I would like to transfer from a camera frame grabber directly to GPU. I know PCI X supports device to device transfers, even though it’s seldom used due to no standard protocol.
Assuming, I can make the frame grabber conform to any protocol (reconfigurable logic), are current NVIDIA GPUs capable of receiving the data? What would need to change to support it? Driver/API support, or does the hardware need to be updated?
I just happened to be reading the forums then (I check the forums when I have a long compile, which is often!). Basically, lots of things need to change before it’s safe. Now, sharing pinned memory between the two devices in the not too distant future is far more likely.
Apparently the Quadro cards support direct transfers, so I’d like to request this feature for Tesla
as well, which I think is reasonable, especially since you pay ~$2000.
Pardon me if wrong…one way to answer your question is to lookup the drivers for the Quadro in Linux.
I just saw this:
during the initialization of the Nvidia driver:
/* find nvidia devices and set initial state */
int
nv_kern_probe
struct pci_dev *dev,
const struct pci_device_id *id_table
memory bus is enabled. ANd then subsequently, PCI will setup all the memory for DMA, marking them as nocache etc. Lots of mmap codes inside there, I may be wrong, but u can start from there to look for the code that setup the memory to be DMA-able by another device like frame-grabber?
Could you elaborate on “sharing pinned memory” a little bit more? Does “pinned memory” refer to memory on the host PC, or is there also pinned memory on the GPU? Or can the GPU use pinned memory on another PCI device?
