Please help:
- cannot run f1.f90 example with Tesla C870 card. Output from f1.exe:
call to cuCtxCreate returned error 2: Out of memory
NVIDIA SDK examples work fine
output from make f1
make f1
pgfortran -ta=nvidia -Minfo=accel -fast f1.f90 -o f1
NOTE: your trial license will expire in 14 days, 9.59 hours.
main:
38, Generating copyin(a(1:n))
Generating copyout(r(1:n))
39, Loop is parallelizable
Accelerator kernel generated
39, !$acc do parallel, vector(256)
- output from pgaccelinfo shows FAILED to create/destroy device context errors
Device Number: 0
Device Name: Tesla C870
Device Revision Number: 1.0
Global Memory Size: 1610350592
Number of Multiprocessors: 16
Number of Cores: 128
Concurrent Copy and Execution: No
Total Constant Memory: 65536
Total Shared Memory per Block: 16384
Registers per Block: 8192
Warp Size: 32
Maximum Threads per Block: 512
Maximum Block Dimensions: 512 x 512 x 64
Maximum Grid Dimensions: 65535 x 65535 x 1
Maximum Memory Pitch: 262144B
Texture Alignment 256B
Clock Rate: 1350 MHz
Initialization time: 5153 microseconds
Current free memory 1564213248
Upload time (4MB) 2195 microseconds (1381 ms pinned)
Download time 3604 microseconds (3729 ms pinned)
Upload bandwidth 1910 MB/sec (3037 MB/sec pinned)
Download bandwidth 1163 MB/sec (1124 MB/sec pinned)
Device Number: 1
Device Name: Quadro FX 370
Device Revision Number: 1.1
Global Memory Size: 267714560
Number of Multiprocessors: 2
Number of Cores: 16
Concurrent Copy and Execution: Yes
Warp Size: 32
Clock Rate: 720 MHz
FAILED to create device context
FAILED to destroy device context
