mlx5 with inbox driver 100G is not detecting
I am trying to up 100G Ethernet driver. I am using inbox driver, I am not using MLNX OFED stack.
I am inserting drivers manually in the sequence of ib_cm…mlx5_core,mlx5_ib
mkdir /sys/kernel/config/rdma_cm/mlx5_0
echo “RoCE v2” > /sys/kernel/config/rdma_cm/$mlx5_0/ports/1/default_roce_mode
But with ethtool command is not showing 100G, Am I missing some thing?
root@xhdipsspdk1 mailto:root@xhdipsspdk1 ~]# ethtool enp5s0
Settings for enp5s0:
Supported ports: [ FIBRE ]
Supported link modes: 1000baseT/Full
1000baseKX/Full
40000baseKR4/Full
40000baseCR4/Full
40000baseSR4/Full
40000baseLR4/Full
Supported pause frame use: Symmetric Receive-only
Supports auto-negotiation: No
Advertised link modes: 1000baseT/Full
1000baseKX/Full
40000baseKR4/Full
40000baseCR4/Full
40000baseSR4/Full
40000baseLR4/Full
Advertised pause frame use: No
Advertised auto-negotiation: No
Speed: Unknown!
Duplex: Unknown! (255)
Port: FIBRE
PHYAD: 0
Transceiver: internal
Auto-negotiation: off
Supports Wake-on: d
Wake-on: d
Supports Wake-on: d
Wake-on: d
Link detected: no
Please, perform the same test with MOFED in order to check if the issue related to inbox driver. I would also suggest to check the cable P/N and try connect ports in loopback ( one to another, using same cable).
Now I can able to work with Inbox and MLNX OFED stack. RHEL 7.0 and kernel 4.2
OS is Centos 7.3 at the moment, kernel is 3.10.0. Everything works as expected with MOFED (well, sort of).
I’ve encountered the same problem with the latest centos7 inbox rpms. Back to mofed it seems.
What OS and kernel are you use ?
Keep in mind that support for 25G/50G/100G was added to ethtool v4.8.
You may want to check which version your are running.
ethtool/ethtool.git - Ethernet device management tool. ethtool/ethtool.git - Ethernet device management tool.
