Hi:
I’m experimenting OpenMP recently and find a strange compile error related to THREADPRIVATE derivative when using pgf90 to compile the following code :
MODULE A22_MODULE8
REAL, POINTER :: WORK(:)
SAVE WORK
!$OMP THREADPRIVATE(WORK)
END MODULE A22_MODULE8
SUBROUTINE SUB1(N)
USE A22_MODULE8
!$OMP PARALLEL PRIVATE(THE_SUM)
ALLOCATE(WORK(N))
CALL SUB2(THE_SUM)
WRITE(,)THE_SUM
!$OMP END PARALLEL
END SUBROUTINE SUB1
SUBROUTINE SUB2(THE_SUM)
USE A22_MODULE8
WORK(:) = 10
THE_SUM=SUM(WORK)
END SUBROUTINE SUB2
PROGRAM A22_8_GOOD
N = 10
CALL SUB1(N)
END PROGRAM A22_8_GOOD
The code above comes from the example of www.openmp.org’s latest manual (v2.5, Example A.22, page 162), which intents to test the use of THREADPRIVATE derivative.
When I use
pfg90 -mp -o test test.f90
to compile the file, PGI complier complains that:
PGF90-S-0034-Syntax error at or near identifier work (test.f90: 4)
This indicates that “!$OMP THREADPRIVATE(WORK)” has syntax error. So I’m very comfusing now. Does this mean that this kind of usage is not supported by PGI or it’s just a bug? My version is PGI 5.2.
I will be grateful if someone could hand out a clue on this.
