I’m developing a python module that calls Fortran executable to convert RPN (Environment Canada) files to r2c. I do not have the wisdom of the ancients : I’m not familiar with Fortran.
I got this error on my logfiles :
PGFIO/stdio: File too large
PGFIO-F-/formatted write/unit=10/error code returned by host stdio - 27.
File name = /data/local/tmpdirs/afqscli/26968/tmpIw37tm/tmprOmNG-/TT_0-9950sg_2004-06.r2c formatted, sequential access record = 1
In source file fst2r2c.f90, at line number 302 (line 307 sometimes too)
301 ! Write time stamp to R2C file
302 write(iunr2c,'(A,I8,I8,A,A,A,A,A)'), &
303 ':Frame ',ip2,ip2,' "',strymd,' ',strhms,'"'
304
305 ! Write data to R2C file
306 do j = 1, yCount
307 write(iunr2c,trim(r2cFormat))(fldr2c(i,j),i=1,xCount)
308 enddo
This error occurs when the r2c file is larger than 2GB : the fortran executable seems to be unable to deal with big files. After searching for a while I found here a topic indicating I had to recompile the fst2r2c executable using the -Mlfs option. I actually did it but the error still occurs with files larger than 2GB.
-Mlfs (32-bit Linux only) Link in the Large File Support routines
available on Linux versions later than > Red Hat 7.0 or SuSE 7.1> .
This will support files from Fortran I/O that are larger than
2GB. Equivalent to > -L$PGI/linux86/7.1-4/liblf> .
The program is run on this server :
Linux hawa 2.6.26-bpo.2-686-bigmem #1 SMP Fri Jul 3 21:38:05 UTC 2009 i686 GNU/Linux (Debian 32bits).
I wanted to know if the -Mlfs option (equivalent to -L$PGI/linux86/9.0/liblf in my case) was supported on my machine or not as I’m not on Fedora or SuSE. If not, should I consider moving my application to a 64bits server to fix that error ?
Regards,
kevindelorme
