Here is a cut down version of the example posted in runtime error
program ILLEGAL
implicit none
integer n,m,nm,i
real ,dimension(nm) :: V
n=2
m=0
nm=2*n-2-m+1
do i=1,nm
V(i)=0
end do
end program ILLEGAL
The array V is declared with a dimension that is not a constant; the extent nm is not even defined. PGI 12.2 on Windows (32- or 64-bit) happily compiles and links the program with no error message. If the -C option is used, a run-time subscript error occurs. Otherwise, the program crashes after an access error occurs.
The program is illegal and compilation should fail. For the same test program, GFortran 4.5 says
1
Error: Variable 'nm' cannot appear in the expression at (1)
kgupta.f90:4.24:
1
Error: The module or main program array 'v' at (1) must have constant shape
