HI,
I am using Inbox mellanox drivers (Not Mellanox OFED stack). In one scenario I have used MLX 100G connect 4x initiator (host) side. Target is our board. In that case we have better performance.
With setup variable is 100G connect 5x initiator (host) side. with that the performance became 1/3 compare to earlier one.
for 100G connect 5x we are using same way inserting driver and configuring roce v2 packets.
For Connect 5x any thing needed more? why we are observing performance degread with Connect 5x card
Our steps:
inserting fallowing modules
configfs.ko,ib_addr ib_core ib_mad ib_sa ib_cm iw_cm rdma_cm ib_uverbs ib_ucm rdma_ucm
nvme-core.ko,nvme.ko,nvme-fabric.ko,nvme-rdma.ko
mkdir /sys/kernel/config/rdma_cm/mlx5_0
echo “RoCE v2” > /sys/kernel/config/rdma_cm/mlx5_0/ports/1/default_roce_mode
