Request: Pre-built TensorRT Engine for PeopleNet ResNet34 INT8 (A100 + TensorRT 10.13)
Issue Description
I’m working with NVIDIA PeopleNet ResNet34 INT8 for object detection and need
help building a TensorRT engine from the encrypted .etlt model file. I’ve
attempted multiple approaches but encountered tooling compatibility issues.
Environment Details
Hardware:
  • GPU: NVIDIA A100 80GB PCIe (Compute Capability 8.0)
  • Platform: Azure NC96ads_A100_v4
Software:
  • OS: Ubuntu 22.04.5 LTS
  • Driver: 535.247.01
  • CUDA: 12.2
  • TensorRT: 10.13.0.35
Model Files:
  • resnet34_peoplenet_int8.etlt (86 MB)
  • resnet34_peoplenet_int8_calib.txt (9.4 KB)
What I’ve Tried
  1. TensorRT Python API - Cannot parse encrypted .etlt format
  2. Existing tao-converter - Requires TensorRT 8.x, I have 10.13
  3. DeepStream 7.0 Docker - Container environment complexities
What I Need
Option A (Preferred): Pre-built TensorRT engine file
Option B: Guidance on correct tao-converter version for TensorRT 10.13
Build Parameters
tao-converter
-k nvidia_tlt
-d 3,544,960
-o output_cov/Sigmoid,output_bbox/BiasAdd
-e resnet34_peoplenet_int8.engine
-t int8
-c resnet34_peoplenet_int8_calib.txt
-i nchw
-m 1
models/resnet34_peoplenet_int8.etlt
Questions
  1. Can someone provide a pre-built engine for A100 + TRT 10.13?
  2. What’s the correct tao-converter version for TensorRT 10.13?
  3. Should I convert .etlt to ONNX first?
Context
Production object detection pipeline for real-time video analytics. Pipeline is
ready - just blocked on TensorRT engine file.
Any help would be greatly appreciated! 🙏
Tags: deepstream, tensorrt, peoplenet, tao-toolkit, engine-build
Build command (if you have DeepStream/TAO):
tao-converter -k nvidia_tlt -d 3,544,960
-e resnet34_peoplenet_int8.engine -t int8
Takes ~5 min with DeepStream. Can you help?
Is there any error? if so, could you share the error information?
duplicate with Request: Pre-built TensorRT Engine for PeopleNet ResNet34 (A100 + TRT 10.13)
