• Hardware Platform (Jetson / GPU) dGPU
• DeepStream Version 5.0.1
• TensorRT Version
• NVIDIA GPU Driver Version (valid for GPU only) 440.118
I get the following error when I run the peoplenet resnet18 pruned model downloaded from NGC.
[property]
gpu-id=0
preprocessing parameters:
net-scale-factor=0.0039215697906911373
batch-size=1
tlt-model-key=tlt_encode
tlt-encoded-model=resnet18_peoplenet_pruned.etlt
labelfile-path=labels.txt
int8-calib-file=resnet18_peoplenet_int8.txt
num-detected-classes=3
infer-dims=3;544;960
uff-input-order=0
uff-input-blob-name=input_1
output-blob-names=output_bbox/BiasAdd;output_cov/Sigmoid
force-implicit-batch-dim=1
network-mode=1
process-mode=1
interval=0
gie-unique-id=1
filter-out-class-ids=0;1
[class-attrs-all]
pre-cluster-threshold=0.5
Set eps=0.7 and minBoxes for cluster-mode=1(DBSCAN)
eps=0.7
minBoxes=1
[NvDCF] Initialized
0:00:01.667239236 130 0x564f143b0c30 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1715> [UID = 1]: Trying to create engine from model files
INFO: ../nvdsinfer/nvdsinfer_func_utils.cpp:39 [TRT]: Reading Calibration Cache for calibrator: EntropyCalibration2
INFO: ../nvdsinfer/nvdsinfer_func_utils.cpp:39 [TRT]: Generated calibration scales using calibration cache. Make sure that calibration cache has latest scales.
INFO: ../nvdsinfer/nvdsinfer_func_utils.cpp:39 [TRT]: To regenerate calibration cache, please delete the existing one. TensorRT will generate a new calibration cache.
WARNING: ../nvdsinfer/nvdsinfer_func_utils.cpp:36 [TRT]: Missing dynamic range for tensor output_bbox/BiasAdd, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: ../nvdsinfer/nvdsinfer_func_utils.cpp:36 [TRT]: Missing dynamic range for tensor output_cov/BiasAdd, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: ../nvdsinfer/nvdsinfer_func_utils.cpp:36 [TRT]: Missing dynamic range for tensor output_cov/Sigmoid, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
INFO: ../nvdsinfer/nvdsinfer_func_utils.cpp:39 [TRT]: Some tactics do not have sufficient workspace memory to run. Increasing workspace size may increase performance, please check verbose output.
