Pcie bus error: severity=Uncorrected (Non-Fatal),type=Transaction Layer, (Requester Ip)
Hello, my platform is jetson agx orin industrial + xilinx FPGA, after i log in the system,found the FPGA device has been scanned. there’re some erorrs happened when use command lspci. I wanna consult you how to fix this problem, please text me when available.
Please check if there is deviation between the custom board and AGX Orin developer kit. The default device tree is for developer kit and you would need to modify the device tree according to the board design. Please check product design guide and adaptation guide.
