Expected Result: panel should wake up when resuming from s3
Defect Replication Steps:
1.install Ubuntu 20.10.
2.set system to DGPU mode.
3.set system to sleep.
4.wake up system.
5.Noticed panel remains black screen.
Marks: Can be reproduced with nouveau
Additional information:
Razer blade 15 laptop (RTX3070+I7-10750H)
generix
January 20, 2021, 10:18am
2
Please run nvidia-bug-report.sh as root and attach the resulting nvidia-bug-report.log.gz file to your post.
Same issue here, running Ubuntu 20.10 with all the latest updates. Nvidia propriety drivers. Attached is the nvidia-bug-report
nvidia-bug-report.log.gz (351.4 KB)
Jan 29 08:32:25 CORSAIR-ONE kernel: nvidia-modeset: ERROR: GPU:0: Display engine push buffer channel allocation failed: 0x65 (Call timed out [NV_ERR_TIMEOUT])
Jan 29 08:32:25 CORSAIR-ONE kernel: nvidia-modeset: ERROR: GPU:0: Failed to allocate display engine core DMA push buffer
The last working driver with my card is 455.45.01. All more recent driver versions break with a black screen after loading of nvidia-modeset: First, the screen goes black, then the backlight is toggled several times (about 10 times), finally it stays blank and dark. Logs show:
[ 0.088017] Kernel command line: root=UUID=32278c21-b19c-47e0-8466-420bbb5a1642 ro rd.dm=0 nvidia-drm.modeset=1 net.ifnames=0 pcie_aspm=force initrd=boot\initramfs-5.9.11-gentoo.img
[ 3.143143] nvidia-nvlink: Nv…
Did this also start with the 460 driver version in your case?
I found this with Nouveau ,can be reproduced with 460.32. attached log with 460.39nvidia-bug-report.log.gz (319.3 KB)
Attached log with 460.39nvidia-bug-report.log.gz (319.3 KB)
