Deepstream6.3 tao_pretrained_models | peopleNet .onnx to .engine
• Hardware Platform (Jetson / GPU) Jetson (Jetson Orin Nano - Dev Kit)
• DeepStream Version 6.3
• JetPack Version (valid for Jetson only) 5.1.2
• TensorRT Version 8.5.2.2
**• Issue Type( questions, new requirements, bugs) questions
Questions with tao_pretrained_model in deepstream-6.3
/opt/nvidia/deepstream/deepstream-6.3/samples/models/tao_pretrained_models/peopleNet
resnet34_peoplenet_int8.onnx
Tried running the below to create tensorRT engine file from onnx but not working
/usr/src/tensorrt/bin/trtexec --onnx=resnet34_peoplenet_int8.onnx --explicitBatch --saveEngine=resnet34_peoplenet_int8.engine --int8 --allowGPUFallback --useSpinWait
[01/14/2024-01:18:18] [I] [TRT] [MemUsageStats] Peak memory usage of TRT CPU/GPU memory allocators: CPU 10 MiB, GPU 498 MiB
[01/14/2024-01:18:18] [I] [TRT] [BlockAssignment] Started assigning block shifts. This will take 51 steps to complete.
[01/14/2024-01:18:18] [I] [TRT] [BlockAssignment] Algorithm ShiftNTopDown took 1.01485ms to assign 4 blocks to 51 nodes requiring 8551936 bytes.
[01/14/2024-01:18:18] [I] [TRT] Total Activation Memory: 8551936
[01/14/2024-01:18:18] [I] [TRT] [MemUsageChange] TensorRT-managed allocation in building engine: CPU +2, GPU +4, now: CPU 2, GPU 4 (MiB)
[01/14/2024-01:18:18] [E] Saving engine to file failed.
[01/14/2024-01:18:18] [E] Engine set up failed
  1. Any reasons it fails at the saving engine part?
  2. Also do i need to specific the --shapes flag when running /usr/src/tensorrt/bin/trtexec
Does the current account have write permission in current folder?
Can you try the trtexec command here: deepstream_tao_apps/build_triton_engine.sh at master · NVIDIA-AI-IOT/deepstream_tao_apps (github.com)
The pretrained peoplenet onnx model PeopleNet | NVIDIA NGC is dynamic batch input.
You can also consult Latest Deep Learning (Training & Inference)/TensorRT topics - NVIDIA Developer Forums for the usage of trtexec tool.
works now @Fiona.Chen.
tyvm folks.
