mellanox connectx-4 RHEL 7.6 driver
While the supported driver for RHEL 7.6 is v4.7-1.0.0.1 as per Mellanox., but what we noticed is that the mellanox drivers that come with the RHEL kernel is 5.0-0.
How is this possible and supported ? Should we downgrade the driver verison to 4.7.x ?
[root@xyz ~]# modinfo mlx5_core
filename: /lib/modules/3.10.0-957.27.2.el7.x86_64/kernel/drivers/net/ethernet/mellanox/mlx5/core/mlx5_core.ko.xz
version: 5.0-0
it’s different package the version you see is inbox driver version that comes with RHEL OS
if you install the full MLNX_OFED you will see the correct version.
https://www.mellanox.com/products/infiniband-drivers/linux/mlnx_ofed
Thanks,
Samer
which is the higher version the inbox driver 5.0-0 or the 4.1.x ?
Does RHEL support the vendor driver versions ?
5.0 is the latest
Please refer to the following
https://www.mellanox.com/products/adapter-software/ethernet/inbox-drivers
inbox driver documentation by Mellanox
https://www.mellanox.com/pdf/prod_software/Red_Hat_Enterprise_Linux_(RHEL)_7.6_Driver_User_Manual.pdf
https://www.mellanox.com/pdf/prod_software/Red_Hat_Enterprise_Linux_(RHEL)_7.6_Driver_Release_Notes.pdf
Thanks,
Samer
