I remember that I did it in the past but I don’t remember how. I want the people detector to only detect the body of people without arms, that is, the rectangle does not get bigger when I extend my arms.
How can I do it?
from
jetson_inference import detectNet
net = detectNet("ssd-mobilenet-v2", threshold=0.6)
while True:
img = input.Capture()
detections = net.Detect(img, overlay='box') # box,labels,conf or none
I do it with a detector, I placed the model. The pose estimator goes to 14 FPS and the detector to 17 FPS, that’s why the object detector suits me.
I don’t understand this, clarify it for me, please. Like I said, I remember getting it done before but I forgot what that line of code looks like. That is, when I extended my arms, the box did not increase.
You could attempt to edit the bounding boxes by running detections = net.Detect(img, overlay='none'), then modifying the detections (i.e. by aspect ratio or some other metric you define), and then run net.Overlay(img, detections) to generate the bounding-box overlay with your updated detections. However, this may not be robust in practice and you could either use the pose model as @AastaLLL suggested, or train your own detection model on a dataset which did not include the arms. Although you also seem to have a solution from before, I’m not sure what that was however as “no arms” is not a feature supported in jetson_inference.detectNet
