Trying To Install MLNX_OFED_LINUX-24.04-0.6.6.0
I am trying to install MLNX_OFED_LINUX-24.04-0.6.6.0 on my system.
Kernel Version : 4.18.0-553.5.1.el8_10.x86_64
The NIC on the system is :
lspci -v | grep Mellanox
86:00.0 Infiniband controller: Mellanox Technologies MT28908 Family [ConnectX-6]
Subsystem: Mellanox Technologies Device 0071
The error I am facing is :
ERROR: Failed executing “MLNX_OFED_SRC-24.04-0.6.6.0/install.pl --tmpdir /tmp/MLNX_OFED_LINUX-24.04-0.6.6.0-4.18.0-553.5.1.el8_10.x86_64/mlnx_iso.6899_logs --kernel-only --kernel 4.18.0-553.5.1.el8_10.x86_64 --kernel-sources /lib/modules/4.18.0-553.5.1.el8_10.x86_64/build --builddir /tmp/MLNX_OFED_LINUX-24.04-0.6.6.0-4.18.0-553.5.1.el8_10.x86_64/mlnx_iso.6899 --disable-kmp --build-only --distro rhel8.8”
ERROR: See /tmp/MLNX_OFED_LINUX-24.04-0.6.6.0-4.18.0-553.5.1.el8_10.x86_64/mlnx_iso.6899_logs/mlnx_ofed_iso.6899.log
Failed to build MLNX_OFED_LINUX for 4.18.0-553.5.1.el8_10.x86_64
Hope you have solved the issue.
Which OS is being used? What kind of installation command is executed?
Check this log for more detail:
Generally, we need to use the corresponding OFED version.
By the way, now DOCA is proposed to replace OFED
