Hey all,
I took the code located at this repository:
https://github.com/NVIDIA-AI-IOT/tf_to_trt_image_classification
and modified the uff_to_plan file by adding this code
builder->setDefaultDeviceType(DeviceType::kDLA);
builder-> setDLACore(1);
builder->allowGPUFallback(true);
right below the builder to enable the dla. When I run either the classify_image script or the test_trt.py script I get them to successfully run but I get this series of errors at the end:
Parameter check failed at: dla/egUtils.cpp::~CudaProducer::162, condition cudaEGLStreamProducerDisconnect(&mConnection) failure.
Parameter check failed at: dla/egUtils.cpp::operator()::137, condition: eglDestroyStreamKHR(display, stream) failure.
Parameter check failed at: dla/egUtils.cpp::~CudaConsumer::245, condition cudaEGLStreamConsumerDisconnect(&mConnection) failure.
any thought to what might be causing it.
