Pairing issue in bluetooth
Hi Team,
I am trying to bring up Bluetooth in UART using CYW43455 module in the custom board with Jetson Nano module.
I have done the following steps:
  1. I did the changes mentioned in this link.
  2. Copied the firmware to /etc/firmware folder.
  3. I did hciattach and following are the logs.
$ sudo hciattach -t 30 /dev/ttyTHS1 bcm43xx 3000000 flow
bcm43xx_init
Set Controller UART speed to 3000000 bit/s>
Flash firmware /etc/firmware/BCM4345C0_003.001.025.0144.0266.1MW.hcd>
Device setup complete
  1. Then I tried pairing from board to device with bluetoothctl and got the following logs:
$ sudo bluetoothctl>
[NEW] Controller 48:EB:62:C2:B8:C7 BlueZ 5.48 [default]
Agent registered
[bluetooth]# agent on>
Agent is already registered>
[bluetooth]# default-agent
Default agent request successful
[bluetooth]# scan on
Discovery started
[CHG] Controller 48:EB:62:C2:B8:C7 Discovering: yes
[NEW] Device 75:6E:A7:64:9C:05 75-6E-A7-64-9C-05
[NEW] Device 94:65:2D:99:CD:12 793ffad1
[NEW] Device 0D:61:95:00:1C:9B boAt Rockerz 600>
[bluetooth]# scan off
[CHG] Device 0D:61:95:00:1C:9B RSSI is nil
[CHG] Device 94:65:2D:99:CD:12 RSSI is nil
[CHG] Device 75:6E:A7:64:9C:05 RSSI is nil
[CHG] Controller 48:EB:62:C2:B8:C7 Discovering: no
Discovery stopped
[bluetooth]# pair 0D:61:95:00:1C:9B
Attempting to pair with 0D:61:95:00:1C:9B>
[CHG] Device 0D:61:95:00:1C:9B Connected: yes
Failed to pair: org.bluez.Error.AuthenticationFailed>
[CHG] Device 0D:61:95:00:1C:9B Connected: no
I am getting the above issue " Failed to pair: org.bluez.Error.AuthenticationFailed ". But If I try to pair and connect from the device to my board it is successful. Can you help me to resolve this issue?
@kayccc @WayneWWW @jonathanh @alanz
Thanks,
Sakthi
Hello!
There is a note on this page that says if the device does not have a pin, then you may need to manully ‘trust’ the device first by executing the ‘trust’ command.
Regards
Jon
I tried executing the trust command before pair command as mentioned in the above link. But I am facing the same issue.
#bluetoothctl
[NEW] Controller 48:EB:62:C2:B8:C7 mistral-desktop [default]
[NEW] Device F8:DA:0C:48:D7:BC LAP391U
Agent registered
[bluetooth]# trust F8:DA:0C:48:D7:BC
[CHG] Device F8:DA:0C:48:D7:BC Trusted: yes
Changing F8:DA:0C:48:D7:BC trust succeeded
[CHG] Device F8:DA:0C:48:D7:BC RSSI: -70
[CHG] Device F8:DA:0C:48:D7:BC TxPower: 10
[CHG] Device F8:DA:0C:48:D7:BC UUIDs: 0000110e-0000-1000-8000-00805f9b34fb
[CHG] Device F8:DA:0C:48:D7:BC UUIDs: 0000110c-0000-1000-8000-00805f9b34fb
[CHG] Device F8:DA:0C:48:D7:BC UUIDs: 0000110a-0000-1000-8000-00805f9b34fb
[CHG] Device F8:DA:0C:48:D7:BC UUIDs: 0000110b-0000-1000-8000-00805f9b34fb
[CHG] Device F8:DA:0C:48:D7:BC UUIDs: 00001112-0000-1000-8000-00805f9b34fb
[CHG] Device F8:DA:0C:48:D7:BC UUIDs: 00001108-0000-1000-8000-00805f9b34fb
[CHG] Device F8:DA:0C:48:D7:BC UUIDs: 00001133-0000-1000-8000-00805f9b34fb
[CHG] Device F8:DA:0C:48:D7:BC UUIDs: 00001132-0000-1000-8000-00805f9b34fb
[CHG] Device F8:DA:0C:48:D7:BC UUIDs: 0000112f-0000-1000-8000-00805f9b34fb
[CHG] Device F8:DA:0C:48:D7:BC UUIDs: 00001104-0000-1000-8000-00805f9b34fb
[CHG] Device F8:DA:0C:48:D7:BC UUIDs: 00001106-0000-1000-8000-00805f9b34fb
[CHG] Device F8:DA:0C:48:D7:BC UUIDs: 00001105-0000-1000-8000-00805f9b34fb
[CHG] Device F8:DA:0C:48:D7:BC UUIDs: 00005005-0000-1000-8000-0002ee000001
[bluetooth]# pair F8:DA:0C:48:D7:BC
Attempting to pair with F8:DA:0C:48:D7:BC
[CHG] Device F8:DA:0C:48:D7:BC Connected: yes
[CHG] Device F8:DA:0C:48:D7:BC Connected: no
Can anybody help me in resolving this?
