RHEL/CentOS update Inbox driver / howto compile
On a CentOS bases system i want to replace/update the Inbox driver version 2.2-1 with latest mlnx drivers.
System is equippped with ConnectX3 / MT27500.
downloaded latest package “MLNX_OFED_LINUX-4.2-1.0.0.0-rhel7.4-x86_64.tgz” but get errors when trying to install.
my system is using Kernel 4.12.4-1.el7.elrepo.x86_64
./mlnxofedinstall
Current operation system is not supported!
modinfo mlx4_core | head
filename: /lib/modules/4.12.4-1.el7.elrepo.x86_64/kernel/drivers/net/ethernet/mellanox/mlx4/mlx4_core.ko
version: 2.2-1
license: Dual BSD/GPL
description: Mellanox ConnectX HCA low-level driver
author: Roland Dreier
What’s the recommended way to update/replace/ the RHEL/CentOS Inbox driver (mlx4_core, mlx4_en) ?
Both ports run in ETH-mode, i do not use IB.
Hi
which centos you use? version?
you should change your mlnxofedinstall file for it accepting “wrong” OS.
Hi
does not work either …
./mlnxofedinstall --add-kernel-support --skip-repo
Will try with OFED for fedora later on
Hello, idk about 4.12.4 kernel, but we using custom RT kernel and using for install:
./mlnxofedinstall --add-kernel-support --skip-repo --wihout-32bit #you interesting in --add-kernel-support option
also you can try download ofed for the last fedora and modify some files to use it. but idk would it work or not.
