I’m building my own performance metrics scripts to assess the models. The idea is to include performance metrics (e.g. FPS/latency/etc) as well as the precision metrics from the model. As a sanity check, I’m trying to replicate the results (mAP) obtained from tlt-evaluate for a DetectNet_v2 model with ResNet-18 backbone.
However, I’ve realized there are different configuration parameters on the evaluation configuration file used in TLT and the DeepStream deployed engine. More specifically, I’m trying to understand the relation between the evaluation_config
used in the training/evaluation spec. file for TLT, and the pgie.txt
configuration file for DeepStream. Is there any way I can guarantee the same post-processing configuration for both cases?
For example, how can I reproduce the following post-processing configuration:
clustering_config {
coverage_threshold: 0.005
dbscan_eps: 0.15
dbscan_min_samples: 0.05
minimum_bounding_box_height: 20
Using the DeepStream configuration parameters (minBoxes, cluster-mode
, etc)
Thanks,