Thanks,
Sakthi
Can you give some pointers to resolve this issue?
@alanz @WayneWWW @jonathanh @kayccc
Could anyone help me to resolve this issue?
Thanks,
Sakthi
Is there any devices paired or connected? pls try as followed instructions.
[bluetooth]# devices
-> If there is something in here, run:
[bluetooth]# remove XX:XX:XX:XX:XX:XX
Now run the command trust and then try to pair:
[bluetooth]# trust XX:XX:XX:XX:XX:XX
[bluetooth]# pair XX:XX:XX:XX:XX:XX
Hi @alanz,
Thanks for your reply. I have tried the commands that you have mentioned, the output is as follows:
#bluetoothctl
Agent registered
Discovery started
[NEW] Device D8:BB:2C:3C:88:8F iPhone
[CHG] Device D8:BB:2C:3C:88:8F RSSI is nil
[CHG] Controller 48:EB:62:C3:A0:D7 Discovering: no
Discovery stopped
[bluetooth]# remove D8:BB:2C:3C:88:8F
[DEL] Device D8:BB:2C:3C:88:8F iPhone
Device has been removed
[bluetooth]# trust D8:BB:2C:3C:88:8F
Device D8:BB:2C:3C:88:8F not available
I am getting the error “device not available”, if I try to remove the device and trust the device. Could you please let me know what other things I need to check?
Thanks,
Sakthi
You may try to systemctl restart bluetooth.service and make sure the devices (iphone) is aviable for pair and connection.
If it’s still not work, you can try other bluetooth device to see if there are any devices. I have an andriod phone which works well.
Hi @alanz,
I tried connecting to the android mobile after restarting bluetooth. If I do scan off and then remove device. I am getting “device not found” error.
Without turning off scan, If I do remove and trust. trust is succeeded but pairing issue still exists.
The following are the logs:
Device F4:F5:DB:A2:69:4A Naveena
[bluetooth]# remove F4:F5:DB:A2:69:4A
[DEL] Device F4:F5:DB:A2:69:4A Naveena
[NEW] Device F4:F5:DB:A2:69:4A Naveena
[bluetooth]# trust F4:F5:DB:A2:69:4A
[CHG] Device F4:F5:DB:A2:69:4A Trusted: yes
Changing F4:F5:DB:A2:69:4A trust succeeded
[bluetooth]# pair F4:F5:DB:A2:69:4A
Attempting to pair with F4:F5:DB:A2:69:4A
[CHG] Device F4:F5:DB:A2:69:4A Connected: yes
[CHG] Device F4:F5:DB:A2:69:4A Connected: no
Can you give some other pointers for me to debug?
Thanks,
Sakthi
Hi Folks,
I’m also facing the same issue as reported by @sakthikrishna.b.
I’m using CYM43455 module with the customized board and Jetson Nano SoM.
When I try to pair bluetooth with other bluetooth supported device like mobile, the pairing does not occur.
The bluez version I am using is 5.48
The problem is when the “pair” command is issued, it connects for one instance and disconnects immediately in less than 30seconds. But the device is not getting paired and the connection is also not established.
( Below logs for reference)
[bluetooth]# pair F4:F5:F6:F3:88:3C
Attempting to pair with F4:F5:F6:F3:88:3C
[CHG] Device F4:F5:F6:F3:88:3C Connected: yes
[CHG] Device F4:F5:F6:F3:88:3C Connected: no
I tried using connect <bt-adrs> command too and got the below error.
Failed to pair: org.bluez.Error.ConnectionAttemptFailed
I have also tried the above solutions mentioned in this question chain. Still the issue exists.
Can anyone please help me find the cause of the issue?
I encountered a similar problem. Whenever I executed pair , it would fail, even if I executed trust. However, when I directly connected , it would succeed. I don’t know why this happened. I described some details in the post:https://forums.developer.nvidia.com/t/bluetooth-unable-to-pair-properly-but-manually-skipping-pairing-can-connect-the-device-and-communicate/
