ZTINSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEE' which may bind externally can not be used when making a shared object; recompile with -fPIC /usr/lib/aarch64-linux-gnu/libprotobuf.a(descriptor.pb.o): in function google::protobuf::SourceCodeInfo_Location::MergePartialFromCodedStream(google::protobuf::io::CodedInputStream*)‘:
(.text+0x209e4): dangerous relocation: unsupported relocation
/usr/bin/ld: /usr/lib/aarch64-linux-gnu/libprotobuf.a(descriptor.pb.o): relocation R_AARCH64_ADR_PREL_PG_HI21 against symbol _ZTINSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEE' which may bind externally can not be used when making a shared object; recompile with -fPIC /usr/lib/aarch64-linux-gnu/libprotobuf.a(descriptor.pb.o): in function google::protobuf::FileDescriptorProto::MergePartialFromCodedStream(google::protobuf::io::CodedInputStream*)’:
(.text+0x21650): dangerous relocation: unsupported relocation
/usr/bin/ld: /usr/lib/aarch64-linux-gnu/libprotobuf.a(generated_message_reflection.o): relocation R_AARCH64_ADR_PREL_PG_HI21 against symbol _ZTINSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEE' which may bind externally can not be used when making a shared object; recompile with -fPIC /usr/lib/aarch64-linux-gnu/libprotobuf.a(generated_message_reflection.o): in function google::protobuf::internal::GeneratedMessageReflection::AddString(google::protobuf::Message*, google::protobuf::FieldDescriptor const*, std::__cxx11::basic_string<char, std::char_traits, std::allocator > const&) const’:
(.text+0xc854): dangerous relocation: unsupported relocation
/usr/bin/ld: /usr/lib/aarch64-linux-gnu/libprotobuf.a(generated_message_reflection.o): relocation R_AARCH64_ADR_PREL_PG_HI21 against symbol _ZTINSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEE' which may bind externally can not be used when making a shared object; recompile with -fPIC /usr/lib/aarch64-linux-gnu/libprotobuf.a(generated_message_reflection.o): in function void google::protobuf::internal::RepeatedPtrFieldBase::MergeFromInnerLoop<google::protobuf::internal::GenericTypeHandler<std::__cxx11::basic_string<char, std::char_traits, std::allocator > > >(void**, void**, int, int)‘:
(.text._ZN6google8protobuf8internal20RepeatedPtrFieldBase18MergeFromInnerLoopINS1_18GenericTypeHandlerINSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEEEEEEvPPvSD_ii[_ZN6google8protobuf8internal20RepeatedPtrFieldBase18MergeFromInnerLoopINS1_18GenericTypeHandlerINSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEEEEEEvPPvSD_ii]+0x7c): dangerous relocation: unsupported relocation
/usr/bin/ld: /usr/lib/aarch64-linux-gnu/libprotobuf.a(message.o): relocation R_AARCH64_ADR_PREL_PG_HI21 against symbol _ZTINSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEE' which may bind externally can not be used when making a shared object; recompile with -fPIC /usr/lib/aarch64-linux-gnu/libprotobuf.a(message.o): in function void google::protobuf::internal::RepeatedPtrFieldBase::AddAllocatedSlowWithCopy<google::protobuf::RepeatedPtrField<std::__cxx11::basic_string<char, std::char_traits, std::allocator > >::TypeHandler>(google::protobuf::RepeatedPtrField<std::__cxx11::basic_string<char, std::char_traits, std::allocator > >::TypeHandler::Type*, google::protobuf::Arena*, google::protobuf::Arena*)’:
(.text.ZN6google8protobuf8internal20RepeatedPtrFieldBase24AddAllocatedSlowWithCopyINS0_16RepeatedPtrFieldINSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEEE11TypeHandlerEEEvPNT_4TypeEPNS0_5ArenaESH[ZN6google8protobuf8internal20RepeatedPtrFieldBase24AddAllocatedSlowWithCopyINS0_16RepeatedPtrFieldINSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEEE11TypeHandlerEEEvPNT_4TypeEPNS0_5ArenaESH]+0x1e4): dangerous relocation: unsupported relocation
/usr/bin/ld: /usr/lib/aarch64-linux-gnu/libprotobuf.a(extension_set.o): relocation R_AARCH64_ADR_PREL_PG_HI21 against symbol _ZTINSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEE' which may bind externally can not be used when making a shared object; recompile with -fPIC /usr/lib/aarch64-linux-gnu/libprotobuf.a(extension_set.o): in function google::protobuf::internal::ExtensionSet::MutableString[abi:cxx11](int, unsigned char, google::protobuf::FieldDescriptor const*)‘:
/usr/bin/ld: /usr/lib/aarch64-linux-gnu/libprotobuf.a(extension_set.o): relocation R_AARCH64_ADR_PREL_PG_HI21 against symbol _ZTINSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEE' which may bind externally can not be used when making a shared object; recompile with -fPIC /usr/lib/aarch64-linux-gnu/libprotobuf.a(extension_set.o): in function google::protobuf::internal::ExtensionSet::AddString[abi:cxx11](int, unsigned char, google::protobuf::FieldDescriptor const*)’:
make[2]: *** [CMakeFiles/paddle2onnx_cpp2py_export.dir/build.make:1910: paddle2onnx_cpp2py_export.cpython-38-aarch64-linux-gnu.so] Error 1
make[1]: *** [CMakeFiles/Makefile2:206: CMakeFiles/paddle2onnx_cpp2py_export.dir/all] Error 2
make: *** [Makefile:136: all] Error 2
File “setup.py”, line 299, in
setuptools.setup(
File “/home/nvidia/envs/paddle/lib/python3.8/site-packages/setuptools/init.py”, line 145, in setup
return distutils.core.setup(**attrs)
File “/usr/lib/python3.8/distutils/core.py”, line 148, in setup
dist.run_commands()
File “/usr/lib/python3.8/distutils/dist.py”, line 966, in run_commands
self.run_command(cmd)
File “/usr/lib/python3.8/distutils/dist.py”, line 985, in run_command
cmd_obj.run()
File “/home/nvidia/envs/paddle/lib/python3.8/site-packages/setuptools/command/install.py”, line 67, in run
self.do_egg_install()
File “/home/nvidia/envs/paddle/lib/python3.8/site-packages/setuptools/command/install.py”, line 109, in do_egg_install
self.run_command(‘bdist_egg’)
File “/usr/lib/python3.8/distutils/cmd.py”, line 313, in run_command
self.distribution.run_command(command)
cmd_obj.run()
File “/home/nvidia/envs/paddle/lib/python3.8/site-packages/setuptools/command/bdist_egg.py”, line 172, in run
cmd = self.call_command(‘install_lib’, warn_dir=0)
File “/home/nvidia/envs/paddle/lib/python3.8/site-packages/setuptools/command/bdist_egg.py”, line 158, in call_command
self.run_command(cmdname)
cmd_obj.run()
File “/home/nvidia/envs/paddle/lib/python3.8/site-packages/setuptools/command/install_lib.py”, line 23, in run
self.build()
File “/usr/lib/python3.8/distutils/command/install_lib.py”, line 107, in build
self.run_command(‘build_py’)
cmd_obj.run()
File “setup.py”, line 204, in run
self.run_command(‘cmake_build’)
cmd_obj.run()
File “setup.py”, line 198, in run
subprocess.check_call(build_args)
File “/usr/lib/python3.8/subprocess.py”, line 364, in check_call
raise CalledProcessError(retcode, cmd)
subprocess.CalledProcessError: Command ‘[’/home/nvidia/.local/bin/cmake’, ‘–build’, ‘.’, ‘–’, ‘-j’, ‘8’]’ returned non-zero exit status 2.
