Hello, I am trying to install OFED (looking at latest 5.8-2.0.3.0 on Rocky 8.8 but even with --skip-distro-check I get an error that the operating system is not supported. Is there a path-more-travelled way to install this?
The OFED just can’t support Rocky 8.8 directly.
we can try to use ‘–add-kernel-support’ , ex:
#./mlnxofedinstall --force --skip-distro-check --distro rhel8.8 --add-kernel-support --skip-repo
after installation , execute:
#dracut -f
more infomation refer to:
https://docs.nvidia.com/networking/display/MLNXOFEDv582030LTS/Installing+MLNX_OFED
Levei
I tried this command on Rocky 8.8, but still got some errors when building the RPM packages.
I ran ./mlnxofedinstall --force --skip-distro-check --distro rhel8.8 --add-kernel-support --skip-repo and got:
/tmp/MLNX_OFED_LINUX-4.9-6.0.6.0-4.18.0-477.10.1.el8_8.x86_64/mlnx_iso.1148273/OFED_topdir/BUILD/mlnx-ofa_kernel-4.9/obj/default/drivers/net/ethernet/mellanox/mlx4/en_cq.c: In function 'mlx4_en_activate_cq':
/tmp/MLNX_OFED_LINUX-4.9-6.0.6.0-4.18.0-477.10.1.el8_8.x86_64/mlnx_iso.1148273/OFED_topdir/BUILD/mlnx-ofa_kernel-4.9/obj/default/drivers/net/ethernet/mellanox/mlx4/en_cq.c:199:23: error: macro "netif_napi_add" passed 4 arguments, but takes just 3
NAPI_POLL_WEIGHT);
/tmp/MLNX_OFED_LINUX-4.9-6.0.6.0-4.18.0-477.10.1.el8_8.x86_64/mlnx_iso.1148273/OFED_topdir/BUILD/mlnx-ofa_kernel-4.9/obj/default/drivers/net/ethernet/mellanox/mlx4/en_cq.c:195:3: error: 'netif_napi_add' undeclared (first use in this function); did you mean 'netif_napi_del'?
netif_napi_add(cq->dev, &cq->napi,
netif_napi_del
/tmp/MLNX_OFED_LINUX-4.9-6.0.6.0-4.18.0-477.10.1.el8_8.x86_64/mlnx_iso.1148273/OFED_topdir/BUILD/mlnx-ofa_kernel-4.9/obj/default/drivers/net/ethernet/mellanox/mlx4/en_cq.c:195:3: note: each undeclared identifier is reported only once for each function it appears in
/tmp/MLNX_OFED_LINUX-4.9-6.0.6.0-4.18.0-477.10.1.el8_8.x86_64/mlnx_iso.1148273/OFED_topdir/BUILD/mlnx-ofa_kernel-4.9/obj/default/drivers/net/ethernet/mellanox/mlx4/en_cq.c:204:60: error: macro "netif_napi_add" passed 4 arguments, but takes just 3
netif_napi_add(cq->dev, &cq->napi, mlx4_en_poll_rx_cq, 64);
make[3]: *** [scripts/Makefile.build:317: /tmp/MLNX_OFED_LINUX-4.9-6.0.6.0-4.18.0-477.10.1.el8_8.x86_64/mlnx_iso.1148273/OFED_topdir/BUILD/mlnx-ofa_kernel-4.9/obj/default/drivers/net/ethernet/mellanox/mlx4/en_cq.o] Error 1
Maybe the driver does not support the kernel version of Rocky 8.8 (4.18.0-477.10.1.el8_8.x86_64)?
OFED 4.9 maybe too old to support Rockey OS. Could you try OFED 5.8
Hi, so I tried
./MLNX_OFED_LINUX-5.8-2.0.3.0-rhel8.7-x86_64/mlnxofedinstall --force --skip-distro-check --distro rhel8.8 --add-kernel-support --skip-repo
but it gave me
/lib/modules/4.18.0-477.10.1.el8_8.x86_64/build/scripts is required to build mlnx-ofa_kernel RPM.
Please install the corresponding kernel-devel RPM.
Error: One or more required packages for installing OFED-internal are missing.
Run:
yum install kernel-devel-4.18.0-477.10.1.el8_8.x86_64
Failed to build MLNX_OFED_LINUX for 4.18.0-477.10.1.el8_8.x86_64
But this package is already installed…
Last metadata expiration check: 23:36:43 ago on Tue 06 Jun 2023 04:47:44 PM -03.
Package kernel-devel-4.18.0-477.10.1.el8_8.x86_64 is already installed.
Dependencies resolved.
Nothing to do.
Complete!
Did I miss anything?
