From OpenCV 3.3,its dnn module include a deep learning based face detector,I test it and found it’s accuracy is good,so I decite to migrate its caffe model to TensorRT for I can catch the best performance,but I failed again,the ICaffeParser::parse() report below errors:
ERROR: mbox_loc: all concat input tensors must have the same dimensions except on the concatenation axis
ERROR: mbox_conf: all concat input tensors must have the same dimensions except on the concatenation axis
Caffe Parser: Invalid axis in softmax layer - Cannot perform softmax along batch size dimension and expects NCHW input. Negative axis is not supported in TensorRT, please use positive axis indexing error parsing layer type Softmax index 109
for my poor deep learning theory knowledge,I can’t solve above errors,so does anyone know how to fix these errors?should I have to write a custom trt plugin?
"ERROR: mbox_loc: all concat input tensors must have the same dimensions except on the concatenation axis
" The above message is a failure message, which indicates that the network cannot be built.
To help us debug, can you share a reproduction case that contains the model (computer_vision/CAFFE_DNN at master · gopinath-balu/computer_vision · GitHub )? and the tensorrt conversion code?
BOOL CreateFromCaffeModel(
const std::string& deployFile, // name for caffe prototxt
const std::string& modelFile, // name for model
unsigned int maxBatchSize, // batch size - NB must be at least as large as the batch we want to run with)
BOOL isFP16,
IHostMemory** trtModelStream, // output stream for the TensorRT model
ICudaEngine ** engine)
// create the builder
IBuilder* builder = createInferBuilder(gLogger);
INetworkDefinition * network = builder->createNetwork();
// parse the caffe model to populate the network, then set the outputs
ICaffeParser* parser = createCaffeParser();
std::cout << "start to parse model \n" << endl;
const IBlobNameToTensor * blobToTensor = parser->parse(
deployFile.c_str(),
modelFile.c_str(),
*network,
isFP16 ? (DataType::kHALF) : (DataType::kFLOAT)
assert(blobToTensor);
if (!blobToTensor)
return FALSE;
std::cout << "end parse model \n" << endl;
// init builder
builder->setMaxBatchSize(maxBatchSize);
builder->setMaxWorkspaceSize(10 << 20); // we need about 6MB of scratch space for the plugin layer for batch size 5
builder->setFp16Mode(isFP16 ? true : false);
builder->setInt8Mode(false);
// build engine
std::cout << "start to build engine \n" << endl;
(*engine) = builder->buildCudaEngine(*network);
assert(*engine);
if (!(*engine))
return FALSE;
std::cout << "end build engine \n" << endl;
// we don't need the network any more, and we can destroy the parser
network->destroy();
parser->destroy();
// clean
builder->destroy();
shutdownProtobufLibrary();
return TRUE;
