Hey All,
So I am having issues getting things installed on my server running a fresh copy of CentOS Stream 8. I am running a Mellanox Technologies MT27800 Family [ConnectX-5] Infiniband controller. Downloading the RHEL8.0 version of 5.2.2.0 results in a distro check failure unless I force it. Taking any suggestions on how to get this built (even via source which seems to have no documentation).
~ Joe G.
[root@Moleskine MLNX_OFED_LINUX-5.2-2.2.0.0-rhel8.0-x86_64]# ./mlnxofedinstall --distro rhel8.0 --add-kernel-support --without-fw-update
Note: This program will create MLNX_OFED_LINUX TGZ for rhel8.0 under /tmp/MLNX_OFED_LINUX-5.2-2.2.0.0-4.18.0-277.el8.x86_64 directory.
See log file /tmp/MLNX_OFED_LINUX-5.2-2.2.0.0-4.18.0-277.el8.x86_64/mlnx_iso.1447830_logs/mlnx_ofed_iso.1447830.log
Checking if all needed packages are installed…
Building MLNX_OFED_LINUX RPMS . Please wait…
ERROR: Failed executing “MLNX_OFED_SRC-5.2-2.2.0.0/install.pl --tmpdir /tmp/MLNX_OFED_LINUX-5.2-2.2.0.0-4.18.0-277.el8.x86_64/mlnx_iso.1447830_logs --kernel-only --kernel 4.18.0-277.el8.x86_64 --kernel-sources /lib/modules/4.18.0-277.el8.x86_64/build --builddir /tmp/MLNX_OFED_LINUX-5.2-2.2.0.0-4.18.0-277.el8.x86_64/mlnx_iso.1447830 --disable-kmp --build-only --distro rhel8.0”
ERROR: See /tmp/MLNX_OFED_LINUX-5.2-2.2.0.0-4.18.0-277.el8.x86_64/mlnx_iso.1447830_logs/mlnx_ofed_iso.1447830.log
Failed to build MLNX_OFED_LINUX for 4.18.0-277.el8.x86_64
